    Problems getting setup on Raspberry Pi Desktop (for PC and Mac)
    18 Posts 3 Posters 7.9k Views 2 Watching
    • blake_northrupB
      blake_northrup
      I followed all of the instructions, but when I get to the npm install from within the MagicMirror directory, I get an error that states: -bash: npm: command not found. I have searched multiple sites, and cannot find anything on this.
      blake_northrupB Mykle1M 2 Replies Last reply
      • blake_northrupB
        blake_northrup @blake_northrup
        Just for reference, this is what version of Node I have installed. This is a really old, single core computer. Maybe it won’t run properly on here, but just wanted to check.
        nodejs/stable,now 8.11.1~dfsg-2~bpo9+1 i386 [installed]
        CPU INFO:
        cat /proc/cpuinfo
        processor : 0
        vendor_id : CentaurHauls
        cpu family : 6
        model : 9
        model name : VIA Nehemiah
        stepping : 8
        cpu MHz : 999.872
        cache size : 64 KB
        physical id : 0
        siblings : 1
        core id : 0
        cpu cores : 1
        apicid : 0
        initial apicid : 0
        fdiv_bug : no
        f00f_bug : no
        coma_bug : no
        fpu : yes
        fpu_exception : yes
        cpuid level : 1
        wp : yes
        flags : fpu vme de pse tsc msr cx8 sep mtrr pge cmov pat mmx fxsr sse rng rng_en ace ace_en
        bugs : cpu_meltdown spectre_v1 spectre_v2 spec_store_bypass l1tf
        bogomips : 1999.74
        clflush size : 32
        cache_alignment : 32
        address sizes : 32 bits physical, 32 bits virtual
        power management:
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @blake_northrup
          @blake_northrup said in Problems getting setup on Raspberry Pi Desktop (for PC and Mac):
          What version of npm?
          npm -v
          blake_northrupB 1 Reply Last reply
          • blake_northrupB
            blake_northrup @Mykle1
            @mykle1 Hey mkyle1, not sure. I get this error every time I try to run the npm command:
            Mykle1M 1 Reply Last reply
            • Mykle1M
              @blake_northrup
              Then it would seem you need to install npm
              • blake_northrupB
                @mykle1 Thanks for the reply mkyle1. See below what I get when trying to install NPM:
                sudo apt-get install nodejs npm
                Reading package lists… Done
                Building dependency tree
                Reading state information… Done
                Note, selecting ‘nodejs:amd64’ instead of ‘npm:amd64’
                nodejs is already the newest version (8.11.1~dfsg-2~bpo9+1).
                Some packages could not be installed. This may mean that you have
                requested an impossible situation or if you are using the unstable
                distribution that some required packages have not yet been created
                or been moved out of Incoming.
                The following information may help to resolve the situation:
                The following packages have unmet dependencies:
                nodejs : Conflicts: nodejs:amd64 but 10.15.1-1nodesource1 is to be installed
                nodejs:amd64 : Depends: python-minimal:amd64 but it is not going to be installed
                Conflicts: nodejs but 8.11.1~dfsg-2~bpo9+1 is to be installed
                E: Unable to correct problems, you have held broken packages.
                  bhepler Module Developer @blake_northrup
                  @blake_northrup Yikes. It looks like something went wrong with your Node installation. Thankfully, you’re not the first person to encounter this. There’s already a thread on this forum discussing it.
                  • blake_northrupB
                    blake_northrup
                    @bhepler Thank you bhelper. I will check this out. In the meantime, I think I will retire this ancient computer, and use it as a display piece. :)
                    • Mykle1M
                      @blake_north
                      What OS are you running on that laptop? I’ve gotten single core laptops to run MM under ubuntu.
                      For what it’s worth:
                      https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other
                      • blake_northrupB
                        @mykle1 It’s actually on old mini PC. To give you an idea of how old it is, Windows XP was running on it previously.
                        • Mykle1M
                          @blake_northrup
                          Well, if you’re willing to retire it then you might not mind wiping it clean and installing ubuntu on it, Then install MM. Just a thought.
                          EDIT:
                          In other words, JUST ubuntu as your os
                          • blake_northrupB
                            @mykle1 I will give that a try. It’s a very small computer, so would fit nicely in certain places. I appreciate your help, and I will take a look at your other post to see if I can give it one last shot.
                            • Mykle1M
                              @blake_northrup
                              Good luck mate. Let me know how you make out
                              blake_northrupB 2 Replies Last reply
                              • blake_northrupB
                                @mykle1 Apparently this computer is so old, that Ubuntu 16 won’t install. Error: This kernel requires the following features not present on the CPU: pae cx8
                                • blake_northrupB
                                  @mykle1 I’m now installing Xubuntu 12.04. I’ll see how this goes, and let you know.
                                  • blake_northrupB
                                    blake_northrup
                                    Well, ended up going with Ubuntu 10.10. It’s old as heck, but I’m going to use it as a dakboard. Thanks for the help guys.
                                    • Mykle1M
                                      @blake_northrup
                                      So, no problems with node now? And MM is running on 10.10?
                                      • blake_northrupB
                                        @mykle1 I decided to just run Dakboard VIA the Chromium browser on it. I’v got a couple of other computers that I am going to use for the other Magic Mirror. I have an old Pentium 4 Dell, that I put Linux Mint on, and it runs like a champ. Way better than the one I run on my Raspberry Pi3.
