    Problems getting setup on Raspberry Pi Desktop (for PC and Mac)
    18 Posts 3 Posters 7.8k Views 2 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @blake_northrup
      @blake_northrup
      Then it would seem you need to install npm
      blake_northrupB 1 Reply Last reply Reply Quote 1
      • blake_northrupB
        blake_northrup @Mykle1
        @mykle1 Thanks for the reply mkyle1. See below what I get when trying to install NPM:
        sudo apt-get install nodejs npm
        Reading package lists… Done
        Building dependency tree
        Reading state information… Done
        Note, selecting ‘nodejs:amd64’ instead of ‘npm:amd64’
        nodejs is already the newest version (8.11.1~dfsg-2~bpo9+1).
        Some packages could not be installed. This may mean that you have
        requested an impossible situation or if you are using the unstable
        distribution that some required packages have not yet been created
        or been moved out of Incoming.
        The following information may help to resolve the situation:
        The following packages have unmet dependencies:
        nodejs : Conflicts: nodejs:amd64 but 10.15.1-1nodesource1 is to be installed
        nodejs:amd64 : Depends: python-minimal:amd64 but it is not going to be installed
        Conflicts: nodejs but 8.11.1~dfsg-2~bpo9+1 is to be installed
        E: Unable to correct problems, you have held broken packages.
          bhepler Module Developer @blake_northrup
          @blake_northrup Yikes. It looks like something went wrong with your Node installation. Thankfully, you’re not the first person to encounter this. There’s already a thread on this forum discussing it.
          • blake_northrupB
            blake_northrup
            @bhepler Thank you bhelper. I will check this out. In the meantime, I think I will retire this ancient computer, and use it as a display piece. :)
            • Mykle1M
              @blake_north
              What OS are you running on that laptop? I’ve gotten single core laptops to run MM under ubuntu.
              For what it’s worth:
              https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other
              blake_northrupB 1 Reply Last reply Reply Quote 0
              • blake_northrupB
                @mykle1 It’s actually on old mini PC. To give you an idea of how old it is, Windows XP was running on it previously.
                • Mykle1M
                  @blake_northrup
                  Well, if you’re willing to retire it then you might not mind wiping it clean and installing ubuntu on it, Then install MM. Just a thought.
                  EDIT:
                  In other words, JUST ubuntu as your os
                  • blake_northrupB
                    @mykle1 I will give that a try. It’s a very small computer, so would fit nicely in certain places. I appreciate your help, and I will take a look at your other post to see if I can give it one last shot.
                    • Mykle1M
                      @blake_northrup
                      Good luck mate. Let me know how you make out
                      blake_northrupB 2 Replies Last reply Reply Quote 1
                      • blake_northrupB
                        @mykle1 Apparently this computer is so old, that Ubuntu 16 won’t install. Error: This kernel requires the following features not present on the CPU: pae cx8
                        • blake_northrupB
                          @mykle1 I’m now installing Xubuntu 12.04. I’ll see how this goes, and let you know.
                          • blake_northrupB
                            blake_northrup
                            Well, ended up going with Ubuntu 10.10. It’s old as heck, but I’m going to use it as a dakboard. Thanks for the help guys.
                            • Mykle1M
                              @blake_northrup
                              So, no problems with node now? And MM is running on 10.10?
                              • blake_northrupB
                                @mykle1 I decided to just run Dakboard VIA the Chromium browser on it. I’v got a couple of other computers that I am going to use for the other Magic Mirror. I have an old Pentium 4 Dell, that I put Linux Mint on, and it runs like a champ. Way better than the one I run on my Raspberry Pi3.
