    Glossy or Non-Glossy Display
    17 Posts 5 Posters 10.0k Views 3 Watching
    • T
      thedk
      Thanks for your answer.
      Yes, the brightness is the issue. As i could see the non-glossy Displays are brighter. Maybe with the glossy Displays i would have less ghosting, but then the mirror would be darker.
      After everything i read, i decided to try an other glas, the Mirastar with just 3% transmission. So i wont change the Display now.
      I will post photos when its here.
      • bheplerB
        bhepler Module Developer
        Before you get too wrapped up in switching displays or glass, be sure to lower the brightness on your display and up the contrast. That should lower the amount of background illumination but make the content pop out a bit.
        • T
          thedk
          I allready did.
          I have only 40x30 Mirror. So the glas isnt that expensive and the first display was a gift. Till now, the Mirror wasnt that expensive ^^
          lavolp3L 1 Reply Last reply
          • lavolp3L
            lavolp3 Module Developer @thedk
            @thedk It’s also very important to have no light coming to the glass from behind. However your setup is, make sure that it is as dark as possible behind the glass.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • T
              thedk
              Yes. I made a black Frame between the display and the frame of the mirror.
              I’ll post a picture later.
              • T
                thedk
                Today the MIRASTAR glas came.
                Had a look again at the Display. Its a glossy one. Always thought its a non glossy. Maybe i will change this.
                Here ist the different between the glas:
                MIRROPANE
                Without light
                MIRASTAR
                Without light
                J 1 Reply Last reply
                  j.e.f.f Project Sponsor Module Developer @thedk
                  @thedk said in Glossy or Non-Glossy Display:
                  Picture Upload doesnt work
                  This happens to me if the picture is too high in resolution. Try making it smaller maybe
                  • T
                    thedk
                    Uploaded again. A lil bit big, but have a look.
                    • lavolp3L
                      @thedk So what’s your conclusion?
                      It’s difficult to really see the difference from the pictures.
                      And what types of Mirastar and Mirropane have you chosen and where have you bought them (I’m from germany as well)
                      • T
                        thedk
                        Bought at Brigla-shop.de. Cheapest shop i found.
                        Both are 4mm glas. The Mirastar is way darker, looks like you cant see everything when i have the light on. But you can see everything and, very imporant for me, you cant see the Display anymore.
                        lavolp3L 2 Replies Last reply
                        • lavolp3L
                          @thedk I have a Mirastar from Brigla as well. And they are indeed the cheapest. I found it a bit too dark and too brownish/yellowish. But the mirror is in a small room without natural lighting. That may be my problem.
                          Now trying out the Mirropane Chromespy 4mm in a better lit room.
                          • lavolp3L
                            In case you haven’t and for completeness: Keep in mind as well that the css colors are set to quite dark greys, so additionally to mirror transmission, monitor brightness, you can as well maipulate the brightness of the texts using css.
                            I have the feeling that lots of people don’t think abou that.
                            • T
                              thedk
                              Thanks for tbe advice. Didnt know this till now.
                              • T
                                thedk
                                To end this. I tried both, you dont really see any different.
