    602 Posts 67 Posters 2.3m Views 68 Watching
      costascontis
      i think using this module from develop branch it work decent with vlc but…it is breaking other modules and features and freezing mm from time to time.My backup from pre installing develop branch is working for weeks without a glitch.After installing the module and viewing just one stream ,its a matter of a few hours that something will stuck or mm freeze.I think that upgrading electron and using opengl is not ready for MM yet.
      • A
        anthony6608 @Cr4z33
        @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        @shbatm I’ve sent you yesterday a private message with everything you asked me.
        Did you find in it anything helpful to fix the issue? :)
        Did you see his post where he stated he was away working to earn money? :) They do this on their spare time for free and have to make a living somehow. He’s been very good with answering my questions when he is around. I am sure he’ll respond as soon as he returns and has a chance.
        • K
          kasperb @Cr4z33
          • K
            kasperb @Cr4z33
            @kasperb I actually added some code parts in the voice command module as per suggestion of its developer.
            If you’re using MMM-AssistantMk2 then I can tell you what to do (not if using other modules). :)
            Yes, I’m using MMM-AssistantMk2. Would love to hear your suggestion.
            Cr4z33C K 2 Replies Last reply Reply Quote 0
            • Cr4z33C
              Cr4z33 @kasperb
              @kasperb in your config.js go to the MMM-AssistantMk2 module and add
              					onActivate: {
              							timer: 0,
              							command: "RTSP_DEACTIVATE"
              					command: {
              							"RTSP_DEACTIVATE": {
              										notificationExec: {
              													notification: "RTSP-STOP",
              													payload: "all"
              • K
                kasperb @kasperb
                @kasperb said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                @Cr4z33 Thank you - this works perfect. Much appreciated.
                • Cr4z33C
                  Cr4z33 @kasperb
                  @kasperb you’re welcome however forgot to say that this was done by @Sean . ;)
                    shbatm Module Developer @Cr4z33
                    “RTSP_ACTIVATE”: {
                    notificationExec: {
                    notification: “RTSP-PLAY”,
                    payload: “all”
                    Regarding the other issue we’ve been working through – I sent you a chat, but if you have this part in your config with the rest of the TV channels–take it out and see if that fixes the problem you’ve been having with the wrong stream.
                    I think this is being called by AssistantMk2 after calling the individual stream.
                    • Cr4z33C
                      Cr4z33 @shbatm
                      @shbatm thank you mate deleting that part made everything work brilliantly!
                      • Cr4z33C
                        Cr4z33
                        So I am having finally some spare time to explain better how to to switch stream by voice control (think at ie. IP cameras, Internet TV/Radio channels, etc.).
                        We are going to use OMXplayer here (can’t say how it will be the result with VLC honestly…) and the good voice command module MMM-AssistantMk2.
                        So set it up properly and once you have it up and running come back and go on reading, otherwise contact @Sean (the author of that module) asking for help. :)
                        Open config.js with a text editor and go to the MMM-AssistantMk2 module section.
                        Replace
                        with
                        					onActivate: {
                        							timer: 0,
                        					transcriptionHook: {
                        								"CHANNEL_1": {
                        										pattern: "TV 1",
                        										command: "CHANGE_CHANNEL_1"
                        								"CHANNEL_2": {
                        										pattern: "TV 2",
                        										command: "CHANGE_CHANNEL_2"
                        								"CHANNEL_3": {
                        										pattern: "TV 3",
                        										command: "CHANGE_CHANNEL_3"
                        								"CHANNEL_4": {
                        										pattern: "TV 4",
                        										command: "CHANGE_CHANNEL_4"
                        								"CHANNEL_5": {
                        										pattern: "Radio 1",
                        										command: "CHANGE_CHANNEL_5"
                        								"CHANNEL_6": {
                        										pattern: "Radio 2",
                        										command: "CHANGE_CHANNEL_6"
                        								"CHANNEL_7": {
                        										pattern: "Radio 3",
                        										command: "CHANGE_CHANNEL_7"
                        					command: {
                        							"CHANGE_CHANNEL_1": {
                        										notificationExec: {
                        													notification: "RTSP-PLAY",
                        													payload: "stream1"
                        							"CHANGE_CHANNEL_2": {
                        										notificationExec: {
                        													payload: "stream2"
                        							"CHANGE_CHANNEL_3": {
                        										notificationExec: {
                        													payload: "stream3"
                        							"CHANGE_CHANNEL_4": {
                        										notificationExec: {
                        													payload: "stream4"
                        							"CHANGE_CHANNEL_5": {
                        										notificationExec: {
                        													payload: "stream5"
                        							"CHANGE_CHANNEL_6": {
                        										notificationExec: {
                        													payload: "stream6"
                        							"CHANGE_CHANNEL_7": {
                        										notificationExec: {
                        													payload: "stream7"
                        										notificationExec: {
                        													payload: "all"
                        Please note that the aforementioned stream names (ie. “TV 1”) used after pattern: HAVE TO BE the same that we will use below in the MMM-RTSPStream module or it won’t work!
                        Of course they are all examples so fit them to your needs, but remember to use then the same naming.
                        So let’s go to enter MMM-RTSPStream like the following:
                        			module: "MMM-RTSPStream",
                        			position: "bottom_right",
                        			disabled: false,
                        				autoStart: false, // Streams will start by voice commands only
                        				rotateStreams: true,
                        				rotateStreamTimeout: 0,
                        				shutdownDelay: 0,
                        				moduleWidth: 420, // Adjust it to your needs
                        				moduleHeight: 236, // Adjust it to your needs
                        				localPlayer: 'omxplayer',
                        				remotePlayer: 'none',
                        				showSnapWhenPaused: false,
                        				remoteSnaps: false,
                        				stream1: {
                        						url: 'IPofstream1',
                        						protocol: "tcp",
                        						frameRate: 'undefined',
                        						width: 420, // Adjust it to your needs
                        						height: 236 // Adjust it to your needs
                        				stream2: {
                        						url: 'IPofstream2',
                        						protocol: "tcp",
                        				stream3: {
                        						url: 'IPofstream',
                        						protocol: "tcp",
                        				stream4: {
                        						url: 'IPofstream',
                        						protocol: "tcp",
                        						width: 440, // Adjust it to your needs
                        						height: 247 // Adjust it to your needs
                        				stream5: {
                        						url: 'IPofstream',
                        						protocol: "tcp",
                        				stream6: {
                        						url: 'IPofstream6',
                        						protocol: "tcp",
                        				stream7: {
                        						url: 'IPofstream7',
                        						protocol: "tcp",
                        This should be all.
                        You can add as many streams as you want (I don’t see the problem if you run them one by one). ;)
                          costascontis
                          i am using the develop branch of the module with vlc and latest MM.The feed is playing alright but it seems it is over MM and when i click over another module the feed dissapears going under.How can i solve that?
                            bhepler Module Developer @costascontis
                            @costascontis - There may be a switch in VLC player that tells it to stay on top. I’d start looking at switches there.
                            • W
                              website19880927
                              this is my configuration:
                              module: “MMM-RTSPStream”,
                              position: “middle_center”,
                              header: “cam”,
                              autoStart: true,
                              rotateStreamTimeout: 10,
                              moduleWidth: 354,
                              moduleHeight: 240,
                              localPlayer: ‘omxplayer’,
                              remotePlayer: ‘none’,
                              showSnapWhenPaused: true,
                              remoteSnaps: true,
                              stream1: {
                              url: ‘rtsp://admin:a1234567@192.168.1.14/Streaming/Channels/1’,
                              frameRate: ‘undefined’,
                              hdUrl: ‘rtsp://admin:a1234567@192.168.1.14/Streaming/Channels/1’,
                              snapshotType: ‘url’,
                              snapshotRefresh: 10,
                              width: 354,
                              height: 240,
                              no response ,was it the problem of resolution,and how to configure that ,I tried many ways and still not success, and I can use my vlc to get the stream of the camera ,but was anything wrong with other configuration,no idea!
                              • Cr4z33C
                                Cr4z33 @website19880927
                                @website19880927 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                Try using VLC instead.
                                Replace
                                with
                                localPlayer: ‘vlc’
                                However you will have to use the developer branch of this module.
                                See here for instructions on how to install it:
                                https://github.com/shbatm/MMM-RTSPStream/tree/develop
                                I didn’t test 4K streaming, but it should be OK up to 1080p.
                                • NiggichN
                                  Niggich
                                  Hey Guys,
                                  any Solution to install the Modul at Ubuntu without Omxplayer? The option with vlc sounds good…
                                  • BKeyportB
                                    BKeyport Module Developer
                                    Believe it or not, I found that OMX is by far the most stable of setups in my use case. Odd, I know.
                                    I do restart my Mirror daily, however.
                                    • G
                                      goprojojo @BKeyport
                                      @bkeyport said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                      Are you using a script to auto restart and could you share?
                                      Cr4z33C BKeyportB 2 Replies Last reply Reply Quote 0
                                      • Cr4z33C
                                        Cr4z33 @goprojojo
                                        @goprojojo I guess he just scheduled the reboot command into cron (Google for it). ;)
                                        • BKeyportB
                                          BKeyport Module Developer @goprojojo
                                          @goprojojo
                                          Cron.
                                          #      m       h        dom    mon     dow     command
                                                 15      2        *      *       *       sudo reboot
                                          Why 2:15 you might ask? 2 AM daily my camera reboots and usually corrupts the display - takes about 10 minutes for it to restart where it don’t, and 5 more minutes to make sure it’s clear of it’s reboot and upgrade routines.
                                          I recommend https://crontab.guru/ to help you build cron tasks.
                                            p4lsec
                                            Does anyone know if it’s possible to use moduleOffset from within a single stream (stream3)? I couldn’t get it to work.
                                            I have three streams going. The first two are side-by-side, but the third is centered under them. I would like the third to be left-justified. Any ideas?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 30
                                            • 31
                                            • 13 / 31
