    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 764.5k Views 27 Watching
    • X
      Xclasher 0 @Mykle1
      @mykle1 Thanks :D I have tested out the integration of both modules. However, I have modified the MMM-voice to have pages in it as stated in the Hello-Lucy documentation. The modules I have included in the MMM-voice pages does not hide when I go to the specific page of the MMM-pages where the MMM-voice is. Any idea how i can hide the modules?
      Mykle1M M 2 Replies Last reply
      • bheplerB
        bhepler Module Developer @dazza120
        @dazza120 - Please use the Markdown features of the forum when posting code.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Xclasher 0
          @xclasher-0 said in Hello-Lucy:
          This is a bit confusing. You’re using MMM- voice with Hello-Lucy AND MMM-pages? My guide on the Hello-Lucy repo is quite easy to follow but I can still help with that. If you’re trying to integrate MMM-pages with that as well then I can’t help you. MMM-pages is not my module. I’ve never used it. You would likely have to modify MMM-voice and MMM-pages
            mdhenriksen @Xclasher 0
            Hey there! I’m not 100% what you mean, but you can easily hide modules in MMM-pages. The ones that keep showing up might be in your “exclude” section of MMM-pages in your config.js. Anything in “exclude” will show up on every page you have, so you have to remove the modules from that.
            X 1 Reply Last reply
            • Mykle1M
              I started thinking, "Why am I using page names like Page One, Page Two? Why not “Weather” for a page of weather modules? Or “Sports” for a page of sports modules? You get the idea. I hope. :-)
              https://www.youtube.com/watch?v=Zsm_hi7XvM4&feature=youtu.be
              • X
                Xclasher 0 @mdhenriksen
                @mdhenriksen Hi sorry for the late reply. Let me rephrase my question a bit. What I would like to do is just to have MMM-voice (With Lucy) work on one of the pages (From MMM-pages).
                I got that to work however, the pages I created from MMM-voice(With Lucy) aren’t working. And when I included the specific modules, it shows up all the time and does not hide. Though it still response with MMM-voice (With Lucy)
                So the problem is, how do I hide the specified modules at the start when magic mirror boot up?.
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  I’m still not sure why you want to use some pages with MMM-pages and others with Hello-Lucy. However, unless there is some conflict with MMM-pages then we can assume you haven’t created your pages correctly in Hello-Lucy. The readme is explicit and should be followed precisely. When you have done it correctly, the only modules displayed at start up will be MMM-voice (and MMM-EasyPix if you are using the face.gif or another image)
                  • A
                    Anthony Project Sponsor
                    I have some problems with Hello Lucy. Firstly sometimes when the MM reloads after Say"Hello, Lucy" I get an ERROR in mic’s icon place. Secondly when I don’t get the ERROR and I say : “MAGIC MIRROR” (my keyword) tha mic icon start flashing (not saying VOICE) but after that anything I say nothing is shown. And i don’t get any errors in pm2 logs or when I start MM with npm start dev . Any suggestions?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Anthony
                      @anthony
                      If you reload MM while MM is running you will get “an ERROR in mic’s icon place.” If you quit MM and relaunch MM you will not get this error.
                      When the mic starts flashing after saying your keyword “Magic MIrror” then Lucy is expecting a command. Example: Show Weather, Show Clock, Show Page One, etc.
                      You have to follow the instructions in the README file precisely if you are adding modules of your own. There is a list of modules that works be default in the README, as well. Those will all work without any modification by you. Any pages you create will have to be done as described in the README.
                      If you have trouble with a particular module I will help you. What commands are you saying to Lucy that do not work?
                      A 1 Reply Last reply
                      • A
                        Anthony Project Sponsor @Mykle1
                        @mykle1
                        I didn’t know that I must quit and restart MM for the mic to work properly. So the first problem solved. With the second one I know after the mic start flashing a command should follow but whatever I say lucy do nothing. For example after I say “Magic Mirror” and the mic icon start flashing I say “Show Clock” and nothing happens. I tried all default modules and nothing. I have added some modules to work with Lucy and did it exactly as you mentioned in the README. Also I have set in my config to start hidden and it does. It just don’t show anything. And sometimes when I say the wake word it does not even start flashing.
                        • ejay-ibmE
                          ejay-ibm Project Sponsor Module Developer
                          Hi @Mykle1 I don’t want to pollute your thread if my post isn’t appropriate here i’ll create a new one.
                          I love the animated avatar, could you point me where did you get it ?
                          I’m looking for 2 of the same kind. One like you have, the other with moving lips so it would look like it talk when the assistant reply to you with her voice. I have in mind how to achieve this, but I’m missing the gif sources .
                          Thank you
                          Ejay
                          • A
                            Anthony Project Sponsor @ejay-ibm
                            @ejay-ibm
                            Check this out: Original animated gif can be gotten here. It’s 60+ MB. https://github.com/HackerHouseYT/AI-Smart-Mirror/blob/master/magic_mirror/aiclient/face.gif.
                            It is copy pasted from Mykles1’s README file. I hope this is what you are looking for.
                            ejay-ibmE 1 Reply Last reply
                            • ejay-ibmE
                              ejay-ibm Project Sponsor Module Developer @Anthony
                              @anthony Thanks , I’m looking now for the same with animated lips
                              https://giphy.com/gifs/geocities-sl5XI0eWn5IjK
                              Something like this with more style. ^^
                              I’ll see if I can work with the 60mb file and make it move the lips .
                              thank you
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @ejay-ibm
                                @ejay-ibm
                                There is a 25MB version in the Hello-Lucy repo
                                https://github.com/mykle1/Hello-Lucy
                                • Mykle1M
                                  @anthony
                                  Have you replaced the correct files as per the readme? There are 2 folders in the Hello-Lucy repo. You have to take the files from them and put them where they belong according to the README. Not all default MM modules work automatically.
                                  • A
                                    I ant to believe that everything have been done correctly:
                                    1. Add in my modules.js folder the lines for voice control after the return wrapper.
                                    2. Add in the new voice_helper.js the lines for the new module (at the end of the last you have added) And change the names accordingly.
                                    3. In the new MMM-Voice.js folder a) add the module to the page I want to be shown and b) add the show/commands of the module again at the end of the last you have added. And every name is changed accordingly to the modules I added. The problem is that it doesn’t hear at all. My mic works when I test it. Yesterday in one of my attemps after “Magic Mirror” the mic icon started flashing and
                                      i said some commands and Lucy understand. But after a few seconds no more listening. And from then when I restart MM I get a blach screen (start hidden) and the mic icon with "Say, ‘Hello Lucy’ and whatever I say it stays still.
                                      Here is the MMM-voice.js with the pages of the modules I added:
                                         else if (notification === 'SHOW_PAGE_ONE') {
                                             MM.getModules().enumerate((module) => {
                                                    module.hide(1000);
                                           this.sendNotification('SHOW_CALENDAR');
                                           this.sendNotification('SHOW_CLOCK');
                                           this.sendNotification('SHOW_COMPLIMENTS');
                                           this.sendNotification('SHOW_COWBOY');
                                           this.sendNotification('SHOW_EARTH');
                                           this.sendNotification('SHOW_NEWS');
                                           this.sendNotification('SHOW_STATS');
                                           this.sendNotification('SHOW_VOICE');
                                           this.sendNotification('SHOW_REMOTECONTROL');
                                         } else if (notification === 'HIDE_PAGE_ONE') {
                                                    module.hide(1000);
                                         } else if (notification === 'SHOW_PAGE_TWO') {
                                                    module.hide(1000);
                                           this.sendNotification('SHOW_MOVIES');
                                           this.sendNotification('SHOW_HOROSCOPE');
                                           this.sendNotification('SHOW_HISTORY');
                                           this.sendNotification('SHOW_RECIPE');
                                           this.sendNotification('SHOW_MOON');
                                           this.sendNotification('SHOW_COCKTAILS');
                                        } else if (notification === 'HIDE_PAGE_TWO') {
                                                    module.hide(1000);
                                        } else if (notification === 'SHOW_PAGE_THREE') {
                                                    module.hide(1000);
                                           this.sendNotification('SHOW_RADIO');
                                           this.sendNotification('SHOW_PHOTOS');
                                        } else if (notification === 'HIDE_PAGE_THREE') {
                                                    module.hide(1000);
                                         } else if (notification === 'SHOW_PAGE_FOUR') {
                                                    module.hide(1000);
                                           this.sendNotification('SHOW_DARWIN');
                                           this.sendNotification('SHOW_FLIPPER');
                                           this.sendNotification('SHOW_PICTURES');
                                           this.sendNotification('SHOW_BACKGROUND');
                                           this.sendNotification('SHOW_PILOTS');
                                           this.sendNotification('SHOW_TIDES');
                                           this.sendNotification('SHOW_EYECANDY');
                                           this.sendNotification('SHOW_LICE');
                                           this.sendNotification('SHOW_LOTTERY');
                                           this.sendNotification('SHOW_FAX');
                                           this.sendNotification('SHOW_NASA');
                                           this.sendNotification('SHOW_ALARM');
                                           this.sendNotification('SHOW_WEATHER');
                                        } else if (notification === 'HIDE_PAGE_FOUR') {
                                                    module.hide(1000);
                                    And here is the same folder with the show/hide commands of the new modules:
                                              // MMM-voice sends notification to MMM-RadioDe to HIDE
                                                  else if (notification === 'HIDE_RADIO') {
                                                       this.sendNotification('HIDE_RADIO');
                                                  // MMM-voice sends notification to MMM-RadioDe to SHOW
                                                  else if (notification === 'SHOW_RADIO') {
                                              // MMM-voice sends notification to MMM-MovieInfo to HIDE
                                                  else if (notification === 'HIDE_MOVIES') {
                                                       this.sendNotification('HIDE_MOVIES');
                                                  // MMM-voice sends notification to MMM-MovieInfo to SHOW
                                                  else if (notification === 'SHOW_MOVIES') {
                                              // MMM-voice sends notification to MMM-horoscope to HIDE
                                                  else if (notification === 'HIDE_HOROSCOPE') {
                                                       this.sendNotification('HIDE_HOROSCOPE');
                                                  // MMM-voice sends notification to MMM-horoscope to SHOW
                                                  else if (notification === 'SHOW_HOROSCOPE') {
                                              // MMM-voice sends notification to MMM-History to HIDE
                                                  else if (notification === 'HIDE_HISTORY') {
                                                       this.sendNotification('HIDE_HISTORY');
                                                  // MMM-voice sends notification to MMM-History to SHOW
                                                  else if (notification === 'SHOW_HISTORY') {
                                              // MMM-voice sends notification to MMM-ImageSlideShow to HIDE
                                                  else if (notification === 'HIDE_PHOTOS') {
                                                       this.sendNotification('HIDE_PHOTOS');
                                                  // MMM-voice sends notification to MMM-ImageSlideShow to SHOW
                                                  else if (notification === 'SHOW_PHOTOS') {
                                              // MMM-voice sends notification to MMM-RemoteControl to HIDE
                                                  else if (notification === 'HIDE_REMOTECONTROL') {
                                                       this.sendNotification('HIDE_REMOTECONTROL');
                                                  // MMM-voice sends notification to MMM-Remote-Control to SHOW
                                                  else if (notification === 'SHOW_REMOTECONTROL') {
                                              // MMM-voice sends notification to mmm-food2fork-recipes to HIDE
                                                  else if (notification === 'HIDE_RECIPE') {
                                                       this.sendNotification('HIDE_RECIPE');
                                                  // MMM-voice sends notification to mmm-food2fork-recipes to SHOW
                                                  else if (notification === 'SHOW_RECIPE') {
                                    And here is the lines I added affter the return wrapper of each module.js folder for voice control:
                                    		return wrapper;
                                    	   notificationReceived: function(notification, payload) {
                                                this.hide(1000);
                                                this.updateDom(300);
                                            }  else if (notification === 'SHOW_HOROSCOPE') {
                                                this.show(1000);
                                    So take a look when you have the time and I hope you will spot if I have done something wrong and what it is. Thank you very much.
                                      on the mirror screen, press ctrl-shift-i (or start the mirror in developer mode with npm start dev)
                                      select the console tab of the dev window, and scroll back up to find any errors (red text)
                                      these will find syntax errors and other problems
                                      the module.js side displays in the dev console
                                      the node_helper.js side displays info in the terminal window
                                      • Mykle1M
                                        @anthony said in Hello-Lucy:
                                        Everything you have described seems correct. And you had Lucy running according to your quote above. Please do as @sdetweil suggests and check for errors
                                        • A
                                          @Mykle1
                                          I made some abdjustments yesterday mostly at the order of the modules (not sure if needed) and disabled by comenting all of those I don’t have istalled in my MM. Seemed to work better with only some problem with showing pages. All modules where showing and hidding perfectly. Only it had a hard time with pages. But today nothing again. I say my keyword mut the min icon doesn’t start flashing. And I don’t get any error when I start MM in dev mode. I guess I must consider trying another mic since the current one is not a good one.
                                          • Mykle1M
                                            @anthony
                                            Are you using a Pi? The Pi may struggle with this because of 1) The use of a usb microphone and 2) The amount and type of modules you are using
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
