    Develop module with API
    42 Posts 6 Posters 22.2k Views 6 Watching
      A Former User @htilburgs
      @htilburgs
      Then, you can access the jsonData like this; (This will be your main job)
      var Fajr = jsonResult.data.timings.Fajr
      console.log(Fajr)
      last, you can print it MM screen with .getDom()(You should call .updateDom() to update screen) or DOM manipulation.
      this.dataToShow.Fajr = jsonResult.data.timings.Fajr
      getDom : function() {
        var dom = document.createElement("div")
        if (this.dataToShow) dom.innerHTML = this.dataToShow.Fajr
        return dom
      I’m skipping many things. This is just hint or sample. Remains will be your homework. :D
      • htilburgsH Offline
        htilburgs @Mykle1
        @Mykle1 @Sean
        Both thanks for the quick reply.
        For now I’ve information that I can use to start.
        If there are any questions, I know where to be ;-)
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          htilburgs
          I used the example from MMM-UFO, and started the module.
          How can I check if there is data from the API URL?
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @htilburgs
            Oke, got it. I had to add some console.log settings…:flushed_face:
              htilburgs
              @Mykle1 I’m using MMM-UFO as example and trying to figure out. I’m getting somewhere but… The data is retrieved through the api and this is the result:
              Asr: "16:01"
              Dhuhr: "12:46"
              Fajr: "05:12"
              Imsak: "05:02"
              Isha: "20:21"
              Maghrib: "18:49"
              Midnight: "00:46"
              Sunrise: "06:44"
              Sunset: "18:49"
              The module is generated on the MM
              alt text
              But as you can see, it cannot read or display the data in the correct way.
              This is the code that I use to get the data from the resultset.
              // Fajr from data
              var mptFajr = document.createElement("div");
              mptFajr.classList.add("small", "bright", "fajr");
              mptFajr.innerHTML = "Fajr : " + MPT.Fajr;
              wrapper.appendChild(mptFajr);
              I can’t figure out what the problem is. It seems have something to do with the time-string that is returned. But whatever I try, no luck. Any idea?
                Mykle1 Project Sponsor Module Developer @htilburgs
                @htilburgs said in Develop module with API:
                Is this correct? MPT.Fajr above? Not mpt.Fajr?
                  sdetweil @Mykle1
                  @Mykle1 it’s not json format. Same problem as your PC stats
                    htilburgs
                    @Mykle1, @sdetweil ,
                    Looking at the website from the API Prayer Times API, the result are all displayed in JSON
                    The API has several endpoints to assist developers. Note that all the endpoints return JSON and are available over http and https.
                    I’ve looked at the code again and it should be MPT.Fajr.
                    I’ve made the module public on github, so you can take a look if you like.
                    MMM-MyPrayerTime
                    Meanwhile I’m trying to solve it…
                      @htilburgs
                      I don’t know what you exactly want,
                      but ,
                      Instead
                      var MPT = this.MPT[Keys[this.activeItem]];
                      Use this;
                      var MPT = this.MPT
                      You can get above picture.
                        htilburgs
                        @Sean,
                        This is what I want. Thanx for the quick reply!
                        Can you tell me what is the difference in the code?
                        This was an example from the MMM-UFO where information is rotated.
                        Because I don’t need it, I’m going to cleanup.
                          @htilburgs
                          Well, I don’t know what exactly you’ve tried, so difficult to tell what was wrong.
                          But,
                          You’ve already gotten timings from response of API in node_helper.js, and transfered it to your main module.
                          var result = JSON.parse(body).data.timings;
                          So your this.MPT might have this object structure;
                                "Fajr":"04:06",
                                "Sunrise":"05:35",
                                "Dhuhr":"11:39",
                          So, All you need is just refer it like this.MPT.Fajr.
                            htilburgs
                            @Sean,
                            Thank you for explaining and pointing me out.
                            I understand what was the issue. I’ve cleaned up the code and removed the caroussel part (and unneeded variables), because I don’t use that.
                            Added the possibility for showing or not showing some items.
                            Up to the next part… HTML Markup
                              htilburgs
                              Strugling with formatting. When I use the basic code, I got the result I like but it’s not displayed nice. I like to have 3 columns.
                              		var MPT = this.MPT;
                              		// Creating the div's for your data items
                              		var top = document.createElement("div");
                              		top.classList.add("list-row");
                              		// Fajr from data
                              		mptFajr.classList.add("small", "bright", "Fajr");
                              		mptFajr.innerHTML = "Fajr : " + MPT.Fajr + " الفجر";
                              		// Sunrise from data
                              		if (this.config.showSunrise != false) {
                              		    var mptSunrise = document.createElement("div");
                              		    mptSunrise.classList.add("small", "bright", "Sunrise");
                              		    mptSunrise.innerHTML = "Sunrise : " + MPT.Sunrise + " شروق الشمس";
                              		    wrapper.appendChild(mptSunrise);
                              		// Dhuhr from data
                              		var mptDhuhr = document.createElement("div");
                              		mptDhuhr.classList.add("small", "bright", "Dhuhr");
                              		mptDhuhr.innerHTML = "Duhr : " + MPT.Dhuhr + " الظهر";
                              		wrapper.appendChild(mptDhuhr);
                              		// Asr from data
                              		var mptAsr = document.createElement("div");
                              		mptAsr.classList.add("small", "bright", "Asr");
                              		mptAsr.innerHTML = "Asr : " + MPT.Asr + " العصر";
                              		wrapper.appendChild(mptAsr);
                              		// Sunset from data
                              		if (this.config.showSunset != false) {
                              		    var mptSunset = document.createElement("div");
                              		    mptSunset.classList.add("small", "bright", "Sunset");
                              		    mptSunset.innerHTML = "Sunset : " + MPT.Sunset + " غروب الشمس";
                              		    wrapper.appendChild(mptSunset);
                              		// Maghrib from data
                              		var mptMaghrib = document.createElement("div");
                              		mptMaghrib.classList.add("small", "bright", "Maghrib");
                              		mptMaghrib.innerHTML = "Maghrib : " + MPT.Maghrib + " المغرب";
                              		wrapper.appendChild(mptMaghrib);
                              		// Isha from data
                              		var mptIsha = document.createElement("div");
                              		mptIsha.classList.add("small", "bright", "Isha");
                              		mptIsha.innerHTML = "Isha : " + MPT.Isha + " العشاء";
                              		wrapper.appendChild(mptIsha);
                              		// Midnight from data
                              		if (this.config.showMidnight != false) {
                              		    var mptMidnight = document.createElement("div");
                              		    mptMidnight.classList.add("small", "bright", "Midnight");
                              		    mptMidnigh
                              alt text
                              Now I trying for several hours to figure out how to create table, columns, rows…
                              I’ve changed the code part to
                              		var MPT = this.MPT;
                              		var logs = document.createElement("table");
                              		var callWrapper = document.createElement("tr");
                              		callWrapper.classList.add("small");
                              		// Fajr
                              		var FajrTextCell = document.createElement("td");
                              		FajrTextCell.className.add = "xsmall bright fajrtext";
                              		FajrTextCell.innerHTML = "Fajr";
                              		callWrapper.appendChild(FajrTextCell);
                              		var FajrTimeCell = document.createElement("td");
                              		FajrTimeCell.className = "xsmall bright fajrtime";
                              		FajrTimeCell.innerHTML = MPT.Fajr;
                              		callWrapper.appendChild(FajrTimeCell);
                              		var FajrArabCell = document.createElement("td");
                              		FajrArabCell.className = "xsmall bright fajrarab";
                              		FajrArabCell.innerHTML = "الفجر";
                              		callWrapper.appendChild(FajrArabCell);
                              		logs.appendChild(callWrapper);
                              		wrapper.appendChild(logs);
                              		return wrapper;
                              The result for 1 item is nice
                              alt text
                              But when I repeat this for the other items, no rows are created and everything is on the same row.
                              		var MPT = this.MPT;
                              //Table Test
                              		// Fajr
                              		// Sunrise
                              		var SunriseTextCell = document.createElement("td");
                              		SunriseTextCell.className.add = "xsmall bright sunrisetext";
                              		SunriseTextCell.innerHTML = "Sunrise";
                              		var SunriseTimeCell = document.createElement("td");
                              		SunriseTimeCell.className = "xsmall bright fajrtime";
                              		SunriseTimeCell.innerHTML = MPT.Sunrise;
                              		callWrapper.appendChild(SunriseTimeCell);
                              		var SunriseArabCell = document.createElement("td");
                              		SunriseArabCell.className = "xsmall bright sunrisearab";
                              		SunriseArabCell.innerHTML = "شروق الشمس";
                              		callWrapper.appendChild(SunriseArabCell);
                              		return wrapper;
                              alt text
                              Any help to get me on the right track again?
                                @htilburgs
                                Insert “tr” element after each row.
                                  htilburgs
                                  Don’t I do this with this?
                                  S ? 2 Replies Last reply Reply Quote 0
                                    sdetweil @htilburgs
                                    @htilburgs yes, for each row, and the columns added to the row
                                      htilburgs @sdetweil
                                      @sdetweil I don’t understand what you mean.
                                        sdetweil @htilburgs
                                        @htilburgs make a table with HTML.
                                        tr have to be added to table for each row
                                        And td need to be added for each tr
                                        Right? Exactly the same using code
                                          @htilburgs
                                          https://www.w3schools.com/jsref/dom_obj_table.asp
                                          This might be help. Read following articles about table on that site.
                                            htilburgs
                                            @Sean @sdetweil I finaly figured it out! Thanx for the support and pointing me in the correct direction. See the result:
                                            alt text
                                            		var MPT = this.MPT;
                                            		// creating the tablerows
                                            		// Fajr
                                            		var FajrRow = document.createElement("tr")
                                            		FajrRow.className = "small fajr-row";
                                            		FajrRow.appendChild(FajrTextCell);
                                            		table.appendChild(FajrRow);
                                            		FajrTimeCell.className = "bright";
                                            		FajrRow.appendChild(FajrTimeCell);
                                            		FajrRow.appendChild(FajrArabCell);
                                            		return table;
