    MMM-Spotify
    249 Posts 51 Posters 359.7k Views 54 Watching
      A Former User @mmmmh
      @mmmmh
      Add this into your css/custom.css
      #SPOTIFY.pausing {
      display:none;
      M Cr4z33C 2 Replies Last reply
        mmmmh Project Sponsor @Guest
        @Sean said in MMM-Spotify:
        #SPOTIFY.pausing {
        display:none;
        Simple and works perfectly. Thanks!
        • Cr4z33C
          Cr4z33 @Guest
          @mmmmh
          #SPOTIFY.pausing {
          display:none;
          I stopped and quit the Windows 10 Spotify app, but the artwork keeps showing.
          ? 1 Reply Last reply
            A Former User @Cr4z33
            @Cr4z33
            That checks only playing and pausing. Inactive device is another issue.
            This module is pooling to pull current playback data per 1~2 secs.
            PPL may have several spotify devices, so if one device is deactivated, but others could be alive. And there’s no way to receive one device’s activeness at event time. (Spotify API doesn’t support pushing to client)
            To check “ALL DEVICES” are inactive, another pooling be needed to pull data about available devices per 1~2 sec. I’m not sure whether it’s good approach or not. It would make API usage double. (Somebody be already worrying about too many DNS calling by this module)
            Anyway, I’ll consider it.
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @Guest
              @Sean OK thanks.
                A Former User
                UPDATED
                1.1.1 (2019-04-11)
                • Added : CSS variable for easy adjusting size. (Adjust only --sp-width to resize)
                • Added : Hiding module when current playback device is inactivated. If you don’t want to hide , modify CSS .inactive. (More test might be needed, but…)
                justjim1220J 1 Reply Last reply
                • justjim1220J
                  justjim1220 Module Developer @Guest
                  @Sean
                  This popped up today:
                  [SPOTIFY] API Request fail on : /v1/me/player
                  { Error: connect ECANCELED 35.186.224.53:443
                      at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14)
                    errno: 'ECANCELED',
                    code: 'ECANCELED',
                    syscall: 'connect',
                    address: '35.186.224.53',
                    port: 443 } undefined
                  TypeError: Cannot read property 'statusCode' of undefined
                      at Request.request [as _callback] (C:\Users\jiman\MagicMirror\modules\MMM-Spotify\Spotify.js:189:23)
                      at self.callback (C:\Users\jiman\MagicMirror\node_modules\request\request.js:185:22)
                      at Request.emit (events.js:182:13)
                      at Request.onRequestError (C:\Users\jiman\MagicMirror\node_modules\request\request.js:877:8)
                      at ClientRequest.emit (events.js:182:13)
                      at TLSSocket.socketErrorListener (_http_client.js:382:9)
                      at TLSSocket.emit (events.js:182:13)
                      at emitErrorNT (internal/streams/destroy.js:82:8)
                      at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                      at process._tickCallback (internal/process/next_tick.js:63:19)
                  Any Ideas?
                  The module seems to be working as it is supposed to… :confused_face:
                  Jim Hallock - 1995
                    A Former User @justjim1220
                    @justjim1220 said in MMM-Spotify:
                    set updateInterval to 1500 or 2000, then try again.
                    lavolp3L 1 Reply Last reply
                      brokenwings
                      Hi everyone, I need your help
                      I successfully installed MM-Spotify and working fine
                      my problem I don’t know how how to put commands to play by voice assistant I’m still learning
                      about this raspberry pi, would anyone can share your command samples and where i place to put in
                      Thanks in advance!
                      • lavolp3L
                        lavolp3 Module Developer @Guest
                        @Sean Hi Sean, from your descriptions I assume you have spent some quality time with the Spotify API. Is there a way to get user-related statistics (e.g. most often heard songs in recent time, new albums by favorite artists…) on the mirror? Have you tried out anything of that?
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                          A Former User @lavolp3
                          @lavolp3
                          Maybe possible.
                          https://developer.spotify.com/documentation/web-api/reference/personalization/
                          https://developer.spotify.com/documentation/web-api/reference/users-profile/
                          https://developer.spotify.com/documentation/web-api/reference/browse/
                          I didn’t implement these apis yet. But not too difficult.
                          But… I have no idea how to use them for MM modules.
                          Maybe you can implement it by yourself. I made a class to wrap APIs so I think ppl can easily expand. https://github.com/eouia/MMM-Spotify/blob/master/Spotify.js
                          • lavolp3L
                            @Sean Well that’s fantastic. On my way…
                            What I see now as most interesting to me is a revolving Top 10 of songs for short_term, medium_term, and long_term.
                            • Cr4z33C
                              Cr4z33
                              @Sean I’ve switched Spotify account so I went to the MMM-Spotify folder, deleted the old token, update Client ID and Secret ID into spotify.config.json and created again (succesfully) the new token.
                              The problem is that now the module doesn’t come up when I want to play music from the smart mirror, BUT I still can hear the music (because of Raspotify I suppose).
                              Can you think about anything I am missing perhaps? :thinking_face:
                              PS: did you remove by chance your Telegram account? I am sending you private chat messages from time to time, but they never get a reply or show to be seen…
                                @Cr4z33 Show me the log. Usually I’m not in front of PC on weekends. :D
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @Sean oh OK. :grinning_face_with_smiling_eyes:
                                  I ran npm start, but unfortunately no error came up.
                                  Same thing for PM2 logs.
                                  At the end I tried to delete and reinstall MMM-Spotify, but the issue is still happening.
                                  By the way this is my current config entry:
                                  			module: "MMM-Spotify",
                                  			disabled: false,
                                  				onStart: null, // disable onStart feature with `null`
                                  				// allowDevices: ["Cr4z33 Mirror"],
                                  				control: "hidden", //"default", "hidden" available
                                    @Cr4z33
                                    Try it without any config (default setup).
                                    And nothing in log? Not only Error but also normal log can help to examine.
                                    At least these(or similar) logs should be shown.
                                    Connecting socket for: MMM-Spotify
                                    [SPOTIFY_AUTH] Token is expired. It will be refreshed
                                    [SPOTIFY_AUTH] Token refreshing...
                                    [SPOTIFY_AUTH] Token is written.
                                    ## or
                                    [SPOTIFY_AUTH] Token is fresh.
                                    • Cr4z33C
                                      Cr4z33 @Guest
                                      @Sean OK here is the console log output of default config with above module entry.
                                      Please note that I also launched Spotify playing (after launching MM).
                                      npm start
                                      > magicmirror@2.7.1 start /home/pi/MagicMirror
                                      > sh run-start.sh
                                      Starting MagicMirror: v2.7.1
                                      Loading config ...
                                      Loading module helpers ...
                                      Module helper loaded: MMM-Spotify
                                      All module helpers loaded.
                                      Server started ...
                                      Starting module: newsfeed
                                      Launching application.
                                      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                                      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                        @Cr4z33
                                        Hmmm weird. It seems nothing special suspicious point at all.
                                        The only thing I suspect is that you are using different account on MMM-Spotify and your real spotify player. but i think it would have bare chance.
                                        Try onStart to activate it by force, at least it would show some errors.
                                        onStart: {
                                            device: null,
                                            search: {
                                              type: "playlist",
                                              keyword: "death metal",
                                              random:true,
                                        • Cr4z33C
                                          Cr4z33
                                          @Sean tried this config
                                          			disabled: false,
                                          				// onStart: null, // disable onStart feature with `null`
                                          and the white big Spotify logo came up at MM loading and then disappeared.
                                          Isn’t it enough to // onStart line to let the module show all the time? :thinking_face:
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            Even if wasn’t the token OK at MM loading log?
                                            • 12
                                            • 13
                                            • 4 / 13
