    MMM-Spotify
    249 Posts 51 Posters 306.6k Views 54 Watching
      A Former User @lavolp3
      @lavolp3
      Maybe possible.
      https://developer.spotify.com/documentation/web-api/reference/personalization/
      https://developer.spotify.com/documentation/web-api/reference/users-profile/
      https://developer.spotify.com/documentation/web-api/reference/browse/
      I didn’t implement these apis yet. But not too difficult.
      But… I have no idea how to use them for MM modules.
      Maybe you can implement it by yourself. I made a class to wrap APIs so I think ppl can easily expand. https://github.com/eouia/MMM-Spotify/blob/master/Spotify.js
      • lavolp3L Offline
        lavolp3 Module Developer @Guest
        @Sean Well that’s fantastic. On my way…
        What I see now as most interesting to me is a revolving Top 10 of songs for short_term, medium_term, and long_term.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • Cr4z33C Offline
          Cr4z33
          @Sean I’ve switched Spotify account so I went to the MMM-Spotify folder, deleted the old token, update Client ID and Secret ID into spotify.config.json and created again (succesfully) the new token.
          The problem is that now the module doesn’t come up when I want to play music from the smart mirror, BUT I still can hear the music (because of Raspotify I suppose).
          Can you think about anything I am missing perhaps? :thinking_face:
          PS: did you remove by chance your Telegram account? I am sending you private chat messages from time to time, but they never get a reply or show to be seen…
            A Former User @Cr4z33
            @Cr4z33 Show me the log. Usually I’m not in front of PC on weekends. :D
            • Cr4z33C Offline
              Cr4z33 @Guest
              @Sean oh OK. :grinning_face_with_smiling_eyes:
              I ran npm start, but unfortunately no error came up.
              Same thing for PM2 logs.
              At the end I tried to delete and reinstall MMM-Spotify, but the issue is still happening.
              By the way this is my current config entry:
              			module: "MMM-Spotify",
              			disabled: false,
              				onStart: null, // disable onStart feature with `null`
              				// allowDevices: ["Cr4z33 Mirror"],
              				control: "hidden", //"default", "hidden" available
                @Cr4z33
                Try it without any config (default setup).
                And nothing in log? Not only Error but also normal log can help to examine.
                At least these(or similar) logs should be shown.
                Connecting socket for: MMM-Spotify
                [SPOTIFY_AUTH] Token is expired. It will be refreshed
                [SPOTIFY_AUTH] Token refreshing...
                [SPOTIFY_AUTH] Token is written.
                ## or
                [SPOTIFY_AUTH] Token is fresh.
                • Cr4z33C Offline
                  Cr4z33 @Guest
                  @Sean OK here is the console log output of default config with above module entry.
                  Please note that I also launched Spotify playing (after launching MM).
                  npm start
                  > magicmirror@2.7.1 start /home/pi/MagicMirror
                  > sh run-start.sh
                  Starting MagicMirror: v2.7.1
                  Loading config ...
                  Loading module helpers ...
                  Module helper loaded: MMM-Spotify
                  All module helpers loaded.
                  Server started ...
                  Starting module: newsfeed
                  Launching application.
                  Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                  Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    @Cr4z33
                    Hmmm weird. It seems nothing special suspicious point at all.
                    The only thing I suspect is that you are using different account on MMM-Spotify and your real spotify player. but i think it would have bare chance.
                    Try onStart to activate it by force, at least it would show some errors.
                    onStart: {
                        device: null,
                        search: {
                          type: "playlist",
                          keyword: "death metal",
                          random:true,
                    • Cr4z33C Offline
                      Cr4z33
                      @Sean tried this config
                      			disabled: false,
                      				// onStart: null, // disable onStart feature with `null`
                      and the white big Spotify logo came up at MM loading and then disappeared.
                      Isn’t it enough to // onStart line to let the module show all the time? :thinking_face:
                      • Cr4z33C Offline
                        Cr4z33 @Guest
                        @Sean said in MMM-Spotify:
                        Even if wasn’t the token OK at MM loading log?
                          @Cr4z33 said in MMM-Spotify:
                          Token might be OK with different account, but if different account is used, it cannot derive current playback info. (You cannot get spotify info from your friend’s account playback with your account). Have you several accounts for spotify?
                            This is normal. Unless you should customize CSS, with no playback, the module will be disappeared by default. (Some PPL have wanted so I added that feature.)
                            When playing on any Spotify player starts, module will be appeared. (If it can get current playback info from server)
                            • Cr4z33C Offline
                              Cr4z33
                              @Sean OK so to be 100% sure everything is set properly I start installing the module from scratch again generating once more the JSON file and the token.
                              • Cr4z33C Offline
                                Cr4z33
                                @Sean working now!
                                For some reason previous installation generated a token without .JSON at the end (I know because I made a backup on the Desktop) while this time it was generated properly!
                                Thanks for your support anyway. :grinning_face_with_smiling_eyes:
                                  mmmmh Project Sponsor
                                  @Sean Is it intentional that the z-index of the artwork (or the Spotify logo) is equal to or higher than whatever the Alert module shows? Alerts do not cover the Spotify module’s content.
                                    A Former User @mmmmh
                                    @mmmmh not intentional. i rarely use alert module, so i didnt know about it. if you can make PR to fix it, feel free to contribute.
                                    • L Offline
                                      larrougos
                                      Hi all! i ve set a config as
                                      SPOTIFY_MA_PLAYLIST: {
                                                  notificationExec: {
                                                      notification: "SPOTIFY_PLAY",
                                                      payload: (params) => {
                                                          console.log("SPOTIFY_MA_PLAYLIST")
                                                          return {
                                                              context_uri: "spotify:playlist:1EaTnmluBfauzzcOdjebNG", // Uri of a personnal playlist or album
                                                      notification: "SPOTIFY_SHUFFLE", // added this to toogle shuffle
                                                      notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                                      and activate it with
                                                  pattern: "play my playlist on spotify", // (.*)  is an action  eg: play my playlist / run my playlist etc...
                                                  command: "SPOTIFY_MA_PLAYLIST"
                                      but every time i get this result which is very weird
                                      weird response
                                      any ideas plz?
                                        A Former User @larrougos
                                        @larrougos
                                        It seems MMM-AssistantMk2’s commands.
                                        You made some mistakes.
                                        This is somewhat similar what you want.
                                        "SPOTIFY_MA_PLAYLIST": {
                                          notificationExec: {
                                            payload: "spotify:playlist:1EaTnmluBfauzzcOdjebNG"
                                        notificationExec cannot emit multiple notifications. It will emit just one - In your case, the last “SPOTIFY_NEXT” would be emitted. that’s why your issue happened.
                                        If you want to emit several notifications, use MMM-NotificationTrigger to relay and chain notifications. Or you can use moduleExec to make some logics. (Anyway that is not the point).
                                        And SPOTIFY_SHUFFLE is just toggle flag for current status, so it will not guarantee to be a shuffle mode.
                                        • L Offline
                                          larrougos @Guest
                                          @larrougos
                                            notificationExec: {
                                          ok!! thats a start! can you please help me with that! i mean how this should have a proper syntax! i would really appreciate.
                                          Also another problem that i have is that if spotify is not already playing in the background i am not able to play anything. whatever command i give. and the frontend does not even show the spotify logo. it just disappears on after one sec on start.
                                            @larrougos
                                            In that case, maybe, the module cannot find available active devices. It doesn’t mean you have no device. But by default, Spotify doesn’t know which device is yours unless it is powered and logged as your account.
                                            So at least one of your devices need to be activated when this SDK is used. I recommend to install Raspotify, that could makes your spotify always on.
                                            • 12
                                            • 13
                                            • 4 / 13
