    Raspberry Pi 4 Released !
    65 Posts 16 Posters 55.4k Views 13 Watching
    • Cr4z33C
      Cr4z33 @Guest
      @Sean said in Raspberry Pi 4 Released !:
      hmmmm. somewhat expensive (only in Germany?)
      Recently I’ve purchased several stronger alternatives - Khadas Edge-V around $100, NVIDIA Jetson nano $100 also.
      I will buy this one also for test, but could it be better than those?
      I was going to buy it from Germany too thinking at the good prices I got for the Pi 3 B, but at this round for some reason it is WAY cheaper (EUR 59 + shipping) to buy it from Italy for me.
      However let’s see what comes out with MagicMirror once I get it delivered (they say 24h) especially by using the new Raspbian Buster… :crossed_fingers_medium_skin_tone:
        Davido @Guest
        @Sean
        https://www.reichelt.de/?&ACTION=446&SEARCH=259874+259919+259920&DIRECT=1;&trstct=tsr_151284
        • mumblebajM
          mumblebaj Module Developer
          They will be R910 in South Africa when they arrive which makes them around 56 Euro.
            dazza120
            Anyone know if you can just boot off of the usb from an SSD?
            Cr4z33C E 2 Replies Last reply Reply Quote 0
            • lavolp3L
              lavolp3 Module Developer
              I was so hyped by this unexpected message I needed to order one (the 4gb of course).
              Please mind that it’s going to have a new kernel and current Raspbian Stretch will presumably not work on this one. A new Raspbian (Buster) has already been released. So we’ll have to see if MM runs on it without problems…
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • Cr4z33C
                Cr4z33 @dazza120
                @dazza120 yes.
                You can read here a very good article about all the good things it can do and how the Pi 4 is performing compared to the previous generation. :)
                https://www.tomshardware.com/reviews/raspberry-pi-4-b,6193.html
                • E
                  electros Project Sponsor @dazza120
                  @dazza120 said in Raspberry Pi 4 Released !:
                  Already I use a ssd with raspberry pi 3 b+. I hope will be working sane with raspberry 4.
                    dazza120 @electros
                    @electros yeah I do too but would love it to boot without altering it, to do it
                      dazza120 @Cr4z33
                      @Cr4z33 said in Raspberry Pi 4 Released !:
                      Any news? Just ordered mine as they where out of stock on the first day lol, need to get a micro to usb C adapter and a micro hdmi cable then get this puppy running
                        A Former User
                        2hdmi… 2 instance of MM possible?
                          SH20192
                          Just got mine. Gonna give it a try tonight.
                            SH20192
                            Base package installed and runs fine. Moving on to the modules now.
                              SH20192
                              All my modules work except MMM-SingleStock. So far it loads much faster than the Pi 3. I had to abandon using MM2 because I could not run it for more than 3 hours without crashing. Fingers crossed the 4 is more stable. Will let it run overnight to see.
                                dazza120 @SH20192
                                @SH20192 said in Raspberry Pi 4 Released !:
                                Yeah my Pi 3 seems to run out of memory, I opted for 4Gb model should have enough grunt to run everything with any issues
                                  SH20192 @dazza120
                                  @dazza120 Pi 4 has been running for 10 hours now and no issues. Had never been able to run the Pi 3 overnight so I think we have a winner!
                                  Cr4z33C 1 Reply Last reply Reply Quote 2
                                  • Cr4z33C
                                    Cr4z33 @SH20192
                                    @SH20192 are you using any cooling system and if yes what? :)
                                      SH20192 @Cr4z33
                                      Yes, a small fan on an open plexiglass case. No heatsink. Without the fan it would complain about overheating.
                                      Should mention it’s running 4 RTSP streams.
                                      • lavolp3L
                                        lavolp3 Module Developer @SH20192
                                        @SH20192 MM system works without changes on Raspbian Buster with the new kernel?
                                        I’m positively surprised…
                                        Gotta order a second one. Lol!
                                        D S 2 Replies Last reply Reply Quote 1
                                          dazza120 @lavolp3
                                          @lavolp3 said in Raspberry Pi 4 Released !:
                                          Can I just upgrade the Pi 3 to the Buster OS so i can just swap the ssd over. Can someone confirm if it’s a plug and play boot from OS on an SSD? Rather than through the bios bit to enable it. Really looking forward to this PI I might get a heat sink but I want a big one not the little ones, need to see if I still have the one from the sky box, got a fan already for it but only activates when the TV is on
                                            SH20192 @lavolp3
                                            Except for the one module mentioned above everything working for me on Buster. Haven’t looked at logs or anything to see if there are errors being thrown that I don’t notice but so far so good.
                                            • 1 / 4
