    MMM-voice
    voice control
    329 Posts 55 Posters 1.0m Views 50 Watching
    • MichMichM Offline
      MichMich
      Awesome work!
      Would be great if you could configure keywords which show/hide certain modules and configure notifications … something like this:
      keywords: {
          'HIDE WEATHER': {
              hide: ['weather']
          'SHOW WEATHER': {
              show: ['weather']
          'SIMPLE MODE': {
              hide: ['default','foo','bar'],
              show: ['simple']
          'RESTART': {
              notification: 'RESTART'
      It might be good to know that I’ll probably be implementing this in the coming weeks: https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism
      • cowboysdudeC Offline
        @daveyg_71 when you do what strawberry suggested after you reboot redo the
        arecord -l
        Like he said you may have to do it a couple times but it should show you more than likely your mic is 1
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Nonamexp
          @Nonamexp my guess is because you installed it in /root/… instead of /home/pi/… so it cant find the file
            daveyg_71 @strawberry 3.141
            @strawberry-3.141 Thanks for the advice. I plugged the mic into my Mac and I couldn’t get it to see it. Must be the mic. I ordered a new one so I will find out in a few days.
              SimJim
              If I run the installation, there is allways a error when it wants to install the PocketSphinx.
              What is wrong?
                strawberry 3.141 Project Sponsor Module Developer @SimJim
                @SimJim do you have some more output to provide?
                  SimJim
                  This is what happens all the time…
                    @SimJim i will test this tonight
                    • N Offline
                      Nonamexp
                      I’ve the next problem: On the Mirror shows the message ‘Error’ , ‘No Moduls identified’.
                      in the Error Log: Error: spawn pocketsphinx_continuous ENOENT-2
                      help me pls ;(
                      strawberry 3.141S 2 Replies Last reply Reply Quote 0
                        @Nonamexp as I said due to installing in root directory the binary will not be found
                        @SimJim Error code 56 indicates a curl receive error of CURLE_RECV_ERROR which means there was some issue that prevented the data from being received during the clone process. Typically this is caused by a network setting, firewall, VPN client, or anti-virus that is terminating the connection before all data has been transferred. It’s not related to this module this is something general
                          daveyg_71 @cowboysdude
                          @cowboysdude I got the new mic, and the pi can see it now, but the mirror is showing error next to the microphone.
                          Is there anything wrong with my config file?
                                                      module: 'MMM-voice',
                                                      position: 'bottom_bar',
                                                              microphone: 1,
                                                              keyword: 'MAGIC MIRROR',
                                                              timeout: 15,
                            strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                            @daveyg_71 there is an error log in the mmm-voice directory can you post it? and do you get any errors in the terminal or electron console?
                            cowboysdudeC D 2 Replies Last reply Reply Quote 1
                              cowboysdude Module Developer @strawberry 3.141
                              @strawberry-3.141 said in MMM-voice:
                              What please do what @strawberry-3-141 said :) Look in the directory for an error log… or when you start your mirror run it in dev mode: npm start dev
                                @strawberry-3.141 I opened up the error log and this is all I see:
                                1271271271271111111111111111
                                The mirror starts up with no problems. It just says error next to the microphone symbol.
                                • O Offline
                                  ostfilinchen
                                  i have sometimes the same error. Do u have restart the mirror via pm2 restart mm?
                                    darrene
                                    Hi @strawberry-3.141, I’ve just tried running the dependencies.sh from the latest .git to install MMM-voice and hit this error in step 5;
                                    [STEP 5/6] Installing npm dependencies
                                    dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                                    npm WARN enoent ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
                                    despite the fact that pocketsphinx seemed to come down and compile okay. I’m logged in as the pi user via ssh and ran the shell script with sudo bash dependancies.sh.
                                    Do you have any suggestions as to what’s happened?
                                    many thanks
                                      strawberry 3.141 Project Sponsor Module Developer @darrene
                                      @darrene yes dont run the script with sudo. as you can see it tries to install and look for files in root instead of home pi
                                        darrene @strawberry 3.141
                                        @strawberry-3.141 Doh! Thank you :)
                                          darrene
                                          Hmm, I too am getting the ‘Error’ mic icon message, once it finishes its initialisation phase when the mirror starts up.
                                          I’m started in dev mode - both the web and terminal consoles look clean - the last report I have in the terminal is 'MMM-voice: Starting pocketsphinx, so I don’t know if I should expect anything further messages in that console.
                                          I’ve taken a look in the MMM-voice/error.log which contains the value ‘127’. It’s repeatable - if i stop the mirror, remove the error log and restart, I get the same results. As a test I’ve tried altering the microphone value in the config.js from it’s initially correct value of 1 - It doesn’t affect the error, which leads me to believe it may not be a hardware issue(?)
                                          It’s such a shame - all steps reported to have completed okay, the microphone was detected - nothing looks to have been out of the ordinary.
                                          Is there anything else I can do to test or anywhere else I can look, before I try flattening the SD card and reinstalling?
                                            darrene @darrene
                                            progress of a sort…
                                            tried a sudo apt-get update, followed by a reboot
                                            same clean startups but between the ‘initialising’ and ‘error’ states I briefly get a ‘no mode found’ and the 127 error is gone - now I just get a 1 returned in the error log
                                            • 16
                                            • 17
                                            • 2 / 17
