    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      daveyg_71 @strawberry 3.141
      @strawberry-3.141 Thanks for the advice. I plugged the mic into my Mac and I couldn’t get it to see it. Must be the mic. I ordered a new one so I will find out in a few days.
        SimJim
        If I run the installation, there is allways a error when it wants to install the PocketSphinx.
        What is wrong?
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @SimJim
          @SimJim do you have some more output to provide?
            SimJim
            This is what happens all the time…
            • strawberry 3.141S
              @SimJim i will test this tonight
              • N
                Nonamexp
                I’ve the next problem: On the Mirror shows the message ‘Error’ , ‘No Moduls identified’.
                in the Error Log: Error: spawn pocketsphinx_continuous ENOENT-2
                help me pls ;(
                strawberry 3.141S 2 Replies Last reply
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Nonamexp
                  @Nonamexp as I said due to installing in root directory the binary will not be found
                  @SimJim Error code 56 indicates a curl receive error of CURLE_RECV_ERROR which means there was some issue that prevented the data from being received during the clone process. Typically this is caused by a network setting, firewall, VPN client, or anti-virus that is terminating the connection before all data has been transferred. It’s not related to this module this is something general
                    daveyg_71 @cowboysdude
                    @cowboysdude I got the new mic, and the pi can see it now, but the mirror is showing error next to the microphone.
                    Is there anything wrong with my config file?
                                                module: 'MMM-voice',
                                                position: 'bottom_bar',
                                                        microphone: 1,
                                                        keyword: 'MAGIC MIRROR',
                                                        timeout: 15,
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @daveyg_71
                      @daveyg_71 there is an error log in the mmm-voice directory can you post it? and do you get any errors in the terminal or electron console?
                      cowboysdudeC D 2 Replies Last reply
                      • cowboysdudeC
                        cowboysdude Module Developer @strawberry 3.141
                        @strawberry-3.141 said in MMM-voice:
                        What please do what @strawberry-3-141 said :) Look in the directory for an error log… or when you start your mirror run it in dev mode: npm start dev
                          @strawberry-3.141 I opened up the error log and this is all I see:
                          1271271271271111111111111111
                          The mirror starts up with no problems. It just says error next to the microphone symbol.
                          • O
                            ostfilinchen
                            i have sometimes the same error. Do u have restart the mirror via pm2 restart mm?
                              darrene
                              Hi @strawberry-3.141, I’ve just tried running the dependencies.sh from the latest .git to install MMM-voice and hit this error in step 5;
                              [STEP 5/6] Installing npm dependencies
                              dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                              npm WARN enoent ENOENT: no such file or directory, open ‘/root/pocketsphinx/package.json’
                              despite the fact that pocketsphinx seemed to come down and compile okay. I’m logged in as the pi user via ssh and ran the shell script with sudo bash dependancies.sh.
                              Do you have any suggestions as to what’s happened?
                              many thanks
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @darrene
                                @darrene yes dont run the script with sudo. as you can see it tries to install and look for files in root instead of home pi
                                D 1 Reply Last reply
                                  darrene @strawberry 3.141
                                  @strawberry-3.141 Doh! Thank you :)
                                    darrene
                                    Hmm, I too am getting the ‘Error’ mic icon message, once it finishes its initialisation phase when the mirror starts up.
                                    I’m started in dev mode - both the web and terminal consoles look clean - the last report I have in the terminal is 'MMM-voice: Starting pocketsphinx, so I don’t know if I should expect anything further messages in that console.
                                    I’ve taken a look in the MMM-voice/error.log which contains the value ‘127’. It’s repeatable - if i stop the mirror, remove the error log and restart, I get the same results. As a test I’ve tried altering the microphone value in the config.js from it’s initially correct value of 1 - It doesn’t affect the error, which leads me to believe it may not be a hardware issue(?)
                                    It’s such a shame - all steps reported to have completed okay, the microphone was detected - nothing looks to have been out of the ordinary.
                                    Is there anything else I can do to test or anywhere else I can look, before I try flattening the SD card and reinstalling?
                                      darrene @darrene
                                      progress of a sort…
                                      tried a sudo apt-get update, followed by a reboot
                                      same clean startups but between the ‘initialising’ and ‘error’ states I briefly get a ‘no mode found’ and the 127 error is gone - now I just get a 1 returned in the error log
                                      • strawberry 3.141S
                                        @darrene no Mode found is the expected behaviour, you can also Enable debug:true this will give You an debug log
                                          @strawberry-3.141 Thanks for following this up. That debug switch is a handy one to know :)
                                          I’m now running with debug enabled and pouring over the debug log. Forcing a revisit of that portion of the config.js was the best thing I could have done - I realised that I’d left my Microphone testing value set incorrectly before catching some sleep.
                                          Now that I’ve reset that to ‘1’ - my actual microphone value, as reported by the installer, I no longer get an error.log generated or the onscreen error icon - just the No Mode Detected which is the resting state without debug and an additional ‘undefined’ with debug
                                          This leads me to believe my problem is a Raspian/hardware one, rather than with the module - If I go into the audio device settings in the desktop, I can see my Logitech USB microphone (ALSA mixer) in the selectable sound cards but am unable to make it the default, which stays as bcm2835 ALSA.
                                          If I try arecord to test the mic from the terminal, I get
                                          “arecord: main:682: audio open error No such file or directory”
                                          however, if I use 'arecord -D plughw:1,0 test.wav
                                          I get a great wav file recording. Could this be related in some way? I don’t know enough about the code to poke around for the microphone details at this level, to figure out how the installer maps the input device values
                                          • strawberry 3.141S
                                            @darrene you’re all good. just try to say your keyword and voice. then you switch from no mode detected to voice mode
                                            i will propably change that message because you’re not the first one who is confused about no mode detected
                                            Everyone can send me private messages to debug this module when he/she has a problem, we will then post the result here for everyone.
                                            To sum up from the private messages I receive, I see a lot of people having issues, because they run the installer multiple times. Make sure you remove ~/MagicMirror/modules/MMM-voice/node_modules, before you run the installer script again.
                                            • 16
                                            • 17
                                            • 2 / 17
