    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 20.4k Views 4 Watching
      Darkmx-6
      Yeah I can’t get it to come up.
      I’m not sure what else I can do.
        sdetweil @Darkmx-6
        @Darkmx-6 if u can change the startup, npm start dev opens the developers window
        D 2 Replies Last reply
          Darkmx-6 @sdetweil
          I am trying a clean install now
            Darkmx-6 @sdetweil
            is this the start file you are talking about?
            pi@raspberrypi:~ $ ls
            chromium_start.sh  mmstart.sh                  package-lock.json
            MagicMirror        node-v10.16.0-linux-armv6l
            pi@raspberrypi:~ $
            mmstart.sh?
            pi@raspberrypi:~ $ sudo nano mmstart.sh
              GNU nano 3.2                       mmstart.sh
            #!/bin/bash
            node serveronly &
            sleep 30
            xinit /home/pi/chromium_start.sh
            npm start dev
            Is that where it goes?
            Man doing this project makes me feel so dumb I need to learn more, any suggestions?
              Darkmx-6
              Oh an just to update with the clean install I had the same issue.
                Darkmx-6
                I am also now using a Raspberry Pi 3 B+
                  Darkmx-6
                  Well I ended up going to a static picture because I can’t think of what else to do.
                    sdetweil @Darkmx-6
                    @Darkmx-6 i don’t know where mmstart.sh came from… it is not part of the base MagicMirror solution.
                    the MagicMirror start script is ~/MagicMirror/installers/mm.sh
                    it does not run serveronly… it assumes you are running the mirror user experience ON the same machine.
                    i don’t know if EasyBack works on the remote client of serveronly… THAT browser would have to enable autoplay… our fix was for the electron browser running ON the same machine
                    edit:
                    ok, i see what you are doing… using chromium for the browser for some reason…
                    so u have to disable the autoplay blocker there , from
                    https://developers.google.com/web/updates/2017/09/autoplay-policy-changes
                    You can decide to disable entirely the autoplay policy by setting the
                    Chrome flag "Autoplay Policy" to "No user gesture is required" at chrome://flags/#autoplay-policy.
                    This allows you to test your website as if user were strongly engaged with your site and playback autoplay would be always allowed.
                    Reply Quote 2
                      Darkmx-6
                      Ah I see! It works THANK YOU!
                      Must be because of the pre-made image I installed MagicMirror with.
                      Here is the link:
                      http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                      Here is the fix:
                      I edited the file chromium_start.sh found here:
                      chromium_start.sh  MagicMirror  mmstart.sh  node-v10.16.0-linux-armv6l  package-lock.json
                      and added
                      --autoplay-policy=no-user-gesture-required
                      Example:
                        GNU nano 3.2                          chromium_start.sh
                      #!/bin/sh
                      unclutter &
                      xset -dpms # disable DPMS (Energy Star) features.
                      xset s off # disable screen saver
                      xset s noblank # don’t blank the video device
                      matchbox-window-manager &
                      #midori -e Fullscreen -a http://localhost:8080
                      chromium-browser --autoplay-policy=no-user-gesture-required --incognito --kiosk http://localhost:8080/
                      S Mykle1M 2 Replies Last reply
                        sdetweil @Darkmx-6
                        @Darkmx-6 cool!.. great feedback, thanks we missed that this was a pi0, and that you were running split mode…
                          Darkmx-6
                          @sdetweil said in MMM-EasyBack no autostart Video:
                          what is split mode? If I am I didn’t mean to, I have it directly connected to a TV that I am using as a Bulletin board.
                            sdetweil @Darkmx-6
                            @Darkmx-6 there are two ways to run Magic Mirror
                            all in one(all in one application) , uses electron, npm start.
                            we’ve solved the pi 0 problem… my installer handles it
                            split mode (two applications)
                            start serverOnly
                            then view with some other browser (chrome, firefox, ie, …) either locally or from another machine/phone…
                            Mykle1M 1 Reply Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Darkmx-6
                              @Darkmx-6 said in MMM-EasyBack no autostart Video:
                              Here is the fix:
                              I added your fix for Chromium to the readme. Many thanks, Mate. :thumbsup:
                              https://github.com/mykle1/MMM-EasyBack/blob/master/README.md
                              • Mykle1M
                                And Sam, my thanks, again. :-)
                                D 1 Reply Last reply
                                  Darkmx-6
                                  No, I thank you! I took a bit, but I’m happy with this!
                                    Darkmx-6 @Mykle1
                                    @Mykle1
                                    In the readme you should really give the thanks to sdetweil , he’s the one who basically gave me the answer.
                                    • Mykle1M
                                      In the readme you should really give the thanks to @sdetweil
                                      Ahh, him again? :-)
                                      Done!
