    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 19.9k Views 4 Watching
      Darkmx-6
      yep, like if I’m hitting ctrl + alt + delete correct?
      instead it’s ctrl shift i
        sdetweil @Darkmx-6
        @Darkmx-6 correct
          Darkmx-6
          Yeah I can’t get it to come up.
          I’m not sure what else I can do.
            sdetweil @Darkmx-6
            @Darkmx-6 if u can change the startup, npm start dev opens the developers window
              Darkmx-6 @sdetweil
              I am trying a clean install now
                Darkmx-6 @sdetweil
                is this the start file you are talking about?
                pi@raspberrypi:~ $ ls
                chromium_start.sh  mmstart.sh                  package-lock.json
                MagicMirror        node-v10.16.0-linux-armv6l
                pi@raspberrypi:~ $
                mmstart.sh?
                pi@raspberrypi:~ $ sudo nano mmstart.sh
                  GNU nano 3.2                       mmstart.sh
                #!/bin/bash
                node serveronly &
                sleep 30
                xinit /home/pi/chromium_start.sh
                npm start dev
                Is that where it goes?
                Man doing this project makes me feel so dumb I need to learn more, any suggestions?
                  Darkmx-6
                  Oh an just to update with the clean install I had the same issue.
                    Darkmx-6
                    I am also now using a Raspberry Pi 3 B+
                      Darkmx-6
                      Well I ended up going to a static picture because I can’t think of what else to do.
                        sdetweil @Darkmx-6
                        @Darkmx-6 i don’t know where mmstart.sh came from… it is not part of the base MagicMirror solution.
                        the MagicMirror start script is ~/MagicMirror/installers/mm.sh
                        it does not run serveronly… it assumes you are running the mirror user experience ON the same machine.
                        i don’t know if EasyBack works on the remote client of serveronly… THAT browser would have to enable autoplay… our fix was for the electron browser running ON the same machine
                        edit:
                        ok, i see what you are doing… using chromium for the browser for some reason…
                        so u have to disable the autoplay blocker there , from
                        https://developers.google.com/web/updates/2017/09/autoplay-policy-changes
                        You can decide to disable entirely the autoplay policy by setting the
                        Chrome flag "Autoplay Policy" to "No user gesture is required" at chrome://flags/#autoplay-policy.
                        This allows you to test your website as if user were strongly engaged with your site and playback autoplay would be always allowed.
                          Darkmx-6
                          Ah I see! It works THANK YOU!
                          Must be because of the pre-made image I installed MagicMirror with.
                          Here is the link:
                          http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                          Here is the fix:
                          I edited the file chromium_start.sh found here:
                          chromium_start.sh  MagicMirror  mmstart.sh  node-v10.16.0-linux-armv6l  package-lock.json
                          and added
                          --autoplay-policy=no-user-gesture-required
                          Example:
                            GNU nano 3.2                          chromium_start.sh
                          #!/bin/sh
                          unclutter &
                          xset -dpms # disable DPMS (Energy Star) features.
                          xset s off # disable screen saver
                          xset s noblank # don’t blank the video device
                          matchbox-window-manager &
                          #midori -e Fullscreen -a http://localhost:8080
                          chromium-browser --autoplay-policy=no-user-gesture-required --incognito --kiosk http://localhost:8080/
                          S Mykle1M 2 Replies Last reply Reply Quote 1
                            sdetweil @Darkmx-6
                            @Darkmx-6 cool!.. great feedback, thanks we missed that this was a pi0, and that you were running split mode…
                              Darkmx-6
                              @sdetweil said in MMM-EasyBack no autostart Video:
                              what is split mode? If I am I didn’t mean to, I have it directly connected to a TV that I am using as a Bulletin board.
                                sdetweil @Darkmx-6
                                @Darkmx-6 there are two ways to run Magic Mirror
                                all in one(all in one application) , uses electron, npm start.
                                we’ve solved the pi 0 problem… my installer handles it
                                split mode (two applications)
                                start serverOnly
                                then view with some other browser (chrome, firefox, ie, …) either locally or from another machine/phone…
                                  Mykle1 Project Sponsor Module Developer @Darkmx-6
                                  @Darkmx-6 said in MMM-EasyBack no autostart Video:
                                  Here is the fix:
                                  I added your fix for Chromium to the readme. Many thanks, Mate. :thumbsup:
                                  https://github.com/mykle1/MMM-EasyBack/blob/master/README.md
                                    And Sam, my thanks, again. :-)
                                      Darkmx-6
                                      No, I thank you! I took a bit, but I’m happy with this!
                                        Darkmx-6 @Mykle1
                                        @Mykle1
                                        In the readme you should really give the thanks to sdetweil , he’s the one who basically gave me the answer.
                                          In the readme you should really give the thanks to @sdetweil
                                          Ahh, him again? :-)
                                          Done!
