    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 19.9k Views 4 Watching
      sdetweil @Darkmx-6
      @Darkmx-6 i don’t know where mmstart.sh came from… it is not part of the base MagicMirror solution.
      the MagicMirror start script is ~/MagicMirror/installers/mm.sh
      it does not run serveronly… it assumes you are running the mirror user experience ON the same machine.
      i don’t know if EasyBack works on the remote client of serveronly… THAT browser would have to enable autoplay… our fix was for the electron browser running ON the same machine
      edit:
      ok, i see what you are doing… using chromium for the browser for some reason…
      so u have to disable the autoplay blocker there , from
      https://developers.google.com/web/updates/2017/09/autoplay-policy-changes
      You can decide to disable entirely the autoplay policy by setting the
      Chrome flag "Autoplay Policy" to "No user gesture is required" at chrome://flags/#autoplay-policy.
      This allows you to test your website as if user were strongly engaged with your site and playback autoplay would be always allowed.
        Darkmx-6
        Ah I see! It works THANK YOU!
        Must be because of the pre-made image I installed MagicMirror with.
        Here is the link:
        http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
        Here is the fix:
        I edited the file chromium_start.sh found here:
        pi@raspberrypi:~ $ ls
        chromium_start.sh  MagicMirror  mmstart.sh  node-v10.16.0-linux-armv6l  package-lock.json
        and added
        --autoplay-policy=no-user-gesture-required
        Example:
          GNU nano 3.2                          chromium_start.sh
        #!/bin/sh
        unclutter &
        xset -dpms # disable DPMS (Energy Star) features.
        xset s off # disable screen saver
        xset s noblank # don’t blank the video device
        matchbox-window-manager &
        #midori -e Fullscreen -a http://localhost:8080
        chromium-browser --autoplay-policy=no-user-gesture-required --incognito --kiosk http://localhost:8080/
        S Mykle1M 2 Replies Last reply Reply Quote 1
          sdetweil @Darkmx-6
          @Darkmx-6 cool!.. great feedback, thanks we missed that this was a pi0, and that you were running split mode…
            Darkmx-6
            @sdetweil said in MMM-EasyBack no autostart Video:
            what is split mode? If I am I didn’t mean to, I have it directly connected to a TV that I am using as a Bulletin board.
              sdetweil @Darkmx-6
              @Darkmx-6 there are two ways to run Magic Mirror
              all in one(all in one application) , uses electron, npm start.
              we’ve solved the pi 0 problem… my installer handles it
              split mode (two applications)
              start serverOnly
              then view with some other browser (chrome, firefox, ie, …) either locally or from another machine/phone…
                Mykle1 Project Sponsor Module Developer @Darkmx-6
                @Darkmx-6 said in MMM-EasyBack no autostart Video:
                Here is the fix:
                I added your fix for Chromium to the readme. Many thanks, Mate. :thumbsup:
                https://github.com/mykle1/MMM-EasyBack/blob/master/README.md
                  And Sam, my thanks, again. :-)
                    Darkmx-6
                    No, I thank you! I took a bit, but I’m happy with this!
                      Darkmx-6 @Mykle1
                      @Mykle1
                      In the readme you should really give the thanks to sdetweil , he’s the one who basically gave me the answer.
                        In the readme you should really give the thanks to @sdetweil
                        Ahh, him again? :-)
                        Done!
