    328 Posts 27 Posters 706.0k Views 24 Watching
      bhepler Module Developer @sdetweil
      @sdetweil - Hmm. Curious. Test run of the script looked good. Added the apply keyword and I’m getting a git error.
      any *-lock.json files do not need to be saved
      do you want to save these files for later   (Y/n)?n
      fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
      Another git process seems to be running in this repository, e.g.
      an editor opened by 'git commit'. Please make sure all processes
      are terminated then try again. If it still fails, a git process
      may have crashed in this repository earlier:
      remove the file manually to continue.
      there were merge errors
      you should examine and resolve them
      using the command git log --oneline --decorate
      a31546b (HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
      Then a bunch of commit statements. There is no git process running at the moment, but that index.lock file does exist. After deleting that file, it worked like a charm. Thanks!
        sdetweil @bhepler
        @bhepler said in new update/upgrade script, ready for testing:
        to git that means it is already running… on exit it cleans up…
        should I add handling this error to the script?
        I can tell if its there and git is not running.
        great feedback… thanks
          sdetweil @bhepler
          @bhepler i added handling for the git lock file…
          if git is NOT running, I erase the dangling lock file
          if git IS running, and this is an APPLY run, i change the run back to test mode, and advise to correct the problem
            I just did another run of your upgrade script, Sam. All went well.
            MM 2.8.0 --> 2.9.0
            Ubuntu 16.04.6 (downgraded from 18.04)
              sdetweil @Mykle1
              @Mykle1 on the 1st run, no modules were updated… there should have been a message in the log… i didn’t see it… did u see any this time??
                Sorry, I was distracted here, Sam. I just emailed you the upgrade.log
                  sdetweil @Mykle1
                  @Mykle1 thanks… they(last night and today) actually look good
                  i did make one change, the merge results generated one LONE line… i added some formatting to make it readable
                    sdetweil @Mykle1
                    @Mykle1 well, there is installed modules, and there is active modules…
                    i only update the ACTIVE (ie, not disabled: true) modules with package.json files
                      Understood. :thumbsup:
                        bobwilliams
                        for some reason, it updates me to version 2.8.0, although it seems like version 2.9.0 has already been released.
                        MagicMirror installation successful!
                        magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                        cd fonts && npm install
                          sdetweil @bobwilliams
                          @bobwilliams can you show me the MagicMirror/installers/upgrade.log
                          or send it to me mail, same userid as here on gmail, thanks
                            bobwilliams
                            Upgrade started - Sun Oct 6 11:26:51 +05 2019
                            user requested to apply changes
                            doing test run = false
                            saving custom.css
                            remote name = origin
                            upgrading from version 2.8.0 to 2.9.0
                            fetching latest revisions
                            current branch = master
                            there are 7 local files that are different than the master repo
                            installers/mm.sh
                            modules/default/calendar/calendar.js
                            modules/default/currentweather/currentweather.js
                            modules/default/weather/weather.js
                            modules/default/weatherforecast/weatherforecast.js
                            package-lock.json
                            run-start.sh
                            save/restore files selection = y
                            test merge result rc=‘’ if empty, no conflicts
                            executing merge, apply specified
                            merge result rc= 0n Updating a31546b…500147e
                            magicmirror@2.8.0 install /home/pi/MagicMirror
                            cd vendor && npm install
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                            audited 220 packages in 53.517s
                            found 5 vulnerabilities (4 low, 1 high)
                            run npm audit fix to fix them, or npm audit for details
                            magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                            sh installers/postinstall/postinstall.sh && npm run install-fonts
                            ^[[32mMagicMirror installation successful!
                            audited 1 package in 3.78s
                            found 0 vulnerabilities
                            npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                            audited 3573 packages in 310.648s
                            found 16 vulnerabilities (1 moderate, 15 high)
                            processing for module MMM-WeeklySchedule please wait
                            audited 1 package in 3.297s
                            processing complete for module MMM-WeeklySchedule
                            processing for module MMM-MyPrayerTimes please wait
                            audited 3 packages in 4.211s
                            processing complete for module MMM-MyPrayerTimes
                            restoring custom.css
                            we stashed a set of files that appear changed from the latest repo versions. you should review them
                                @bobwilliams do a git pull, and show the results…
                                looks like git lied on the return code of the merge…
                                lets try the output of this
                                git merge-tree `git merge-base master HEAD` HEAD master
                                thanks
                                  bobwilliams
                                  no change … I’m a simple user so don’t judge strictly
                                    @bobwilliams no judging… my script should help with this
                                    just gotta understand it…
                                    the output of those two commands is the same?
                                    then
                                    git pull
                                      bobwilliams
                                      @sdetweil said in new update/upgrade script, ready for testing:
                                      git pull
                                      pi@raspberrypi:~/MagicMirror $ git merge-tree git merge-base master HEAD HEAD master
                                      pi@raspberrypi:~/MagicMirror $ git pull
                                      error: Your local changes to the following files would be overwritten by merge:
                                      package-lock.json
                                      run-start.sh
                                      Please commit your changes or stash them before you merge.
                                      Aborting
                                        @bobwilliams said in new update/upgrade script, ready for testing:
                                        there were two little backtics (left of 1 on us keyboard)
                                        replace backtic in the next command with that keyboard character
                                         git merge-tree backtic git merge-base master HEAD backtic HEAD master
                                        git pull results hm… we did a stash, why are those files still listed
                                        try some more
                                        git stash show
                                        git stash
                                        git pull
                                          bobwilliams
                                          pi@raspberrypi:~/MagicMirror $ git merge-tree ~ git merge-base master HEAD ~ HEAD master
                                          usage: git merge-tree
                                          pi@raspberrypi:~/MagicMirror $ git stash show
                                          No stash entries found.
                                          *** Please tell me who you are.
                                          Run
                                          git config --global user.email “you@example.com”
                                          git config --global user.name “Your Name”
                                          to set your account’s default identity.
                                          Omit --global to set the identity only in this repository.
                                          fatal: unable to auto-detect email address (got ‘pi@raspberrypi.(none)’)
                                          Cannot save the current index state
                                          package-lock.json
                                          run-start.sh
                                          Aborting
                                            @bobwilliams great!!.. let me see what I can do about that…
                                            also ~ git , that is the tilde character, i need the single quote leaning to the left (backtic), same keyboard key for me, just not with shift
                                            • 16
                                            • 17
                                            • 4 / 17
