    MMM-EventHorizon
    Scheduled Pinned Locked Moved Fun & Games
    41 Posts 8 Posters 27.4k Views 8 Watching
      Mykle1 Project Sponsor Module Developer @Hein-Jan
      @hein-jan
      You could do that or you could make it your own. Feel free to make any edits that please you. Ah, the beauty of open source. :-) Have fun.
        Update:
        [card:mykle1/MMM-EventHorizon]
        Version 1.0.1
        Thanks to @spitzlbergerj for taking the initiative here. He posted an issue at the repo which included the modificatons so I wanted him to get the credit and my thanks.
        Now you can color text line by line AND use any city you like as the timezone.
        git pull or install as per the readme
          Update:
          Version update 1.0.2
          Added an option for unit designation
          1. No units
          2. D H M S
          3. Day Hr Min Sec
          4. Days Hrs Mins Secs
          5. Days Hours Minutes Seconds (Full names)
          Example of option 1 and 2
          0_1548380952908_Screenshot from 2019-01-24 19-13-00.png - 0_1548381184316_wert.png
          swvalentiS 1 Reply Last reply Reply Quote 2
          • swvalentiS Offline
            swvalenti Project Sponsor @Mykle1
            @Mykle1 Any way to add years to this? I retire in 2515 days, but would like to know years then days. HA! I keep having to fn pull out the calculator to convert.
            Thanks ahead if this can be done!
            Regards, Scott
            Mykle1M 3 Replies Last reply Reply Quote 0
              Mykle1 Project Sponsor Module Developer @swvalenti
              @swvalenti
              Scott,
              I’m terribly sorry but this module doesn’t use a conventional api data source which would have allowed me to do the computations on the data. Thus, converting all those days to years. It’s simply using an iFrame and tapping in to this web site. You can see on the site that “days” is not an option. My apologies.
              Peace!
                @swvalenti
                Hey Scott,
                You could try this module. It shows just the days remaining.
                https://forum.magicmirror.builders/topic/1846/mmm-doomsday-the-countdown-module
                swvalentiS 1 Reply Last reply Reply Quote 0
                  @Mykle1 said in MMM-EventHorizon:
                  @swvalenti
                  Hey Scott,
                  I will give that a go thank you sir.
                    @swvalenti
                    Upon further inspection of the site I found that “Show Days Only” is an option. Sorry I missed it the first time. If you would not mind trying it out and reporting back to me I would be grateful. I updated the repo. Note: New config option.
                      Update:
                      Version update 1.0.3
                      Added an option to display only days remaining, as per request by @swvalenti.
                      Do a git pull in the MMM-EventHorizon directory or install as per the readme.
                      swvalentiS 1 Reply Last reply Reply Quote 1
                        @Mykle1 doing something wrong when added justDays, now a config error shows…ideas?
                        	disabled: false,
                        	module: 'MMM-EventHorizon',
                        	position: 'top_left',
                            	timezone: "n2268",                     // See Timezone chart at bottom
                        	justDays: “yes”,
                            	size: "large",                        // small, medium or large
                            	countUp: "yes",                       // Count up after timer ends
                            	date: "2026-09-04",                   // YYYY-MM-DD format ONLY
                            	time: "23:59:59",                     // (HH:MM:SS)    Exact time you want timer to end
                            	text1: "Until Retirement",         // 2 lines of text during timer
                            	text2: "Bitches!",               // 2 lines of text during timer
                            	text1Color: "4169E1",                 // Hex color codes
                            	text2Color: "C0C0C0",                 // Hex color codes
                            	timerColor: "FFFFFF",                 // Hex color codes
                            	endText1: "When timer ends",          // 2 lines of text when timer ends
                            	endText2: "Say something here",       // 2 lines of text when timer ends
                            	endText1Color: "FFFFFF",              // Hex color codes
                            	endText2Color: "62FF00",              // Hex color codes
                            	timerUpColor: "FFFFFF",               // Hex color codes
                            	colorpc: "000",                       // color of the background 000 = black, t = transparent
                          sdetweil @swvalenti
                          @swvalenti Wrong double quote characters. Type it from the keyboard, not cut/paste
                            swvalenti Project Sponsor @sdetweil
                            @sdetweil said in MMM-EventHorizon:
                            I’m an idiot thank you sir that fixed it. Thanks @Mykle1 for the quick update! You guys rock.
                              @swvalenti said in MMM-EventHorizon:
                              You’re welcome, mate. Turned out to be a rather easy update. I’m glad you suggested it because now the module has more, better options and should appeal to more users.
                                Ok, I meant there was no “YEARS” option. justDays option was the best I could do for you as the site does not offer that option.
                                • BKeyportB Offline
                                  BKeyport Module Developer
                                  Hey, Mykle,
                                  I’ve got EventHorizon jumping out of it’s box when it’s grouped with other modules.
                                  When it’s by itself, It’s fine.
                                  Any clues?
                                    Mykle1 Project Sponsor Module Developer @BKeyport
                                    @BKeyport said in MMM-EventHorizon:
                                    Any clues?
                                    css? I think I set that up that way for my personal use. Give the css file a look.
                                    • BKeyportB Offline
                                      BKeyport Module Developer @Mykle1
                                      @Mykle1 Yeah, it was the right-margin.
                                      it was set to -120px, and in my case I need to have it at -40px.
                                      thanks for the clue.
                                        @Mykle1 Yo brother is there anyway to add to the code to subtract weekends and number of holidays?
                                          @swvalenti
                                          It’s an iframe module which means, in this case, you only have access to certain elements. Manipulating the return can only be done to those elements. What you’re asking for is not one of the elements available and is done automatically by the site where the data is coming from.
                                          Then again, I’m really just a hobbyist programmer. There may be a way that is beyond my simple knowledge. Feel free to fork the module and experiment to your liking.
                                          Peace bro.
                                            Is it possible to reverse the date on top and the text on bottom? See image to what I mean…thanks!
                                            ![0_1630267750641_Capture.PNG](Uploading 100%)
                                            • 2 / 3
