    MMM-EventHorizon
    Scheduled Pinned Locked Moved Fun & Games
    41 Posts 8 Posters 33.0k Views 8 Watching
      Mykle1 Project Sponsor Module Developer @swvalenti
      @swvalenti
      Hey Scott,
      You could try this module. It shows just the days remaining.
      https://forum.magicmirror.builders/topic/1846/mmm-doomsday-the-countdown-module
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @Mykle1
        @Mykle1 said in MMM-EventHorizon:
        @swvalenti
        Hey Scott,
        I will give that a go thank you sir.
          @swvalenti
          Upon further inspection of the site I found that “Show Days Only” is an option. Sorry I missed it the first time. If you would not mind trying it out and reporting back to me I would be grateful. I updated the repo. Note: New config option.
            Update:
            [card:mykle1/MMM-EventHorizon]
            Version update 1.0.3
            Added an option to display only days remaining, as per request by @swvalenti.
            Do a git pull in the MMM-EventHorizon directory or install as per the readme.
            swvalentiS 1 Reply Last reply Reply Quote 1
              @Mykle1 doing something wrong when added justDays, now a config error shows…ideas?
              	disabled: false,
              	module: 'MMM-EventHorizon',
              	position: 'top_left',
                  	timezone: "n2268",                     // See Timezone chart at bottom
              	justDays: “yes”,
                  	size: "large",                        // small, medium or large
                  	countUp: "yes",                       // Count up after timer ends
                  	date: "2026-09-04",                   // YYYY-MM-DD format ONLY
                  	time: "23:59:59",                     // (HH:MM:SS)    Exact time you want timer to end
                  	text1: "Until Retirement",         // 2 lines of text during timer
                  	text2: "Bitches!",               // 2 lines of text during timer
                  	text1Color: "4169E1",                 // Hex color codes
                  	text2Color: "C0C0C0",                 // Hex color codes
                  	timerColor: "FFFFFF",                 // Hex color codes
                  	endText1: "When timer ends",          // 2 lines of text when timer ends
                  	endText2: "Say something here",       // 2 lines of text when timer ends
                  	endText1Color: "FFFFFF",              // Hex color codes
                  	endText2Color: "62FF00",              // Hex color codes
                  	timerUpColor: "FFFFFF",               // Hex color codes
                  	colorpc: "000",                       // color of the background 000 = black, t = transparent
                sdetweil @swvalenti
                @swvalenti Wrong double quote characters. Type it from the keyboard, not cut/paste
                swvalentiS 1 Reply Last reply Reply Quote 2
                  swvalenti Project Sponsor @sdetweil
                  @sdetweil said in MMM-EventHorizon:
                  I’m an idiot thank you sir that fixed it. Thanks @Mykle1 for the quick update! You guys rock.
                    @swvalenti said in MMM-EventHorizon:
                    You’re welcome, mate. Turned out to be a rather easy update. I’m glad you suggested it because now the module has more, better options and should appeal to more users.
                      Any way to add years to this?
                      Ok, I meant there was no “YEARS” option. justDays option was the best I could do for you as the site does not offer that option.
                      • BKeyportB Offline
                        BKeyport Module Developer
                        Hey, Mykle,
                        I’ve got EventHorizon jumping out of it’s box when it’s grouped with other modules.
                        When it’s by itself, It’s fine.
                        Any clues?
                          Mykle1 Project Sponsor Module Developer @BKeyport
                          @BKeyport said in MMM-EventHorizon:
                          Any clues?
                          css? I think I set that up that way for my personal use. Give the css file a look.
                          • BKeyportB Offline
                            BKeyport Module Developer @Mykle1
                            @Mykle1 Yeah, it was the right-margin.
                            it was set to -120px, and in my case I need to have it at -40px.
                            thanks for the clue.
                              @Mykle1 Yo brother is there anyway to add to the code to subtract weekends and number of holidays?
                                @swvalenti
                                It’s an iframe module which means, in this case, you only have access to certain elements. Manipulating the return can only be done to those elements. What you’re asking for is not one of the elements available and is done automatically by the site where the data is coming from.
                                Then again, I’m really just a hobbyist programmer. There may be a way that is beyond my simple knowledge. Feel free to fork the module and experiment to your liking.
                                Peace bro.
                                  Is it possible to reverse the date on top and the text on bottom? See image to what I mean…thanks!
                                  ![0_1630267750641_Capture.PNG](Uploading 100%)
                                    swvalenti Project Sponsor @swvalenti
                                    @swvalenti won’t let me attach image but hopefully someone knows what I am trying to convey
                                      sdetweil @swvalenti
                                      @swvalenti u are doing upload photo, not attachment right
                                      third icon from the right, sun over the mountain
                                        I am doing upload image and just says error
                                          sdetweil @swvalenti
                                          @swvalenti how big is the image… I see it fail over 3 meg
                                            @sdetweil only 1.2meg![0_1630268696907_Capture.PNG](Uploading 100%)
                                            • 2 / 3
