    MMM-ISS
    Scheduled Pinned Locked Moved Education
    35 Posts 8 Posters 23.4k Views 9 Watching
      mrdenmark
      is anyone else having problems with this module?i’m getting the following error-
      Error Found
      The Spot The Station widget has encountered a problem. If you are the website curator please visit our widget page for a new version of the embed code.
      Visit the Spot The Station website to see when the International Space Station will be flying over you.
      C Mykle1M 2 Replies Last reply Reply Quote 0
        chassain 0 @mrdenmark
        @mrdenmark said in MMM-ISS:
        Error Found
        I had an error…i live in france…resolved when i put region state: “none”.
          Mykle1 Project Sponsor Module Developer @mrdenmark
          @chassain 0
          This usually happens when there is an error in the config.js entry for this module. country, regionState and city options cannot contain spaces. It is stated in the example config of the repo. This is most common mistake.
          Please post your config entry in a code block.
          Module is working as expected.
            Mykle1 Project Sponsor Module Developer @chassain 0
            @chassain-0 said in MMM-ISS:
            You are absolutely right, sir. The module/widget does accept “None” in the regionState: config option and fixes that issue rather nicely. This is the first I’ve heard of that problem. Thank you for bringing it to my attention. And thanks for the solution. I went to the url and confirmed.
              mrdenmark
              problem solved-it was the none required in state!thanks for the assistance
                Download:
                [card:mykle1/MMM-ISS]
                Update to Version 1.0.1
                Updated module and fixed config so that underscores are no longer necessary in config options country, regionState and city.
                Also, when regionState is not necessary for your location (Ex. Toulon, France), simply leave regionState blank.
                disabled: false,
                module: 'MMM-ISS',
                position: 'middle_center',
                    country: "United States",
                    regionState: "New York",       // Outside USA may not need regionState. If so, leave blank "".
                    city: "New York",
                disabled: false,
                module: 'MMM-ISS',
                    country: "France",
                    regionState: "",       // Outside USA may not need regionState. If so, leave blank "".
                    city: "Toulon",
                  chassain 0
                  Perfect !
                    In case anyone would like to use this module for multiple locations, simply add another config entry.
                      mrdenmark
                      would it be possible to restrict the times it updates? say once an hour during the day and every 30 seconds when sightings are possible?
                        @mrdenmark
                        The default updateInterval is 5 * 60 * 1000 (5 minutes). You can adjust this in your config. As the module only displays the next flyover, setting the updateInterval to 30 seconds would not change the information being displayed by the module. With that, I have no plans to make those changes but you are free to fork the module and make any changes you like.
                          mrdenmark
                          any ideas why the iss module has started displaying like this?-!0_1573028886737_mirror 2 resised.jpg
                          both modules are in lower_third but the same thing happens wherever i move them, if i move iss to bottom_left for instance it will overlap the news feed in bottom_bar
                            @mrdenmark
                            Hmm, until I can see what is going on there you can use something like this in your custom.css file and adjust accordingly.
                            .MMM-ISS {
                              margin-top: 0px;
                              margin-bottom: 0px;
                              margin-left: 0px;
                              margin-right: 0px;
                            and this to move MMM-Aurora
                            .MMM-Aurora {
                              margin-top: 0px;
                              margin-bottom: 0px;
                              margin-left: 0px;
                              margin-right: 0px;
                            I played with mine for a minute and was able to do this. Adjust the values until you are satisfied.
                              mrdenmark
                              the module has recently started telling me there are no sightings for several days but that date has been moving further and further away, anyone have any ideas why?
                                     disabled: false,
                                     module: "MMM-ISS",
                                                 country: "New_Zealand",                  // NO SPACES, USE UNDERSCORE
                                                 regionState: "None",                   // NO SPACES, USE UNDERSCORE
                                                 city: "Queenstown",                            // NO SPACES, USE UNDERSCore
                                                 lat: "-44.57",                              // latitude
                                                 lng: "168.50",                             // longitude
                                                 units: "km",                               // mi = miles, mph / km = kilometers, km/h
                                                 useHeader: false,                          // true if you want a header
                                                 header: "",                                // Any text you want. useHeader must be true
                                                 updateInterval: 5 * 60 * 1000,
                              Mykle1M MoreLinuxM 2 Replies Last reply Reply Quote 0
                                Change of flight path?
                                I tested with your config entry and got the same results as you. Tested with my entry and all is normal. Perhaps you can try with a neighboring city or slightly different lat and long as a further test.
                                  mrdenmark @Mykle1
                                  @Mykle1
                                  i’ve been playing around,i can’t get any nz locations to work but use the same info on the website and its fine,original config also works fine,no idea whats wrong,it worked great up until around 10 days ago.maybe something on the website has changed?
                                  • MoreLinuxM Offline
                                    MoreLinux @mrdenmark
                                    @mrdenmark Queenstown NZ doesn’t have any ISS passes until 30 Nov. 2019, so your mirror might be correct.
                                    You can check it at: https://www.heavens-above.com/PassSummary.aspx?satid=25544&lat=-45.0312&lng=168.6626&loc=Queenstown&alt=0&tz=NZST
                                      mrdenmark @MoreLinux
                                      @MoreLinux
                                      yeah,i guess thats the reason,for some reason i thought visible passe were much more frequent than that
                                      • V Offline
                                        Vauxdvihl
                                        @Mykle1
                                        Thanks for this great module.
                                        Unfortunately i get an error
                                        Error Found
                                        {//MMM-ISS
                                        			disabled: false,
                                        			module: 'MMM-ISS',
                                        			position: 'bottom_left',
                                        				country: "Germany",
                                        				city: "Pöcking",
                                        				lat: "47.9664",                // latitude
                                        				lng: "11.3001",                // longitude
                                        Do you have an idea?
                                        Thanks a lot
                                          Mykle1 Project Sponsor Module Developer @Vauxdvihl
                                          @Vauxdvihl said in MMM-ISS:
                                          Pöcking
                                          Please try, Osterhofen or Deggendorf as your city, whichever is closer. Pöcking and Pocking are not acceptable by the module. Keep in mind, the ISS is not visible everywhere.
                                          You can go to https://spotthestation.nasa.gov/ and find a better location, if there is one.
                                          Peace
                                          • T Offline
                                            timma11 @Mykle1
                                            @Mykle1, Thanks for making these modules. I have 2 of yours installed. Might I suggest adding to the readme that the module can’t use every location and that it can only use ones listed on the findthesation.nasa.gov site.
