    MMM-Celebrations [german only!]
    14 Posts 7 Posters 5.9k Views 7 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      MMM-Celebrations
      This is a MagicMirror module to display today’s celebrations.
      Shows some quite funny celebrations, also with (revolving) explanations.
      Currently only available in German!
      The data is fetched from welcher-tag-ist-heute.org
      Screenshot
      [card:lavolp3/MMM-Celebrations]
      Thanks go out to Chris Erler for his beautiful compilation of celebrations and the detailed explanations!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      StoffbeuteluweS 1 Reply Last reply Reply Quote 1
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @lavolp3
        @lavolp3 Thanks for the nice module …vielen Dank
        • CyruS1337C Offline
          CyruS1337 Project Sponsor
          Oo cool, thank you :) coole Sache, weiter so ;)
            matze86
            Hey lavolp3,
            cooles Modul. Finde es leider nicht auf der “Modul-Seite”. Wo kann man es beziehen?
            VG
            KamiSchamiK 1 Reply Last reply Reply Quote 0
            • KamiSchamiK Offline
              KamiSchami
              Sehr schön :-)
              Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                KamiSchami @matze86
                @matze86 https://github.com/lavolp3/MMM-Celebrations
                  matze86 @KamiSchami
                  @KamiSchami said in MMM-Celebrations [german only!]:
                  Dank dir!
                    KamiSchami
                    How can i center the entire module?
                    • lavolp3L Offline
                      lavolp3 Module Developer @KamiSchami
                      @KamiSchami sorry for the late reply, currently not here very often.
                      Try putting following in your custom.css
                      .MMM-Celebrations {
                          text-align: center
                      O 1 Reply Last reply Reply Quote 1
                      • O Offline
                        OberfragGER @lavolp3
                        @lavolp3
                        When i add this code to the config.js the whole MagicMirror turn black.
                        			module: 'MMM-Celebrations',
                        			position: 'top_left',	// This can be any of the regions. Best results in left or right regions.
                        			header: 'Heute ist:', // This is optional
                        					// You don't need any configuration options currently}
                        Pretty strange. Any ideas?
                        S lavolp3L 2 Replies Last reply Reply Quote 0
                          sdetweil @OberfragGER
                          @oberfragger did u look at the messages in the terminal window where u started mm?
                          npm start. or if you use pm2, then
                          pm2 logs --lines=???
                          where ??? is a number, default 15
                          • lavolp3L Offline
                            lavolp3 Module Developer @OberfragGER
                            @oberfragger can you execute the following in MagicMirror folder:
                            npm run config:check
                            O 2 Replies Last reply Reply Quote 0
                            • O Offline
                              @lavolp3 like i wrote in GitHub… its fixed. My fault.
                              To All: Somehow the installation was broken.
                              • O Offline
                                @lavolp3 Are there any options within the custom.css.
                                I want to have the text on the left side. So i have choosen ‘top_left’ but the text spans till the middle.
                                Any ideas?
                                I made a screenshot and want to have the text in the white boarders.
