    MMM-Celebrations [german only!]
    14 Posts 7 Posters 5.2k Views 7 Watching
      matze86
      Hey lavolp3,
      cooles Modul. Finde es leider nicht auf der “Modul-Seite”. Wo kann man es beziehen?
      VG
      KamiSchamiK 1 Reply Last reply Reply Quote 0
      • KamiSchamiK Offline
        KamiSchami
        Sehr schön :-)
        Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
          KamiSchami @matze86
          @matze86 https://github.com/lavolp3/MMM-Celebrations
            matze86 @KamiSchami
            @KamiSchami said in MMM-Celebrations [german only!]:
            Dank dir!
              KamiSchami
              How can i center the entire module?
              • lavolp3L Offline
                lavolp3 Module Developer @KamiSchami
                @KamiSchami sorry for the late reply, currently not here very often.
                Try putting following in your custom.css
                .MMM-Celebrations {
                    text-align: center
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                O 1 Reply Last reply Reply Quote 1
                • O Offline
                  OberfragGER @lavolp3
                  @lavolp3
                  When i add this code to the config.js the whole MagicMirror turn black.
                  			module: 'MMM-Celebrations',
                  			position: 'top_left',	// This can be any of the regions. Best results in left or right regions.
                  			header: 'Heute ist:', // This is optional
                  					// You don't need any configuration options currently}
                  Pretty strange. Any ideas?
                  S lavolp3L 2 Replies Last reply Reply Quote 0
                    sdetweil @OberfragGER
                    @oberfragger did u look at the messages in the terminal window where u started mm?
                    npm start. or if you use pm2, then
                    pm2 logs --lines=???
                    where ??? is a number, default 15
                    • lavolp3L Offline
                      lavolp3 Module Developer @OberfragGER
                      @oberfragger can you execute the following in MagicMirror folder:
                      npm run config:check
                      O 2 Replies Last reply Reply Quote 0
                      • O Offline
                        @lavolp3 like i wrote in GitHub… its fixed. My fault.
                        To All: Somehow the installation was broken.
