    MMM-Celebrations [german only!]
    14 Posts 7 Posters 5.2k Views 7 Watching
    • KamiSchamiK Offline
      KamiSchami
      Sehr schön :-)
      Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
        KamiSchami @matze86
        @matze86 https://github.com/lavolp3/MMM-Celebrations
          matze86 @KamiSchami
          @KamiSchami said in MMM-Celebrations [german only!]:
          Dank dir!
            KamiSchami
            How can i center the entire module?
            • lavolp3L Offline
              lavolp3 Module Developer @KamiSchami
              @KamiSchami sorry for the late reply, currently not here very often.
              Try putting following in your custom.css
              .MMM-Celebrations {
                  text-align: center
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              O 1 Reply Last reply Reply Quote 1
              • O Offline
                OberfragGER @lavolp3
                @lavolp3
                When i add this code to the config.js the whole MagicMirror turn black.
                			module: 'MMM-Celebrations',
                			position: 'top_left',	// This can be any of the regions. Best results in left or right regions.
                			header: 'Heute ist:', // This is optional
                					// You don't need any configuration options currently}
                Pretty strange. Any ideas?
                S lavolp3L 2 Replies Last reply Reply Quote 0
                  sdetweil @OberfragGER
                  @oberfragger did u look at the messages in the terminal window where u started mm?
                  npm start. or if you use pm2, then
                  pm2 logs --lines=???
                  where ??? is a number, default 15
                  • lavolp3L Offline
                    lavolp3 Module Developer @OberfragGER
                    @oberfragger can you execute the following in MagicMirror folder:
                    npm run config:check
                    O 2 Replies Last reply Reply Quote 0
                    • O Offline
                      @lavolp3 like i wrote in GitHub… its fixed. My fault.
                      To All: Somehow the installation was broken.
                      • O Offline
                        @lavolp3 Are there any options within the custom.css.
                        I want to have the text on the left side. So i have choosen ‘top_left’ but the text spans till the middle.
                        Any ideas?
                        I made a screenshot and want to have the text in the white boarders.
