MMM-Tibber
17 Posts 7 Posters 5.8k Views 7 Watching
  • O Offline
    ottopaulsen
    Show electricity price data from Tibber.
    Tibber customers can see the price per hour for today and tomorrow.
    Screenshot
    See https://github.com/ottopaulsen/MMM-Tibber for more.
    L 1 Reply Last reply Dec 5, 2019, 11:03 AM Reply Quote 3
    • T Offline
      TheGizmo
      Hi @ottopaulsen
      Love that you have created this one! I´m also using tibber at home, and my token works on my Hass.io, but I cannot make it run on my MM. Only error I can see is “No Tibber data”. Got any tips on how to dig into what I have done wrong with my code? I just copied your suggestion for setup and added my access token from Tibber.
      T 1 Reply Last reply Dec 4, 2019, 6:42 PM Reply Quote 0
      • T Offline
        TheGizmo @TheGizmo
        @TheGizmo said in MMM-Tibber:
        Hi @ottopaulsen
        From the error logs:
        ATTENTION: default value of option force_s3tc_enable overridden by environment.
        ReferenceError: log is not defined
        at Class.readTibberPrices (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:34:9)
        at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:26:18)
        at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
        at Socket.emit (events.js:182:13)
        at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
        at process._tickCallback (internal/process/next_tick.js:61:11)
        S 1 Reply Last reply Dec 4, 2019, 6:48 PM Reply Quote 0
          sdetweil @TheGizmo
          looks like the node helper has a typo…
          edit line 34
          change from
                  log("readTibberPrices")
          to this
            this.log("readTibberPrices")
          line 44 is correct
          T 1 Reply Last reply Dec 4, 2019, 9:43 PM Reply Quote 0
          • T Offline
            TheGizmo @sdetweil
            @sdetweil Thx for looking into this, changed and still the same.
            Error from log:
            Error getting tibber prices: TypeError: Cannot read property ‘viewer’ of null
            at rp.then.res (/home/pi/MagicMirror/modules/MMM-Tibber/tibber.js:51:35)
            at tryCatcher (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/util.js:16:23)
            at Promise._settlePromiseFromHandler (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:547:31)
            at Promise._settlePromise (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:604:18)
            at Promise._settlePromise0 (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:649:10)
            at Promise._settlePromises (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:729:18)
            at _drainQueueStep (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:93:12)
            at _drainQueue (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:86:9)
            at Async._drainQueues (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:102:5)
            at Immediate.Async.drainQueues [as _onImmediate] (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:15:14)
            at runCallback (timers.js:696:18)
            at tryOnImmediate (timers.js:667:5)
            at processImmediate (timers.js:649:5)
            S 1 Reply Last reply Dec 5, 2019, 1:38 PM Reply Quote 0
              retroflex Project Sponsor Module Developer
              Really cool! Makes me want to switch to Tibber myself.
              One idea… doesn’t Tibber provide your real time consumption as well? Couldn’t that be included?
              T 1 Reply Last reply Dec 5, 2019, 11:50 AM Reply Quote 0
              • L Offline
                lavolp3 Module Developer @ottopaulsen
                @ottopaulsen Looks impressive. I see that you’re using highcharts for the chart. Is that free to use?
                I only see “buy” buttons on their page.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • T Offline
                  TheGizmo @retroflex
                  @retroflex yes they do, if you have their puls addon. I do, and it works in Home Assistant. I started to look into how I can use one addon to read from HA (not a developer, more visionary guy)
                    sdetweil @TheGizmo
                    no… now the api is returning and error that the code is not handling…
                    • T Offline
                      TheGizmo
                      I have digged more into this, and I cannot see that the module asks Tibber for data at all, (Using Pi-Hole at home) and there are no requests towards Tibber domain.
                      S 1 Reply Last reply Dec 8, 2019, 12:56 PM Reply Quote 0
