    MMM-Tibber
    17 Posts 7 Posters 9.1k Views 7 Watching
    • T
      TheGizmo @TheGizmo
      @TheGizmo said in MMM-Tibber:
      Hi @ottopaulsen
      Love that you have created this one! I´m also using tibber at home, and my token works on my Hass.io, but I cannot make it run on my MM. Only error I can see is “No Tibber data”. Got any tips on how to dig into what I have done wrong with my code? I just copied your suggestion for setup and added my access token from Tibber.
      From the error logs:
      ATTENTION: default value of option force_s3tc_enable overridden by environment.
      ReferenceError: log is not defined
      at Class.readTibberPrices (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:34:9)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:26:18)
      at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
      at Socket.emit (events.js:182:13)
      at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
      at process._tickCallback (internal/process/next_tick.js:61:11)
        sdetweil @TheGizmo
        looks like the node helper has a typo…
        edit line 34
        change from
                log("readTibberPrices")
        to this
          this.log("readTibberPrices")
        line 44 is correct
        T 1 Reply Last reply
        • T
          TheGizmo @sdetweil
          @sdetweil Thx for looking into this, changed and still the same.
          Error from log:
          Error getting tibber prices: TypeError: Cannot read property ‘viewer’ of null
          at rp.then.res (/home/pi/MagicMirror/modules/MMM-Tibber/tibber.js:51:35)
          at tryCatcher (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/util.js:16:23)
          at Promise._settlePromiseFromHandler (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:547:31)
          at Promise._settlePromise (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:604:18)
          at Promise._settlePromise0 (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:649:10)
          at Promise._settlePromises (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:729:18)
          at _drainQueueStep (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:93:12)
          at _drainQueue (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:86:9)
          at Async._drainQueues (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:102:5)
          at Immediate.Async.drainQueues [as _onImmediate] (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:15:14)
          at runCallback (timers.js:696:18)
          at tryOnImmediate (timers.js:667:5)
          at processImmediate (timers.js:649:5)
            retroflex Project Sponsor Module Developer
            Really cool! Makes me want to switch to Tibber myself.
            One idea… doesn’t Tibber provide your real time consumption as well? Couldn’t that be included?
            • lavolp3L
              lavolp3 Module Developer @ottopaulsen
              @ottopaulsen Looks impressive. I see that you’re using highcharts for the chart. Is that free to use?
              I only see “buy” buttons on their page.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • T
                TheGizmo @retroflex
                @retroflex yes they do, if you have their puls addon. I do, and it works in Home Assistant. I started to look into how I can use one addon to read from HA (not a developer, more visionary guy)
                  sdetweil @TheGizmo
                  no… now the api is returning and error that the code is not handling…
                  • T
                    TheGizmo
                    I have digged more into this, and I cannot see that the module asks Tibber for data at all, (Using Pi-Hole at home) and there are no requests towards Tibber domain.
                      sdetweil @TheGizmo
                      @TheGizmo supposedly it called for something at this url
                      const gqlEndpoint = “https://api.tibber.com/v1-beta/gql”
                      and thinks it got a good response as it is parsing the data
                       .then(res => {
                                      resO = JSON.parse(res.body);
                                      resolve(resO.data.viewer.homes[0].currentSubscription.priceInfo) < --- this line fails
                      the api IS called beta , “v1-beta”, so maybe they changed the response
                      you could add a line to dump out the returned data
                       .then(res => {
                                      console.log("tibber response="+ resO);  // < --- add this line
                      • T
                        TheGizmo
                        So, I woke up today, and guess what.
                        I have Tibber data. It have pulled some data during the night
                          sdetweil @TheGizmo
                          @TheGizmo cool, and weird!..
                          • O
                            ottopaulsen
                            Hi all.
                            I haven’t gotten any notifications from this forum, so I was not aware of the conversation until today, when @kennethnilssen mentioned it on github. Sorry about that.
                            I believe the issue with the this.log() statement in node_helper.js is solved and fixed in the latest version on Github.
                            I just received my Tibber Pulse, so I am currently working on showing consumption, and will also look in to real time consumption (as asked by @retroflex), so I am currently doing a major upgrade.
                            To @lavolp3 's question about Highcharts, yes, as I understand their license terms, it is free to use for non-commercial purposes, like this obviously is.
                            If you have bug reports or change suggestions, I prefer them as github issues.
                            Cool to see so many people using this :-) It is inspiring!
                            • O
                              ottopaulsen
                              Hi folks, I just updated the MMM-Tibber module, so now it also shows consumption, if you have Tibber Pulse installed. Please help testing, and report bugs on Github.
                                siggmur
                                Just tested and it works great!
                                If I could come with a request, it would be not to show the graphs but only the data. So that I could only see the current consumption or by hours and the current pricing.
                                • A
                                  Aardal1
                                  Thanks for a fantastic module!
                                  Its working great, except the consumption curve in the graph.
                                  The only config line I have for the module is the “tibbertoken”.
                                  Do I need to add the consumption curve config, or should it be enabled as default?
