    MMM-Tibber
    17 Posts 7 Posters 7.8k Views 7 Watching
    • O Offline
      ottopaulsen
      Show electricity price data from Tibber.
      Tibber customers can see the price per hour for today and tomorrow.
      Screenshot
      See https://github.com/ottopaulsen/MMM-Tibber for more.
      lavolp3L 1 Reply Last reply Reply Quote 3
      • T Offline
        TheGizmo
        Hi @ottopaulsen
        Love that you have created this one! I´m also using tibber at home, and my token works on my Hass.io, but I cannot make it run on my MM. Only error I can see is “No Tibber data”. Got any tips on how to dig into what I have done wrong with my code? I just copied your suggestion for setup and added my access token from Tibber.
        • T Offline
          TheGizmo @TheGizmo
          @TheGizmo said in MMM-Tibber:
          Hi @ottopaulsen
          From the error logs:
          ATTENTION: default value of option force_s3tc_enable overridden by environment.
          ReferenceError: log is not defined
          at Class.readTibberPrices (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:34:9)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Tibber/node_helper.js:26:18)
          at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
          at Socket.emit (events.js:182:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at process._tickCallback (internal/process/next_tick.js:61:11)
            sdetweil @TheGizmo
            looks like the node helper has a typo…
            edit line 34
            change from
                    log("readTibberPrices")
            to this
              this.log("readTibberPrices")
            line 44 is correct
            • T Offline
              TheGizmo @sdetweil
              @sdetweil Thx for looking into this, changed and still the same.
              Error from log:
              Error getting tibber prices: TypeError: Cannot read property ‘viewer’ of null
              at rp.then.res (/home/pi/MagicMirror/modules/MMM-Tibber/tibber.js:51:35)
              at tryCatcher (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/util.js:16:23)
              at Promise._settlePromiseFromHandler (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:547:31)
              at Promise._settlePromise (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:604:18)
              at Promise._settlePromise0 (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:649:10)
              at Promise._settlePromises (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/promise.js:729:18)
              at _drainQueueStep (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:93:12)
              at _drainQueue (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:86:9)
              at Async._drainQueues (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:102:5)
              at Immediate.Async.drainQueues [as _onImmediate] (/home/pi/MagicMirror/modules/MMM-Tibber/node_modules/bluebird/js/release/async.js:15:14)
              at runCallback (timers.js:696:18)
              at tryOnImmediate (timers.js:667:5)
              at processImmediate (timers.js:649:5)
                retroflex Project Sponsor Module Developer
                Really cool! Makes me want to switch to Tibber myself.
                One idea… doesn’t Tibber provide your real time consumption as well? Couldn’t that be included?
                • lavolp3L Offline
                  lavolp3 Module Developer @ottopaulsen
                  @ottopaulsen Looks impressive. I see that you’re using highcharts for the chart. Is that free to use?
                  I only see “buy” buttons on their page.
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • T Offline
                    TheGizmo @retroflex
                    @retroflex yes they do, if you have their puls addon. I do, and it works in Home Assistant. I started to look into how I can use one addon to read from HA (not a developer, more visionary guy)
                      sdetweil @TheGizmo
                      no… now the api is returning and error that the code is not handling…
                      • T Offline
                        TheGizmo
                        I have digged more into this, and I cannot see that the module asks Tibber for data at all, (Using Pi-Hole at home) and there are no requests towards Tibber domain.
