    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 136.3k Views 25 Watching
      bachoo786 @Fozi
      @Fozi Hi
      Can i solder pin 1 and 2 of the resistor to the radar sensor? I accidentally broke pin no 3.
      FoziF 1 Reply Last reply
      • FoziF
        Fozi Project Sponsor @bachoo786
        @bachoo786 yes, you can also use pin 1 and 2.
        An example:
        The max value of the resistor (Rmax) is between pin 1 and 3.
        Between pin 1 and 2 is the restitor value R1, and
        between pin 2 and 3 is the resistor value R2.
        Rmax = R1 + R2. (or R1=Rmax - R2, resp, R2=Rmax - R1)
        Thus, you can use both options (R1 pin 1/2 or R2 pin 2/3).
        B 1 Reply Last reply
          bachoo786 @Fozi
          @Fozi so I got a new radar sensor set the resistance to 80ohms which would give me around 40 to 50cm detection distance. I am using @cowboysdude script.
          My mm is running on my rpi 4b 4g and at present its connected to my TV. However the rada sensor is not working as the script is meant to detect motion and if there is no motion it would turn the tv off after 20 seconds. I tried many times but have failed.
          Any ideas? Or maybe my sensor is not working. Is there a simple script that I could test the sensor?
          Thanks.
          FoziF cowboysdudeC 2 Replies Last reply
          • FoziF
            @bachoo786 First re-check if the sensor is cabled correctly to the GPIO as described in my tutorial. Further check if the resistor is soldered correctly to the sensor. Maybe there is a “cold soldering joint”. Sounds trivial, but the devil is a squirrel (old german saying 0_1578041639036_41a3b8fa-8272-448b-8e93-36c6fb58809d-image.png )
            Then, extend the detection range to the max, to check if the sensor is generally OK (200 Ohms) and re-run @cowboysdude script. If this works, then reduce the resistor step by step until you reach the desired detection range. Theoretically 80 Ohms should provide a range of 40-50 cm, but from my experience this may vary strongly as the resistor value does not correspond linearly to the detection range.
            B 2 Replies Last reply
              bachoo786 @Fozi
              @Fozi ok will do thanks.
                bachoo786 @Fozi
                @Fozi Hi
                I am on raspberry pi 4 and I think wiringPi does not work with it as the guy has stopped developing it any further. Is there any other way I could make this work?
                Thanks.
                • FoziF
                  @bachoo786 there exist alternative libs like piGPIO or GPIOzero, but I have no experience with them. Why not try MMM-PIR-Sensor? It is easy to install and to configure and works out of the box with the RCWL-0516.
                    bachoo786 @Fozi
                    @Fozi nope none of them worked for me very surprising.
                    lavolp3L 1 Reply Last reply
                    • lavolp3L
                      lavolp3 Module Developer @bachoo786
                      @bachoo786 Same for me. Couldn’t get neither MMM-PIR nor MMM-PIR-Sensor to work, but on a Raspi3B+
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • FoziF
                        Hmmm…that’s strange.
                        Here is my config for MMM-Pir-Sensor I use:
                                module: 'MMM-PIR-Sensor',
                                sensorPin: 4,
                                powerSavingDelay: 150, // (seconds) how long the monitor will be turned on
                        And this is the wiring of the sensor with the GPIO, which corresponds to the above config. ‘sensorPin: 4’ corresponds to GPIO_4 (brown cable)
                        • lavolp3L
                          lavolp3 Module Developer @Fozi
                          @Fozi The odd thing is that I didn’t even get the module installed properly. However, just tried again and it seems to work now. Maybe because of MM v 2.10.0. I don’t know…
                          • FoziF
                            Fozi Project Sponsor @lavolp3
                            @lavolp3 great!
                            • hedmikH
                              hedmik
                              More or less the same problem for me…
                              I’m using a velleman VMA314 connected to GPIO pin 11 (BCM GPIO 17) and module MMM-PIR-Sensor.
                              I’ve updated wiringPi for Pi 4 (wiringPi updated to 2.52 for the Raspberry Pi 4B)
                              I see that state changes using “gpio readall” but nothing happens…or to start with, connected screen does not even turn off after time set in config:
                              				sensorPin: 17, // The pin (BCM numbering, NOT pin number itself) your PIR-sensor is connected to.
                              				powerSaving: true, // Should the monitor be turned off if no user is present? (via HDMI or relay)
                              				powerSavingDelay: 5, // Additional software side delay (in seconds) before the monitor will be turned off.
                              				powerSavingNotification: true, // To display a notification before to switch screen off
                              				powerSavingMessage: "Skärmen stängs av på grund av inaktivitet..." // Message notification to display before to switch screen off
                              hedmikH 1 Reply Last reply
                              • hedmikH
                                hedmik @hedmik
                                @hedmik sorry, my bad, i was editing config in another pi…
                                Now it’s working now as it should :-)
                                  sdetweil @hedmik
                                  @hedmik said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                                  doesn’t that drive u crazy?! I have 5 devices running, and all have open editors and file managers…
                                  in the editor I can’t tell where the file came from…
                                  hedmikH 2 Replies Last reply
                                  • FoziF
                                    You made my day, guys! 🤣
                                    • hedmikH
                                      hedmik @sdetweil
                                      • hedmikH
                                        hedmik @sdetweil
                                        @sdetweil :rolling_on_the_floor_laughing:
                                        Yes, i’ve built two mirrors and now working on my third bathroom mirror and with x number of files open in Notepad++ it’s getting messy…and even if you can see the file name and it’s location (host name) you end up editing elsewhere :dizzy_face:
                                          devmil
                                          What type of mirror glass do you all have?
                                          I have a Pilkington Mirropane Chrome Spy and to me it seems that this type of Mirror glass interferes with the RCWL-0516.
                                          When doing tests (mirror glass taken off) the sensor works as expected but as soon as I put the mirror glass back it stops working through the glass.
                                          Waving my hand at the side still works.
                                          Greetings
                                          Michael
                                          FoziF hedmikH 2 Replies Last reply
                                          • FoziF
                                            Fozi Project Sponsor @devmil
                                            @devmil I have the same mirror, but 4mm thick, and it works really well. Thickness shouldn’t be an issue, because the sensor is easily able to detect motions in adjacent rooms separated by stone walls. I‘d suggest to increase slightly the sensitivity by increasing the trimmer value.
                                            Further check the soldering joints between trimmer and sensor. Maybe they need to be reworked so that the solder provides a proper connection.
                                            • 3 / 6
