    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 33.1k Views 7 Watching
    • T Offline
      TheGeekfather
      I am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have this problem when Hello-Lucy module loads.:
      “displays mic flashing symbol and just says initialising and “undefined” underneath microphone icon”
      I have tried following the documentation but still no luck
      Anyone get Hello-Lucy to work?
        sdetweil @TheGeekfather
        @TheGeekfather use lsusb and arecord -l to get the device id for the config
        • T Offline
          TheGeekfather @sdetweil
          Sam,
          Bus 001 Device 003: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
          card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
            @TheGeekfather said in Hello-Lucy Module Microphone not working:
            but that is ok… if u speak does it change to Voice?
            the config should say microphone: “plughw:1,0”
            right?
            • T Offline
              Hi Sam, is that the config.txt in boot?
                @TheGeekfather no… in the MagicMirror/config/config.js for the HelloLucy module config section
                it is set to
                microphone: “default”,
                in the code…
                if u do arecord test.wav
                does it work? (this uses the default)
                • T Offline
                  		disabled: false,
                  		module: "Hello-Lucy",
                  		position: "bottom_left",
                    			keyword: 'HELLO LUCY',               // MUST BE CAPITALS to make Lucy start listening
                    			timeout: 15,                        // timeout listening for a command/sentence
                    			defaultOnStartup: 'Hello-Lucy',
                    			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                    			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                    			confirmationSound: "ding.mp3",
                  This is my config for Lucy
                    @TheGeekfather right, it is using ‘default’, and I asked u to test if default worked
                    • T Offline
                      It works outside of MagicMirror
                      Not sure where I put in Microphone id or microphone default
                      Retired teacher still trying to learn. Got lots of the modules working but having trouble with voice commands
                        ahmen… everyone has trouble…
                        so, did the arecord command work?
                        T 2 Replies Last reply Reply Quote 0
                        • T Offline
                          arecord works in terminal. when Lucy module loads - under mic icon it says “undefined”
                          • T Offline
                            Hi Sam
                            Looks like the problem is with the install
                            "My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                            Seriously, it will be fixed ASAP.
                            Thank you for your patience and interest."
                            • L Offline
                              Linas123
                              @TheGeekfather
                              I have the same problem. Do you have the solution for this issue? Pleas, let me now.
                                Mykle1 Project Sponsor Module Developer @Linas123
                                @Linas123
                                Have you run arecord -l in the terminal? (that’s a lower case L)
                                Post your output from that command here.
                                My output:
                                pop@e8300:~$ arecord -l
                                **** List of CAPTURE Hardware Devices ****
                                card 0: PCH [HDA Intel PCH], device 0: ALC221 Analog [ALC221 Analog]
                                  Subdevices: 1/1
                                  Subdevice #0: subdevice #0
                                card 0: PCH [HDA Intel PCH], device 2: ALC221 Alt Analog [ALC221 Alt Analog]
                                  Subdevices: 1/1
                                pop@e8300:~$
                                • L Offline
                                  Linas123 @Mykle1
                                  @Mykle1
                                  Here is my micro output:
                                   arecord -l
                                  **** Liste der Hardware-Geräte (CAPTURE) ****
                                  Karte 2: AK5371 [AK5371], Gerät 0: USB Audio [USB Audio]
                                    Sub-Geräte: 0/1
                                    Sub-Gerät #0: subdevice #0
                                  and my speaker (I use the screen speaker):
                                  aplay -l
                                  **** Liste der Hardware-Geräte (PLAYBACK) ****
                                  Karte 0: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
                                    Sub-Geräte: 7/7
                                    Sub-Gerät #1: subdevice #1
                                    Sub-Gerät #2: subdevice #2
                                    Sub-Gerät #3: subdevice #3
                                    Sub-Gerät #4: subdevice #4
                                    Sub-Gerät #5: subdevice #5
                                    Sub-Gerät #6: subdevice #6
                                  Karte 0: ALSA [bcm2835 ALSA], Gerät 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
                                    Sub-Geräte: 1/1
                                  Karte 0: ALSA [bcm2835 ALSA], Gerät 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
                                    Sub-Geräte: 1/1
                                  Karte 1: vc4hdmi [vc4-hdmi], Gerät 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
                                    Sub-Geräte: 1/1
                                  I have a USB Mic and I hope that’s not the problem, because I read a bit in this forum, that sometimes USB Micros have trouble with Hello-Lucy. I also changed my /.asoundrc file so that the speaker and microphone worked as they should. In the tests everything still worked. Here is my /.asoundrc file:
                                  pcm.!default {
                                    type asym
                                     playback.pcm {
                                       type plug
                                       slave.pcm "hw:0,1"
                                     capture.pcm {
                                       type plug
                                       slave.pcm "hw:2,0"
                                  Maybe It’s a npm problem, because at the end of the installation of the module these npm warnings came:
                                  Note: First I make the sound configuration and only after that I install the module.
                                  npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                                  npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                  npm notice created a lockfile as package-lock.json. You should commit this file.
                                  npm WARN eslint-config-airbnb-base@11.3.2 requires a peer of eslint@^3.19.0 || ^4.5.0 but none is installed. You must install peer dependencies yourself.
                                  npm WARN acorn-jsx@5.2.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                  I’m glad if you can help me:)
                                    @Linas123
                                    I don’t think it’s npm. Those are just warnings and won’t affect the module.
                                    USB microphone will work but it does introduce some latency.
                                    If you run arecord test.wav in a terminal window does it record a sound file?
                                    So, based on the info you gave me your config entry for the microphone should be
                                    microphone: "2,0",
                                    Please try that
                                    Then post your entire Hello-Lucy config entry so I can see it
                                    • L Offline
                                      Linas123 @Mykle1
                                      @Mykle1
                                      disabled: false,
                                      position: "top_center",
                                          keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                                          microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                                          sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random greetings
                                          confirmationSound: "ding.mp3",      // name and extension of sound file
                                          startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                                          // *** Page One is your default startup page *** This overrides startHideAll: true,
                                          pageOneModules: ["Hello-Lucy", ],                     // default modules to show on page one/startup
                                          pageTwoModules: ["Hello-Lucy",], // modules to show on page two
                                          pageThreeModules: ["Hello-Lucy",],                 // modules to show on page three
                                          pageFourModules: ["Hello-Lucy", ],                  // modules to show on page four
                                          pageFiveModules: ["Hello-Lucy", ],               // modules to show on page five
                                          pageSixModules: ["Hello-Lucy", ],                      // modules to show on page six
                                          pageSevenModules: ["Hello-Lucy", ],                   // modules to show on page seven
                                          pageEightModules: ["Hello-Lucy", ],                   // modules to show on page eight
                                          pageNineModules: ["Hello-Lucy", ],                   // modules to show on page nine
                                          pageTenModules: ["Hello-Lucy", ]             // modules to show on page ten
                                      I don’t know what else I can do.
                                        @Linas123
                                        You tried to run it? What was the result?
                                          @Linas123
                                          Your config entry is fine. I just tried it with my microphone setting and it works fine
                                          • L Offline
                                            Linas123
                                            Yes I tried it to run, but lucy say only “Hello Michael, what would you like to see” and on the top of the Mirror is a crossed-out green flashing microphone and “Command Please:”.
