    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 34.8k Views 7 Watching
      sdetweil @TheGeekfather
      @TheGeekfather said in Hello-Lucy Module Microphone not working:
      “displays mic flashing symbol and just says initialising and “undefined” underneath microphone icon”
      but that is ok… if u speak does it change to Voice?
      the config should say microphone: “plughw:1,0”
      right?
      T 1 Reply Last reply
      • T
        TheGeekfather @sdetweil
        Hi Sam, is that the config.txt in boot?
          @TheGeekfather no… in the MagicMirror/config/config.js for the HelloLucy module config section
          it is set to
          microphone: “default”,
          in the code…
          if u do arecord test.wav
          does it work? (this uses the default)
          • T
            		disabled: false,
            		module: "Hello-Lucy",
            		position: "bottom_left",
              			keyword: 'HELLO LUCY',               // MUST BE CAPITALS to make Lucy start listening
              			timeout: 15,                        // timeout listening for a command/sentence
              			defaultOnStartup: 'Hello-Lucy',
              			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
              			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
              			confirmationSound: "ding.mp3",
            This is my config for Lucy
              @TheGeekfather right, it is using ‘default’, and I asked u to test if default worked
              • T
                It works outside of MagicMirror
                Not sure where I put in Microphone id or microphone default
                Retired teacher still trying to learn. Got lots of the modules working but having trouble with voice commands
                  ahmen… everyone has trouble…
                  so, did the arecord command work?
                  T 2 Replies Last reply
                  • T
                    arecord works in terminal. when Lucy module loads - under mic icon it says “undefined”
                    • T
                      Hi Sam
                      Looks like the problem is with the install
                      "My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                      Seriously, it will be fixed ASAP.
                      Thank you for your patience and interest."
                      • L
                        Linas123
                        @TheGeekfather
                        I have the same problem. Do you have the solution for this issue? Pleas, let me now.
                        Mykle1M 1 Reply Last reply
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Linas123
                          @Linas123
                          Have you run arecord -l in the terminal? (that’s a lower case L)
                          Post your output from that command here.
                          My output:
                          pop@e8300:~$ arecord -l
                          **** List of CAPTURE Hardware Devices ****
                          card 0: PCH [HDA Intel PCH], device 0: ALC221 Analog [ALC221 Analog]
                            Subdevices: 1/1
                            Subdevice #0: subdevice #0
                          card 0: PCH [HDA Intel PCH], device 2: ALC221 Alt Analog [ALC221 Alt Analog]
                            Subdevices: 1/1
                          pop@e8300:~$
                          L 1 Reply Last reply
                          • L
                            Linas123 @Mykle1
                            @Mykle1
                            Here is my micro output:
                             arecord -l
                            **** Liste der Hardware-Geräte (CAPTURE) ****
                            Karte 2: AK5371 [AK5371], Gerät 0: USB Audio [USB Audio]
                              Sub-Geräte: 0/1
                              Sub-Gerät #0: subdevice #0
                            and my speaker (I use the screen speaker):
                            aplay -l
                            **** Liste der Hardware-Geräte (PLAYBACK) ****
                            Karte 0: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
                              Sub-Geräte: 7/7
                              Sub-Gerät #1: subdevice #1
                              Sub-Gerät #2: subdevice #2
                              Sub-Gerät #3: subdevice #3
                              Sub-Gerät #4: subdevice #4
                              Sub-Gerät #5: subdevice #5
                              Sub-Gerät #6: subdevice #6
                            Karte 0: ALSA [bcm2835 ALSA], Gerät 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
                              Sub-Geräte: 1/1
                            Karte 0: ALSA [bcm2835 ALSA], Gerät 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
                              Sub-Geräte: 1/1
                            Karte 1: vc4hdmi [vc4-hdmi], Gerät 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
                              Sub-Geräte: 1/1
                            I have a USB Mic and I hope that’s not the problem, because I read a bit in this forum, that sometimes USB Micros have trouble with Hello-Lucy. I also changed my /.asoundrc file so that the speaker and microphone worked as they should. In the tests everything still worked. Here is my /.asoundrc file:
                            pcm.!default {
                              type asym
                               playback.pcm {
                                 type plug
                                 slave.pcm "hw:0,1"
                               capture.pcm {
                                 type plug
                                 slave.pcm "hw:2,0"
                            Maybe It’s a npm problem, because at the end of the installation of the module these npm warnings came:
                            Note: First I make the sound configuration and only after that I install the module.
                            npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                            npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                            npm notice created a lockfile as package-lock.json. You should commit this file.
                            npm WARN eslint-config-airbnb-base@11.3.2 requires a peer of eslint@^3.19.0 || ^4.5.0 but none is installed. You must install peer dependencies yourself.
                            npm WARN acorn-jsx@5.2.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                            I’m glad if you can help me:)
                            • Mykle1M
                              @Linas123
                              I don’t think it’s npm. Those are just warnings and won’t affect the module.
                              USB microphone will work but it does introduce some latency.
                              If you run arecord test.wav in a terminal window does it record a sound file?
                              So, based on the info you gave me your config entry for the microphone should be
                              microphone: "2,0",
                              Please try that
                              Then post your entire Hello-Lucy config entry so I can see it
                              • L
                                Linas123 @Mykle1
                                @Mykle1
                                disabled: false,
                                position: "top_center",
                                    keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                                    microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                                    sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random greetings
                                    confirmationSound: "ding.mp3",      // name and extension of sound file
                                    startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                                    // *** Page One is your default startup page *** This overrides startHideAll: true,
                                    pageOneModules: ["Hello-Lucy", ],                     // default modules to show on page one/startup
                                    pageTwoModules: ["Hello-Lucy",], // modules to show on page two
                                    pageThreeModules: ["Hello-Lucy",],                 // modules to show on page three
                                    pageFourModules: ["Hello-Lucy", ],                  // modules to show on page four
                                    pageFiveModules: ["Hello-Lucy", ],               // modules to show on page five
                                    pageSixModules: ["Hello-Lucy", ],                      // modules to show on page six
                                    pageSevenModules: ["Hello-Lucy", ],                   // modules to show on page seven
                                    pageEightModules: ["Hello-Lucy", ],                   // modules to show on page eight
                                    pageNineModules: ["Hello-Lucy", ],                   // modules to show on page nine
                                    pageTenModules: ["Hello-Lucy", ]             // modules to show on page ten
                                I don’t know what else I can do.
                                Mykle1M 2 Replies Last reply
                                • Mykle1M
                                  @Linas123
                                  You tried to run it? What was the result?
                                  • Mykle1M
                                    @Linas123
                                    Your config entry is fine. I just tried it with my microphone setting and it works fine
                                    • L
                                      Linas123
                                      Yes I tried it to run, but lucy say only “Hello Michael, what would you like to see” and on the top of the Mirror is a crossed-out green flashing microphone and “Command Please:”.
                                      • Mykle1M
                                        @Linas123
                                        OK, the module is loading. That’s good.
                                        • L
                                          Linas123 @Mykle1
                                          @Mykle1 said in Hello-Lucy Module Microphone not working:
                                          arecord test.wav
                                          No it doesn’t work , there is yet the error “arecord: main:828:…”. I just noticed that my USB micro is now suddenly displayed as card 1. I change yet my /.asoundrc file again. Do I have to download the module again?
                                          Thank you for you fast replays.
                                          • Mykle1M
                                            @Linas123
                                            arecord test.wav MUST work for Lucy to work.
                                            If you can get that to work then run arecord -l again to get your card and device numbers,
                                            Then enter those in the microphone config entry and run MM again
