    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 28.0k Views 7 Watching
      sdetweil @TheGeekfather
      @TheGeekfather use lsusb and arecord -l to get the device id for the config
      • T Offline
        TheGeekfather @sdetweil
        Sam,
        Bus 001 Device 003: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
        card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
          @TheGeekfather said in Hello-Lucy Module Microphone not working:
          “displays mic flashing symbol and just says initialising and “undefined” underneath microphone icon”
          but that is ok… if u speak does it change to Voice?
          the config should say microphone: “plughw:1,0”
          right?
          • T Offline
            Hi Sam, is that the config.txt in boot?
              @TheGeekfather no… in the MagicMirror/config/config.js for the HelloLucy module config section
              it is set to
              microphone: “default”,
              in the code…
              if u do arecord test.wav
              does it work? (this uses the default)
              • T Offline
                		disabled: false,
                		module: "Hello-Lucy",
                		position: "bottom_left",
                  			keyword: 'HELLO LUCY',               // MUST BE CAPITALS to make Lucy start listening
                  			timeout: 15,                        // timeout listening for a command/sentence
                  			defaultOnStartup: 'Hello-Lucy',
                  			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                  			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                  			confirmationSound: "ding.mp3",
                This is my config for Lucy
                  @TheGeekfather right, it is using ‘default’, and I asked u to test if default worked
                  • T Offline
                    It works outside of MagicMirror
                    Not sure where I put in Microphone id or microphone default
                    Retired teacher still trying to learn. Got lots of the modules working but having trouble with voice commands
                      ahmen… everyone has trouble…
                      so, did the arecord command work?
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        arecord works in terminal. when Lucy module loads - under mic icon it says “undefined”
                        • 1 / 6
