    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 34.1k Views 7 Watching
      sdetweil @TheGeekfather
      @TheGeekfather use lsusb and arecord -l to get the device id for the config
      • T Offline
        TheGeekfather @sdetweil
        Sam,
        Bus 001 Device 003: ID 0d8c:0014 C-Media Electronics, Inc. Audio Adapter (Unitek Y-247A)
        card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
          @TheGeekfather said in Hello-Lucy Module Microphone not working:
          “displays mic flashing symbol and just says initialising and “undefined” underneath microphone icon”
          but that is ok… if u speak does it change to Voice?
          the config should say microphone: “plughw:1,0”
          right?
          • T Offline
            Hi Sam, is that the config.txt in boot?
              @TheGeekfather no… in the MagicMirror/config/config.js for the HelloLucy module config section
              it is set to
              microphone: “default”,
              in the code…
              if u do arecord test.wav
              does it work? (this uses the default)
              • T Offline
                		disabled: false,
                		module: "Hello-Lucy",
                		position: "bottom_left",
                  			keyword: 'HELLO LUCY',               // MUST BE CAPITALS to make Lucy start listening
                  			timeout: 15,                        // timeout listening for a command/sentence
                  			defaultOnStartup: 'Hello-Lucy',
                  			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                  			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                  			confirmationSound: "ding.mp3",
                This is my config for Lucy
                  @TheGeekfather right, it is using ‘default’, and I asked u to test if default worked
                  • T Offline
                    It works outside of MagicMirror
                    Not sure where I put in Microphone id or microphone default
                    Retired teacher still trying to learn. Got lots of the modules working but having trouble with voice commands
                      ahmen… everyone has trouble…
                      so, did the arecord command work?
                      T 2 Replies Last reply Reply Quote 0
                      • T Offline
                        arecord works in terminal. when Lucy module loads - under mic icon it says “undefined”
                        • T Offline
                          Hi Sam
                          Looks like the problem is with the install
                          "My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                          Seriously, it will be fixed ASAP.
                          Thank you for your patience and interest."
                          • L Offline
                            Linas123
                            @TheGeekfather
                            I have the same problem. Do you have the solution for this issue? Pleas, let me now.
                              Mykle1 Project Sponsor Module Developer @Linas123
                              @Linas123
                              Have you run arecord -l in the terminal? (that’s a lower case L)
                              Post your output from that command here.
                              My output:
                              pop@e8300:~$ arecord -l
                              **** List of CAPTURE Hardware Devices ****
                              card 0: PCH [HDA Intel PCH], device 0: ALC221 Analog [ALC221 Analog]
                                Subdevices: 1/1
                                Subdevice #0: subdevice #0
                              card 0: PCH [HDA Intel PCH], device 2: ALC221 Alt Analog [ALC221 Alt Analog]
                                Subdevices: 1/1
                              pop@e8300:~$
                              • L Offline
                                Linas123 @Mykle1
                                @Mykle1
                                Here is my micro output:
                                 arecord -l
                                **** Liste der Hardware-Geräte (CAPTURE) ****
                                Karte 2: AK5371 [AK5371], Gerät 0: USB Audio [USB Audio]
                                  Sub-Geräte: 0/1
                                  Sub-Gerät #0: subdevice #0
                                and my speaker (I use the screen speaker):
                                aplay -l
                                **** Liste der Hardware-Geräte (PLAYBACK) ****
                                Karte 0: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
                                  Sub-Geräte: 7/7
                                  Sub-Gerät #1: subdevice #1
                                  Sub-Gerät #2: subdevice #2
                                  Sub-Gerät #3: subdevice #3
                                  Sub-Gerät #4: subdevice #4
                                  Sub-Gerät #5: subdevice #5
                                  Sub-Gerät #6: subdevice #6
                                Karte 0: ALSA [bcm2835 ALSA], Gerät 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
                                  Sub-Geräte: 1/1
                                Karte 0: ALSA [bcm2835 ALSA], Gerät 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
                                  Sub-Geräte: 1/1
                                Karte 1: vc4hdmi [vc4-hdmi], Gerät 0: MAI PCM vc4-hdmi-hifi-0 [MAI PCM vc4-hdmi-hifi-0]
                                  Sub-Geräte: 1/1
                                I have a USB Mic and I hope that’s not the problem, because I read a bit in this forum, that sometimes USB Micros have trouble with Hello-Lucy. I also changed my /.asoundrc file so that the speaker and microphone worked as they should. In the tests everything still worked. Here is my /.asoundrc file:
                                pcm.!default {
                                  type asym
                                   playback.pcm {
                                     type plug
                                     slave.pcm "hw:0,1"
                                   capture.pcm {
                                     type plug
                                     slave.pcm "hw:2,0"
                                Maybe It’s a npm problem, because at the end of the installation of the module these npm warnings came:
                                Note: First I make the sound configuration and only after that I install the module.
                                npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                npm WARN eslint-config-airbnb-base@11.3.2 requires a peer of eslint@^3.19.0 || ^4.5.0 but none is installed. You must install peer dependencies yourself.
                                npm WARN acorn-jsx@5.2.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                I’m glad if you can help me:)
                                  @Linas123
                                  I don’t think it’s npm. Those are just warnings and won’t affect the module.
                                  USB microphone will work but it does introduce some latency.
                                  If you run arecord test.wav in a terminal window does it record a sound file?
                                  So, based on the info you gave me your config entry for the microphone should be
                                  microphone: "2,0",
                                  Please try that
                                  Then post your entire Hello-Lucy config entry so I can see it
                                  • L Offline
                                    Linas123 @Mykle1
                                    @Mykle1
                                    disabled: false,
                                    position: "top_center",
                                        keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                                        microphone: "2,0",                  // run "arecord -l" card # and device # mine is "0,0"
                                        sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random greetings
                                        confirmationSound: "ding.mp3",      // name and extension of sound file
                                        startHideAll: false,                 // All modules start as hidden EXCEPT PAGE ONE
                                        // *** Page One is your default startup page *** This overrides startHideAll: true,
                                        pageOneModules: ["Hello-Lucy", ],                     // default modules to show on page one/startup
                                        pageTwoModules: ["Hello-Lucy",], // modules to show on page two
                                        pageThreeModules: ["Hello-Lucy",],                 // modules to show on page three
                                        pageFourModules: ["Hello-Lucy", ],                  // modules to show on page four
                                        pageFiveModules: ["Hello-Lucy", ],               // modules to show on page five
                                        pageSixModules: ["Hello-Lucy", ],                      // modules to show on page six
                                        pageSevenModules: ["Hello-Lucy", ],                   // modules to show on page seven
                                        pageEightModules: ["Hello-Lucy", ],                   // modules to show on page eight
                                        pageNineModules: ["Hello-Lucy", ],                   // modules to show on page nine
                                        pageTenModules: ["Hello-Lucy", ]             // modules to show on page ten
                                    I don’t know what else I can do.
                                      @Linas123
                                      You tried to run it? What was the result?
                                        @Linas123
                                        Your config entry is fine. I just tried it with my microphone setting and it works fine
                                        • L Offline
                                          Linas123
                                          Yes I tried it to run, but lucy say only “Hello Michael, what would you like to see” and on the top of the Mirror is a crossed-out green flashing microphone and “Command Please:”.
                                            @Linas123
                                            OK, the module is loading. That’s good.
