    MMM-SpaceX
    Scheduled Pinned Locked Moved Fun & Games
    21 Posts 10 Posters 15.6k Views 10 Watching
      sonicgoose @koxm
      @koxm That looks awesome! It looks like you have launch date as the second last column—can that show upcoming launches in ascending order (so soonest to latest?) Can you add in the launch window time?
      I agree with @retroflex that the option to show each column would be nice. Otherwise well done!
      K 1 Reply Last reply
      • K
        koxm @retroflex
        @retroflex Thanks for the compliment!
        Optional column headings are a great idea. I’m gonna work on it. I will see how I can fit the other features in it.
        • K
          koxm @sonicgoose
          @sonicgoose Thanks!
          Unfortunately the dates for the upcoming launches are not fully maintained in the api. Maybe I can use a different field. I’m going to look at it.
          R 1 Reply Last reply
            sonicgoose @koxm
            @koxm I’ve just installed it and have noticed the table cells are awfully close together, i.e. there is no separation at all between the last two columns, so it appears as 02 Mar 2020 Falcon 9. This is with the module bottom_center. I tried adding a padding to the left and right side of the cells in my custom.css and also added a width to the table in custom.css, but neither seemed to help.
            • K
              koxm @sonicgoose
              @sonicgoose You’re right, it’s pretty close. The stylesheet included only manipulates the td and th. If I test it on my screen on bottom_center, it looks quite fine. This is because of the column header which creates some kind of spacing.
              I’m gonna see if I can make it al little better with the MMM-SpaceX.css.
                sonicgoose @koxm
                @koxm Is this the api you’re using?
                  A Former User
                  • K
                    koxm @sonicgoose
                    @sonicgoose Yep
                    • K
                      koxm @Guest
                      @hango Thanks for the tip, gonna work on it tommorow. I’m pretty new to CSS as well.
                        A Former User
                          retroflex Project Sponsor Module Developer @koxm
                          @koxm said in MMM-SpaceX:
                          @sonicgoose Thanks!
                          I have not looked much at the API but if the unix timestamp field is maintained, I suggest you use that. Then you will also get the correct date for your time zone.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @koxm
                            @koxm
                            Damn, you beat me to it! haha
                            Well done! :thumbsup:
                            • BKeyportB
                              BKeyport Module Developer
                              Nice module!
                                jimmythehat45 @koxm
                                @koxm I really like the idea of this app! Any chance we could get an update? It looks like v3 is no longer active on the spacexdata api, I tried updating the url to their newest but it doesn’t seem to load-in the future launches properly:
                                https://api.spacexdata.com/v4/launches/latest
                                Any ideas on what is needed to get this app working again? Cheers!
                                W 1 Reply Last reply
                                • W
                                  Wenike @jimmythehat45
                                  @jimmythehat45 I’ve not played around with this, but MMM-Rocketlaunch might work better? Or if nothing else, pull the same API (and get more than the SpaceX launches).
                                  Thanks for calling out this module btw, I didn’t even realize that I actually wanted a rocket launch module on my mirror.
                                  J 1 Reply Last reply
                                    jimmythehat45 @Wenike
                                    @wenike Good call, I hadn’t seen the MMM-Rocketlaunch module before, looks sharp! I love seeing upcoming launches on my mirror :D
                                    • X
                                      xsorifc28
                                      I have just updated this module to work with V4 of the SpaceX api:
                                      https://github.com/xsorifc28/MMM-SpaceX
                                      I only tested “upcoming” launches.
                                      I will make a pull request to the original source by @koxm after I clean up my implementation.
                                      @jimmythehat45
                                        jimmythehat45 @xsorifc28
                                        @xsorifc28 this is fantastic! I didn’t see this reply until now, I can’t wait to install it on my Mirror! Thanks so much
                                          peterpong493
                                          In general, we can see that most of the people are struggling to find the stuffs when you want to know. If you are looking for the same, then without going for a second thought, go ahead with this"">COC MOD and GBWhatsapp
                                          https://gbplusmod.com/download-fm-whatsapp-apk/
                                          Reply Quote -1
