    MMM-SpaceX
    Scheduled Pinned Locked Moved Fun & Games
    21 Posts 10 Posters 11.5k Views 10 Watching
      sonicgoose @koxm
      @koxm I’ve just installed it and have noticed the table cells are awfully close together, i.e. there is no separation at all between the last two columns, so it appears as 02 Mar 2020 Falcon 9. This is with the module bottom_center. I tried adding a padding to the left and right side of the cells in my custom.css and also added a width to the table in custom.css, but neither seemed to help.
      • K Offline
        koxm @sonicgoose
        @sonicgoose You’re right, it’s pretty close. The stylesheet included only manipulates the td and th. If I test it on my screen on bottom_center, it looks quite fine. This is because of the column header which creates some kind of spacing.
        I’m gonna see if I can make it al little better with the MMM-SpaceX.css.
          sonicgoose @koxm
          @koxm Is this the api you’re using?
            A Former User
            • K Offline
              koxm @sonicgoose
              @sonicgoose Yep
              • K Offline
                koxm @Guest
                @hango Thanks for the tip, gonna work on it tommorow. I’m pretty new to CSS as well.
                  A Former User
                    retroflex Project Sponsor Module Developer @koxm
                    @koxm said in MMM-SpaceX:
                    @sonicgoose Thanks!
                    Unfortunately the dates for the upcoming launches are not fully maintained in the api. Maybe I can use a different field. I’m going to look at it.
                    I have not looked much at the API but if the unix timestamp field is maintained, I suggest you use that. Then you will also get the correct date for your time zone.
                      Mykle1 Project Sponsor Module Developer @koxm
                      @koxm
                      Damn, you beat me to it! haha
                      Well done! :thumbsup:
                      • BKeyportB Offline
                        BKeyport Module Developer
                        Nice module!
                          jimmythehat45 @koxm
                          @koxm I really like the idea of this app! Any chance we could get an update? It looks like v3 is no longer active on the spacexdata api, I tried updating the url to their newest but it doesn’t seem to load-in the future launches properly:
                          https://api.spacexdata.com/v4/launches/latest
                          Any ideas on what is needed to get this app working again? Cheers!
                          • W Offline
                            Wenike @jimmythehat45
                            @jimmythehat45 I’ve not played around with this, but MMM-Rocketlaunch might work better? Or if nothing else, pull the same API (and get more than the SpaceX launches).
                            Thanks for calling out this module btw, I didn’t even realize that I actually wanted a rocket launch module on my mirror.
                              jimmythehat45 @Wenike
                              @wenike Good call, I hadn’t seen the MMM-Rocketlaunch module before, looks sharp! I love seeing upcoming launches on my mirror :D
                              • X Offline
                                xsorifc28
                                I have just updated this module to work with V4 of the SpaceX api:
                                https://github.com/xsorifc28/MMM-SpaceX
                                I only tested “upcoming” launches.
                                I will make a pull request to the original source by @koxm after I clean up my implementation.
                                @jimmythehat45
                                  jimmythehat45 @xsorifc28
                                  @xsorifc28 this is fantastic! I didn’t see this reply until now, I can’t wait to install it on my Mirror! Thanks so much
                                    peterpong493
                                    In general, we can see that most of the people are struggling to find the stuffs when you want to know. If you are looking for the same, then without going for a second thought, go ahead with this"">COC MOD and GBWhatsapp
                                    https://gbplusmod.com/download-fm-whatsapp-apk/
                                    1 Reply Last reply Reply Quote -1
