    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
    • bheplerB
      bhepler Module Developer @alexyak
      Thanks, @alexyak. Any idea about how to get around the issue with the new security surrounding webcams?
        DirkS
        Hi, i had some issues with the PIR module where the screen doesn’t switch on anymore. Now with a original PI Camera i tried this module. Same issue, the screen doesn’t switch on but in this case no motion seems to be detected. (the PIR did detect)
        with /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7 i can switch on the screen manually.
        I followed every tip here in the thread. So i have no idea what is going on :(
        mm-0 (out): monitor has been deactivated
        mm-0 (out): monitor :state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
        mm-0 (out):
        That is the only thing i can see in the log.
        • bheplerB
          Check the console log. I suspect you’ll see a security error preventing the browser from accessing the monitor. Either launch your mirror in dev mode (modify your mm.sh script to read DISPLAY=:0 npm start dev and then restart via pm2 restart 0) or browse to your mirror’s address via a web browser and enter developere mode.
            DirkS
            i don’t have a mm.sh script. Where should it be located?
            bheplerB 1 Reply Last reply
            • bheplerB
              bhepler Module Developer @DirkS
              @DirkS Aha. You probably haven’t set it up yet. No worries. You normally start your mirror by going into ~/MagicMirror and entering npm start, right? Just append the dev switch and you should see both the mirror UI and the browser console on your mirror: npm start dev
              If you’re starting your mirror via SSH, prepend the command to send the output to the mirror’s display: DISPLAY=:0 npm start dev
                DirkS
                The mirror is starting at reboot. So maybe there is a script, i installed it a few month ago, i don’t remember :D
                If i’m testing new settings i use pm2 restart mm for example. npm i’m just using to install new modules.
                • bheplerB
                  @DirkS Interesting. Following the instructions I found via the GitHub MagicMirror repository, the pm2 should be using /home/pi/mm.sh to start the magic mirror process. Editing this file and appending DEV should give you the web browser console with log.
                    done @cpramhofer
                    Hi and thanks to everybody making this module work!
                    @cpramhofer Did your solution solve the issue that the monitor did not switch on again after a longer period of time?
                    • bheplerB
                      bhepler Module Developer @done
                      @done Wait, does it work for you? Because it’s not working for me and this is the last thing I need before my mirror is done.
                      D 1 Reply Last reply
                        done @bhepler
                        @bhepler Sorry, I haven’t tried yet. :)
                        I installed the cam and the module yesterday and motion detection worked.
                        But I experienced the same issue this morning. Wake up problem is not solved.
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @done
                          @done propably everything is working for you guys and you can just see the screensaver, be sure to disable the screensaver
                          D bheplerB 2 Replies Last reply
                            done @strawberry 3.141
                            Hi @strawberry-3.141
                            Thanks for your answer
                            I disabled the screensaver by editing (found here
                            Is that what you had in mind?
                            sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
                            @lxpanel --profile LXDE-pi
                            @pcmanfm --desktop --profile LXDE-pi
                            #@xscreensaver -no-splash
                            @xset s off
                            @xset -dpms
                            @xset s noblank
                            @unclutter
                            Strange that my camera driver was not working today.
                            I had to activate the cam in the pi config again.
                            In the morning the cam led was on but when I tried to wake up the monitor the led just turned off.
                            I use a v1.3 cam on a rpi3.
                            • strawberry 3.141S
                              @done Personally I don’t have a mirror myself, but I heard from other users in this forum they had problems with the screensaver when they tried to wake up the mirror using my voice module. They could see the mirror got brighter, but the screen was still black because of the screensaver. I would connect a mouse or keyboard and do some action to see if there is a screensaver active.
                                @strawberry-3.141 Ok, I’ll give it a try. Tomorrow morning, I will test again. Thx!
                                  bibi
                                  hello! as understood there are 2 topics ongoing here "PIR module of @cowboysdude " and "motiondetector of @alexyak ". I will not ask which is the best module, you both did a great job, thx!
                                  don’t take it bad but i just wanted to have opinions and feedback on which one is running currently without any, less issues please? (i am starting my mirror and don’t want to be too much demanding on the forum if not working - wise ;-))
                                  @cowboysdude : i have already implemented Paviro’s module to test and i wanted to know if i should remove it before installing your one?
                                  Thx in advance for your relpies and have a good day/eve :)
                                  • cowboysdudeC
                                    cowboysdude Module Developer @bibi
                                    @bibi said in Motion Detector:
                                    Honestly I will you this… I liked the motion sensor BUT @ianperrin worked out a module scheduler that I liked much better! I can turn modules off and on at specific times and turn it all off when I"m not home only to have it back on again when I arrive home.
                                    All-in-all it really depends on your needs. NOTHING is without issues of some kind. I just really disliked the PIR sensor sticking out …
                                    I hoped this help you in some way.
                                    OH but of course @strawberry-3-141 also made a voice module that you can just tell the mirror to turn off too :) The usb mike is about the same price as a pir sensor!!! It’s REALLY awesome!!!
                                    • cowboysdudeC
                                      cowboysdude Module Developer @done
                                      @done said in Motion Detector:
                                      WORST case senario is you install a screen saver program and disable it… period. :)
                                        bibi @cowboysdude
                                        @cowboysdude 1st thx for taking time to reply. much appriciated! the PIR is ok but as it needs to get hidden somewhere, etc it’s less convinent. Yes you are right, the solution depends on my personnal need… i just need a way to switch on MM when i am in front of it BUT also completly switch off the monitor when nothing detected and not only the MM.
                                        oh great, i will check @strawberry-3-141 module for sure!
                                        @IngmarSwart also designed a solution with motion detection with a Picam behind the glass which seems to be nice to. i let you check it if interest…
                                        by the way, do i have to remove Paviro module to install your one?
                                        i couldn’t find @strawberry-3-141 module… can you pls forward me the link?
                                        • bheplerB
                                          bhepler Module Developer @strawberry 3.141
                                          @strawberry-3.141 said in Motion Detector:
                                          Negative. The screensaver has been disabled but the motiondetection module isn’t working. I gave the Facial Recognition module a try, but with the camera behind the glass, there isn’t enough light to train the system to recognize anyone.
                                          At this point, I’m considering downgrading my chromium to something without the new security “features”.
                                          • bheplerB
                                            I’m still working this problem. To help with @paphko 's concern about processor utilization, I finally figured out how and where to put a delay in the main image comparison loop. @alexyak is using the RequestAnimationFrame feature to run the comparison as fast as the browser can render the UI.
                                            If you wish to include a delay, modify your motion.js file’s main function to read as such:
                                            function main(frequency) {
                                            	render();
                                            	if(rendering == true) {
                                            		setTimeout(function() {
                                            			raf(main.bind(this));
                                            		}, 500);
                                            That last number (the 500) is the milliseconds between each image comparison. I think half a second between comparisons is enough to keep the CPU usage down and the effectiveness up.
                                            • 10
                                            • 11
                                            • 5 / 11
