monitor - disassemble or not?
9 Posts 7 Posters 2.0k Views 7 Watching
    banbutcher
    Hi, not sure if this is in the right place.
    so no ive got my pi almost set up to my liking, it will soon be time to mount monitor behind my mirror, question is do you recommend disassembling the plastic case and then mount the monitor panel for a tighter fit to the glass or does it matter?
    thanks,
    Richie
    T 1 Reply Last reply Mar 20, 2020, 1:13 PM Reply Quote 0
      BKeyport Module Developer
      I suppose it depends on the monitor. I took the front off mine, will likely have to shim it back a hair from the glass due to it having a metal piece on the bottom and nowhere else… undecided if I’m going to take the plastics off the sides and back or use the VESA mount to secure it in it’s final case…
        MilkShake
        You will get the best result from disassembling the case. Should be easy for most cases, just be wary of not ripping any of the cords.
          bendardenne
          It’s usually not hard to take it out and it allows you to have the monitor closer to the glass, it makes the monitor less thick so your frame doesn’t have to be so deep, it allows you to place your monitor more freely…
          I guess it depends on the monitor, but with mine I wouldn’t have had a good result with the frame still on, it was way too clunky and thick.
            banbutcher
            i have a 23" LG monitor, thin enough but i might still look at removing the plastic!
            thanks folks! :)
            M 1 Reply Last reply Mar 20, 2020, 11:34 AM Reply Quote 0
              Mykle1 Project Sponsor Module Developer @banbutcher
              @banbutcher
              Personally, I want the mirror as close to the monitor glass as possible. I’ve made a few mirrors. In all cases, that meant removing the front bezel from the monitor at the very least. With that in mind, do it whatever way makes you happiest. :-)
              • T Offline
                thedoorsfanatic @banbutcher
                @banbutcher
                I wish I knew how to disassemble a monitor
                I tried it once but the monitor did not survive because of short circuit
                So far I just glued the mirror glas onto the frame of my 24 inch Benq monitor
                https://youtu.be/T5bE2UmlyXQ
                My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                B F 2 Replies Last reply Mar 20, 2020, 7:01 PM Reply Quote 0
                  BKeyport Module Developer @thedoorsfanatic
                  @thedoorsfanatic clearly you cut a wire when pulling it apart. use plastic, patience, and small moves.
                  • F Offline
                    Fozi Project Sponsor @thedoorsfanatic
                    @thedoorsfanatic Try to find a guide on youtube on how to disassemble a benq monitor. I just googled for “disassebmle benq monitor” and found a few videos on yt. Maybe your model is amongst them.
