    monitor - disassemble or not?
    9 Posts 7 Posters 2.7k Views 7 Watching
      bendardenne
      It’s usually not hard to take it out and it allows you to have the monitor closer to the glass, it makes the monitor less thick so your frame doesn’t have to be so deep, it allows you to place your monitor more freely…
      I guess it depends on the monitor, but with mine I wouldn’t have had a good result with the frame still on, it was way too clunky and thick.
        banbutcher
        i have a 23" LG monitor, thin enough but i might still look at removing the plastic!
        thanks folks! :)
          Mykle1 Project Sponsor Module Developer @banbutcher
          @banbutcher
          Personally, I want the mirror as close to the monitor glass as possible. I’ve made a few mirrors. In all cases, that meant removing the front bezel from the monitor at the very least. With that in mind, do it whatever way makes you happiest. :-)
          • thedoorsfanaticT Offline
            thedoorsfanatic @banbutcher
            @banbutcher
            I wish I knew how to disassemble a monitor
            I tried it once but the monitor did not survive because of short circuit
            So far I just glued the mirror glas onto the frame of my 24 inch Benq monitor
            https://youtu.be/T5bE2UmlyXQ
            My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
            BKeyportB FoziF 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @thedoorsfanatic
              @thedoorsfanatic clearly you cut a wire when pulling it apart. use plastic, patience, and small moves.
              • FoziF Offline
                Fozi Project Sponsor @thedoorsfanatic
                @thedoorsfanatic Try to find a guide on youtube on how to disassemble a benq monitor. I just googled for “disassebmle benq monitor” and found a few videos on yt. Maybe your model is amongst them.
