    MMM-Astrology
    23 Posts 5 Posters 13.9k Views 5 Watching
      @cowboysdude said in MMM-Astrology:
      I made a couple of changes so do a git pull when you get back
      I told you I’d get back to you. :-)
      I successfully justified your module to the right using your css suggestion. However, the header css would not move the header permanently, meaning, as the module loads it appears as if it’s oriented correctly, but then it snaps back over to the left when the module does load. Now, I don’t know if you noticed from any of my pictures, but I don’t use headers at all, none. I would be more than pleased to be able to remove the header altogether. I noticed there is no header: in the config.js so how would I go about removing that.
      Also, the logo? for Taurus seems to not load. There is a little symbol there. It’s not very clear at all in the picture. Broken link?
      Otherwise, here it is.
      • cowboysdudeC Offline
        Interesting…
        Do a git pull and add this to your custom.css
         .MMM-Astrology .content {
          margin-left: 11%;
          .MMM-Astrology .title {
        	margin-left: 11%;
        Adjust your % accordingly :)
          Another one? I only ask because I did one earlier this afternoon. Ok, I’ll do another git pull and follow your suggestions. I’ll get back to you. Thanks for helping me out.
            @cowboysdude
            As it turns out I did need another git pull, and with some adjustments to your css advice I was able to justify to the right. However, if I choose a width (250px) then the header becomes 2 lines and only the top line justified to the right. I still would like to not have a header at all, as I mentioned earlier.
            The only other problem is the icon at the beginning of the horoscope. Even at 400px width yields the picture below
            Let me not forget to thank you for your work here, so, thanks :thumbsup_tone1:
              You can always use xsmall for the header ;) OHHHHHHHHH and the icons… that was my fault I didn’t upload them LOL
              Was in a hurry… as for the title you can adjust that as well in the custom.css… under MMM-Astrology .title {
              font-size: ??;
              One more ‘git pull’… :) Made some other changes.
                One more ‘git pull’… Made some other changes.
                Sorry to make you work on your birthday!
                  @Mykle1 said in MMM-Astrology:
                  Heck no… I don’t stop working LOL Plus I’m taking the day off so I don’t mind at all :)
                    sam5168
                    I know the cool site where you can read many interesting articles on this topic https://horo.io
                      cowboysdude Module Developer @sam5168
                      @sam5168 If they have an api I can ;)
                      • RyFi13R Offline
                        RyFi13
                        Hey @cowboysdude! My wife has thoroughly enjoyed your Astrology app! I finally got around to updating everything (including the 256 MM2 updates) and I’m stumped! I can’t seem to get anything in the CSS file to impact anything with the MMM-Astro app alignment or sizes. I really just want to increase the font size and alight everything similar to the previous poster. Icon trapped into the beginning of the text. Right now, it appears as though the logo, sign, and date are aligned left. Content all flush to the right, but chaos on the left side. I’m attempting to upload an image, however it says it’s too large. Hopefully I explained that thoroughly enough. Please help! Thank you in advance!
                          cowboysdude Module Developer @RyFi13
                          @RyFi13 I will send you a PM
