    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 952.9k Views 77 Watching
      Mr.Meeseeks
      @Jopyth I’ve added on mine ability to refresh browser, update mm and modules, and send alerts. I’ll probably work on installing and configuring modules next.
      I’ll push merge soon
      CAAAAN DOO!👍
      J 2 Replies Last reply
        Jopyth Moderator @Mr.Meeseeks
        @Mr.Meeseeks Nice!
          plumcraft
          @Mr-Meeseeks
          Looking forward your updates.
            @Mr.Meeseeks Also if you think you are at a stage where we can work together, feel free to make the pull request early, and I will have a look and see if I can help.
            Otherwise I will concentrate on other stuff, which you have not already implemented.
            J 1 Reply Last reply
            • cowboysdudeC
              Yeah but if you make the changes to the config.js it takes all the fun out learning for people who really want to… I’m not programmer and this would be WAY above my head but I do enjoy tinkering with things… I realize that in the end a total package would push the mirror into more people’s lap though… progress and this would be just a natural progression of things.
              You guys that do this stuff are truly amazing and those of us who can’t Thank you!
                Mr.Meeseeks
                It’s the MAGIC MIRRORS TO THE MASSES MOVEMENT!! M⁴!
                CAAAAN DOO!👍
                  Jopyth Moderator
                  Work in progress:
                  Config is not yet saved and adding a new module is not yet supported, but the rest is mostly ready.
                  R 1 Reply Last reply
                  Reply Quote 10
                    PaulB
                    @Jopyth
                    This is an awesome module. Thanks for creating :)
                    I tried to download it via “sudo apt-get install https://github.com/Jopyth/MMM-Remote-Control”
                    but nevertheless I get the following notice:
                    E: Unable to locate package https
                    E: Couldn’t find any package by regex ‘https://github.com/Jopyth’
                    I hope you have a tip, how I can solve this :)
                    Kind regards,
                    Paul
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @PaulB
                      @PaulB as the install instruction says git clone https://github.com/Jopyth/MMM-Remote-Control.git
                      https://github.com/Jopyth/MMM-Remote-Control#installation
                      P 1 Reply Last reply
                      Reply Quote 4
                        PaulB @strawberry 3.141
                        @strawberry-3.141 as always… thanks a lot :)
                        If you still have the nerves to answer just one more question :) I would like to how to use the html web script.
                        I ve searched the IP-Adress but nether the local IP nor the IP4 would work.
                        Do you have a betting guess which I should use?
                        Thanks a lot!
                        • strawberry 3.141S
                          @PaulB by default you should be able to access the remote by
                          http://raspberrypi:8080/remote.html
                          or run ifconfig to research your ip
                          then access it via
                          http://ip:8080/remote.html
                            Jopyth Moderator @strawberry 3.141
                            @PaulB In addtition to what @strawberry-3.141 wrote, you can also set a position in the config, and it should display the URL on the mirror, for example like this:
                                module: 'MMM-Remote-Control',
                                header: 'Remote Control',
                                position: 'bottom_right'
                            D 1 Reply Last reply
                              done @Jopyth
                              @Jopyth
                              This is a hardcore module from what I see here. Nice one!
                              Say, would “turn on monitor for x minutes” be a possible feature?
                              Like a sleep timer on the TV.
                              I come from an energy saving point of view and “turning on” is great but you know how we are. We always forget to turn things off.
                              Cheers
                              done
                                Jopyth Moderator @done
                                @done Thank you.
                                Yes this is certainly possible. Would it make sense to also make an option, which automatically switches off the screen at the start up then? So the “default” would be, that the screen is off, but you can switch it on for x Minutes?
                                  done @Jopyth
                                  @Jopyth I think I don’t understand the difference? :D
                                  Or you’re talking about the default sleep time that is already set at start up of the pi?
                                  So that, no matter what you do, you set a (default) timer of i. e. 15 minutes when the hdmi switches off.
                                    PaulB
                                    @strawberry-3-141 @Jopyth Thank you very much for your help.
                                    My error was following one:
                                    “https://192.168 …”
                                    Now, I ve fixed it in “http://192.168 …”
                                    –> It’s the small things that matter, I guess :D
                                    Thanks a lot.
                                    @Jopyth I love it :-) Well done!
                                      rvdgeer @Jopyth
                                      @Jopyth Amazing work so far!
                                      Can’t wait for the ‘finished’ product (read: next major version).
                                      Reply Quote 2
                                        compoti
                                        The remote-control works really great, thank you very much for this module!
                                        Reply Quote 2
                                          Mr.Meeseeks
                                          Holy smokes @Jopyth you refactored a lot, it’s taking me some time to merge my changes in
                                          CAAAAN DOO!👍
                                            Jopyth Moderator @Jopyth
                                            @Mr.Meeseeks Even though I did not make that properly clear, but that was my intention, behind asking you to make the pull request early, sorry about that. :/ I can help with the merging, though, let me know.
                                            @Jopyth said in MMM-Remote-Control:
                                            • 13
                                            • 14
                                            • 4 / 14
