    How to post code on the forum - For absolute beginners
    26 Posts 10 Posters 32.3k Views 9 Watching
    • evroomE
      evroom
      Still having trouble with < and >, actually < x m l _ l I n e > (without spaces).
      <xml_line>
      Or:
      </xml_line>
      I did:
      < x m l _ l I n e >
      and
      < / x m l _ l I n e >
      Remove the spaces to get my result.
      I was given a workaround for this, but of course forgot it.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom the workaround is to add a space after <
        • evroomE
          evroom @sdetweil
          Can’t be it. He said hopefully.
          So when I have numerous lines of xml, I need to add a space after every < ?
          And when doing so I actually get:
          < xml_line>
            sdetweil @evroom
            @evroom yes… the space will show, uuuuuuuugly…
            you would think that the three backquotes would turn off text interpretation…
            but sadly not…
            • Mykle1M
              I’m posting to this topic in the hope that it will be read by users that are not aware of the protocol for posting.
              Your code posts should look like this:
                          disabled: false,
                          module: "MMM-EARTH",
                          position: "bottom right",
                              mode: "Natural",
                              rotateInterval: 15000,
                              animationSpeed: 0,
                              MaxWidth: "45%",
                              MaxHeight: "45%",
              NOT like this:
              disabled: false,
              module: “MMM-EARTH”,
              position: “bottom right”,
              mode: “Natural”,
              animationSpeed: 0,
              MaxWidth: “45%”,
              MaxHeight: “45%”,
              Peace!
                JediJah
                Thanks for this post. I am about to put it to good use.
                  sdetweil @Mykle1
                  @Mykle1 how did you do that? (the two steps!)
                  • Mykle1M
                    @sdetweil said in How to post code on the forum - For absolute beginners:
                    I’m lost.
                      sdetweil @Mykle1
                      so, how do they do that?
                      1. mark the text of the ‘code’
                      2. hit the button above the editor that looks like </>
                      • Mykle1M
                        Hit the button above the editor first.
                        That gives you the two sets of backticks, In between them, already highlighted, are the words, “Post code here”.
                        and you get this
                          sdetweil @Mykle1
                          @Mykle1 i like to write the text, add the code in between the words, then mark the code sections…
                          • Mykle1M
                            I never use the button. Learned backticks early on. Was so happy about it that I wrote the tutorial Jun 28, 2017, 7:40 PM
