    mmm assistant mk2
    112 Posts 12 Posters 70.0k Views 11 Watching
      sdmydbr9
      hi,first of all thanks for all the awesome modules, i just installed assistant mk2 and its working fine but im stuck with the configuration i was trying to integrate mmm-tool warning text and i have no idea where to place the warning text and along with that you might as well guide me where to place the transcript hook from mmm spotify control… totally beginner here… probably this is guess is a dumb question.
        [[global:former-user]]
        hi, what is mmm-tool warning text for you ?
          sdmydbr @Guest
          @Bugsounet
          I have somehow managed to do it but now whenever i start my magic mirror chromium automatically starts and takes me to the Auth screen
          Update: turning on assistsay: true, in the tool module leads to this… i turned that off and now it’s working fine… is there a work around for this?
            assistantSay: true
            Your assistant says vocal warning (need myMagicWord feature of MMM-AssistantMk2)
            I don’t really understand what do you want to do
              sdmydbr9 @Guest
              @Bugsounet i just did a fresh install of magicmirror on raspberry pi4 and it was working fine and then i installed assistant mk2, when i launch the magic mirror i get the only black screen,when i open the developers console i dont see anything except “internal server error and bla bla”… heres my log
              npm start
              > magicmirror@2.11.0 start /home/pi/MagicMirror
              [2020-05-30 18:51:14.372] [LOG]    Starting MagicMirror: v2.11.0
              [2020-05-30 18:51:14.378] [LOG]    Loading config ...
              [2020-05-30 18:51:14.382] [LOG]    Loading module helpers ...
              [2020-05-30 18:51:14.383] [LOG]    No helper found for module: alert.
              [2020-05-30 18:51:14.414] [LOG]    Initializing new module helper ...
              [2020-05-30 18:51:14.415] [LOG]    Module helper loaded: updatenotification
              [2020-05-30 18:51:14.415] [LOG]    No helper found for module: clock.
              [2020-05-30 18:51:14.693] [LOG]    Initializing new module helper ...
              [2020-05-30 18:51:14.694] [LOG]    Module helper loaded: calendar
              [2020-05-30 18:51:14.694] [LOG]    No helper found for module: compliments.
              [2020-05-30 18:51:14.695] [LOG]    No helper found for module: currentweather.
              [2020-05-30 18:51:14.695] [LOG]    No helper found for module: weatherforecast.
              [2020-05-30 18:51:14.695] [LOG]    No helper found for module: MMM-AssistantMk2.
              [2020-05-30 18:51:14.714] [LOG]    Initializing new module helper ...
              [2020-05-30 18:51:14.714] [LOG]    Module helper loaded: newsfeed
              [2020-05-30 18:51:14.715] [LOG]    All module helpers loaded.
              [2020-05-30 18:51:14.799] [LOG]    Starting server on port 8080 ...
              [2020-05-30 18:51:14.809] [LOG]    Server started ...
              [2020-05-30 18:51:14.809] [LOG]    Connecting socket for: updatenotification
              [2020-05-30 18:51:14.810] [LOG]    Connecting socket for: calendar
              [2020-05-30 18:51:14.811] [LOG]    Starting node helper for: calendar
              [2020-05-30 18:51:14.811] [LOG]    Connecting socket for: newsfeed
              [2020-05-30 18:51:14.812] [LOG]    Starting module: newsfeed
              [2020-05-30 18:51:14.812] [LOG]    Sockets connected & modules started ...
              [2020-05-30 18:51:14.897] [LOG]    Launching application.
              [2020-05-30 18:51:15.084] [ERROR]  Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/index.html'
                 at Object.openSync (fs.js:447:3)
                 at Object.func (electron/js2c/asar.js:138:31)
                 at Object.func [as openSync] (electron/js2c/asar.js:138:31)
                 at Object.readFileSync (fs.js:349:35)
                 at Object.fs.readFileSync (electron/js2c/asar.js:580:40)
                 at /home/pi/MagicMirror/js/server.js:71:17
                 at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)
                 at next (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:137:13)
                 at Route.dispatch (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:112:3)
              [2020-05-30 18:51:30.160] [LOG]    Shutting down server...
              [2020-05-30 18:51:30.163] [LOG]    Stopping module helper: updatenotification
              [2020-05-30 18:51:30.163] [LOG]    Stopping module helper: calendar
              [2020-05-30 18:51:30.164] [LOG]    Stopping module helper: newsfeed
              S D 2 Replies Last reply Reply Quote 0
                sdetweil @sdmydbr9
                @sdmydbr9 said in mmm assistant mk2:
                looks like something erased the index.html
                git checkout index.html
                  sdmydbr9 @sdetweil
                  @sdetweil hi thanks for replying, i followed your step but the magicmirror starts, it beeps and then the magicmirror exits. my logs are as follows
                  [2020-05-30 20:47:38.468] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-05-30 20:47:38.475] [LOG]    Loading config ...
                  [2020-05-30 20:47:38.480] [LOG]    Loading module helpers ...
                  [2020-05-30 20:47:38.481] [LOG]    No helper found for module: alert.
                  [2020-05-30 20:47:38.521] [LOG]    Initializing new module helper ...
                  [2020-05-30 20:47:38.522] [LOG]    Module helper loaded: updatenotification
                  [2020-05-30 20:47:38.523] [LOG]    No helper found for module: clock.
                  [2020-05-30 20:47:38.865] [LOG]    Initializing new module helper ...
                  [2020-05-30 20:47:38.866] [LOG]    Module helper loaded: calendar
                  [2020-05-30 20:47:38.867] [LOG]    No helper found for module: compliments.
                  [2020-05-30 20:47:38.867] [LOG]    No helper found for module: currentweather.
                  [2020-05-30 20:47:39.581] [LOG]    Initializing new module helper ...
                  [2020-05-30 20:47:39.581] [LOG]    Module helper loaded: MMM-AssistantMk2
                  [2020-05-30 20:47:39.582] [LOG]    No helper found for module: weatherforecast.
                  [2020-05-30 20:47:39.605] [LOG]    Initializing new module helper ...
                  [2020-05-30 20:47:39.605] [LOG]    Module helper loaded: newsfeed
                  [2020-05-30 20:47:39.605] [LOG]    All module helpers loaded.
                  [2020-05-30 20:47:39.704] [LOG]    Starting server on port 8080 ...
                  [2020-05-30 20:47:39.717] [LOG]    Server started ...
                  [2020-05-30 20:47:39.718] [LOG]    Connecting socket for: updatenotification
                  [2020-05-30 20:47:39.719] [LOG]    Connecting socket for: calendar
                  [2020-05-30 20:47:39.720] [LOG]    Starting node helper for: calendar
                  [2020-05-30 20:47:39.720] [LOG]    Connecting socket for: MMM-AssistantMk2
                  [2020-05-30 20:47:39.721] [LOG]    Connecting socket for: newsfeed
                  [2020-05-30 20:47:39.721] [LOG]    Starting module: newsfeed
                  [2020-05-30 20:47:39.722] [LOG]    Sockets connected & modules started ...
                  [2020-05-30 20:47:39.820] [LOG]    Launching application.
                  [2020-05-30 20:47:41.603] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                  [2020-05-30 20:47:41.671] [LOG]    [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                  [2020-05-30 20:47:41.677] [LOG]    [AMK2] Recipe is loaded: reboot.js
                  [2020-05-30 20:47:41.679] [LOG]    [AMK2] Recipe is loaded: screen_onoff.js
                  [2020-05-30 20:47:41.682] [LOG]    [AMK2] Recipe is loaded: shutdown.js
                  [2020-05-30 20:47:41.684] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  [2020-05-30 20:47:41.802] [LOG]    [AMK2] Temporal storage directory is clearing.
                  [2020-05-30 20:47:42.570] [LOG]    [AMK2] assistant ready
                  /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                  npm ERR! code ELIFECYCLE
                  npm ERR! syscall spawn
                  npm ERR! file sh
                  npm ERR! errno ENOENT
                  npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.11.0 start script.
                  npm ERR!     /home/pi/.npm/_logs/2020-05-30T15_17_42_655Z-debug.log
                    sdetweil @sdmydbr9
                    __atomic_store_8
                    I thought @Bugsounet had fixed that … anyhow
                    see the answer here for the steps to workaround this problem
                    https://stackoverflow.com/questions/58561090/mmm-hotword-crashing
                      sdmydbr9 @sdetweil
                      @sdetweil hi again, i did everything mentioned in that post but the behaviour doesnt change, it works for one time and next time i restart the magic mirror it gets back to missing index.html. its an endless loop. please help what am i doing wrong
                        sdetweil @sdmydbr9
                        @sdmydbr9 no idea sorry
                          sdmydbr9 @sdetweil
                          @sdetweil here is another log. i might have missed something in the process i just cant figure out
                          npm start
                          [2020-05-30 22:33:42.189] [LOG]    Starting MagicMirror: v2.11.0
                          [2020-05-30 22:33:42.195] [LOG]    Loading config ...
                          [2020-05-30 22:33:42.200] [LOG]    Loading module helpers ...
                          [2020-05-30 22:33:42.201] [LOG]    No helper found for module: alert.
                          [2020-05-30 22:33:42.233] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:42.233] [LOG]    Module helper loaded: updatenotification
                          [2020-05-30 22:33:42.234] [LOG]    No helper found for module: clock.
                          [2020-05-30 22:33:42.234] [LOG]    No helper found for module: MMM-Volume.
                          [2020-05-30 22:33:42.811] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:42.811] [LOG]    Module helper loaded: MMM-TelegramBot
                          [2020-05-30 22:33:43.715] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:43.716] [LOG]    Check MagicMirror version for node helper 'MMM-GoogleBirthdaysProvider' - Minimum version:  2.6.0 - Current version: 2.11.0
                          [2020-05-30 22:33:43.716] [LOG]    Version is ok!
                          [2020-05-30 22:33:43.716] [LOG]    Module helper loaded: MMM-GoogleBirthdaysProvider
                          [2020-05-30 22:33:43.949] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:43.950] [LOG]    Module helper loaded: calendar
                          [2020-05-30 22:33:43.950] [LOG]    No helper found for module: compliments.
                          [2020-05-30 22:33:43.957] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:43.958] [LOG]    Module helper loaded: MMM-Spotify
                          [2020-05-30 22:33:44.610] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.610] [LOG]    Module helper loaded: MMM-AssistantMk2
                          [2020-05-30 22:33:44.835] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.836] [LOG]    Module helper loaded: MMM-DailyBibleVerse
                          [2020-05-30 22:33:44.836] [LOG]    No helper found for module: MMM-Carousel.
                          [2020-05-30 22:33:44.850] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.850] [LOG]    Module helper loaded: MMM-Tools
                          [2020-05-30 22:33:44.851] [LOG]    No helper found for module: MMM-OpenmapWeather.
                          [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-PushBulletNotifications.
                          [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-WeeklySchedule.
                          [2020-05-30 22:33:44.852] [LOG]    No helper found for module: weatherforecast.
                          [2020-05-30 22:33:44.853] [LOG]    No helper found for module: calendar_monthly.
                          [2020-05-30 22:33:44.853] [LOG]    No helper found for module: MagicMirror-QuoteCatalog.
                          [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-AirQuality.
                          [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-ATM.
                          [2020-05-30 22:33:44.902] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.903] [LOG]    Module helper loaded: MMM-Remote-Control
                          [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                          [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-Strava.
                          [2020-05-30 22:33:44.913] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.914] [LOG]    Module helper loaded: MMM-GoogleFit
                          [2020-05-30 22:33:44.941] [LOG]    Initializing new module helper ...
                          [2020-05-30 22:33:44.941] [LOG]    Module helper loaded: newsfeed
                          [2020-05-30 22:33:44.941] [LOG]    All module helpers loaded.
                          [2020-05-30 22:33:45.023] [LOG]    Starting server on port 8080 ...
                          [2020-05-30 22:33:45.028] [LOG]    Server started ...
                          [2020-05-30 22:33:45.029] [LOG]    Connecting socket for: updatenotification
                          [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-TelegramBot
                          [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-GoogleBirthdaysProvider
                          [2020-05-30 22:33:45.033] [LOG]    MMM-GoogleBirthdaysProvider: Server is running
                          [2020-05-30 22:33:45.033] [LOG]    Connecting socket for: calendar
                          [2020-05-30 22:33:45.034] [LOG]    Starting node helper for: calendar
                          [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-Spotify
                          [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-AssistantMk2
                          [2020-05-30 22:33:45.036] [LOG]    Connecting socket for: MMM-DailyBibleVerse
                          [2020-05-30 22:33:45.037] [LOG]    Started node_helper.js for MMM-DailyBibleVerse.
                          [2020-05-30 22:33:45.037] [LOG]    Connecting socket for: MMM-Tools
                          [2020-05-30 22:33:45.039] [LOG]    Connecting socket for: MMM-Remote-Control
                          [2020-05-30 22:33:45.040] [LOG]    Starting node helper for: MMM-Remote-Control
                          [2020-05-30 22:33:45.043] [LOG]    Connecting socket for: MMM-GoogleFit
                          [2020-05-30 22:33:45.044] [LOG]    MMM-GoogleFit helper started...
                          [2020-05-30 22:33:45.045] [LOG]    Connecting socket for: newsfeed
                          [2020-05-30 22:33:45.045] [LOG]    Starting module: newsfeed
                          [2020-05-30 22:33:45.046] [LOG]    Sockets connected & modules started ...
                          [2020-05-30 22:33:45.115] [LOG]    Launching application.
                          [2020-05-30 22:33:48.324] [LOG]    Create new calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics - Interval: 300000
                          [2020-05-30 22:33:48.335] [LOG]    Create new calendar fetcher for url: http://localhost:8080/MMM-iCloud-Client/birthdays - Interval: 300000
                          [2020-05-30 22:33:48.338] [LOG]    Create new calendar fetcher for url: http://localhost:8080/mmm-googlebirthdaysprovider - Interval: 300000
                          [2020-05-30 22:33:48.339] [LOG]    Create new calendar fetcher for url: http://p55-caldav.icloud.com/published/2/MTYyNDUxMzU4NTMxNjI0NYC75Drqr02v7z3JKqrHR4_Vd4jSfdBaOYaOyJzk__IX - Interval: 300000
                          [2020-05-30 22:33:48.363] [LOG]    [AMK2] Recipe is loaded: with-MMM-TelegramBot.js
                          [2020-05-30 22:33:48.390] [LOG]    [AMK2] Recipe is loaded: reboot.js
                          [2020-05-30 22:33:48.392] [LOG]    [AMK2] Recipe is loaded: with-MMM-Spotify
                          [2020-05-30 22:33:48.396] [LOG]    MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
                          [2020-05-30 22:33:48.645] [LOG]    Create new news fetcher for url: https://timesofindia.indiatimes.com/rssfeeds/-2128936835.cms - Interval: 300000
                          [2020-05-30 22:33:48.964] [LOG]    [SPOTIFY] MMM-Spotify Version: 1.4.1
                          [2020-05-30 22:33:49.711] [LOG]    [AMK2] Temporal storage directory is clearing.
                          [2020-05-30 22:33:49.814] [ERROR]  Calendar Error. Could not fetch calendar:  http://localhost:8080/MMM-iCloud-Client/birthdays 404: Not Found
                          [2020-05-30 22:33:50.755] [LOG]    [AMK2] assistant ready
                          [2020-05-30 22:33:50.830] [LOG]    [AMK2] Conversation starts.
                          [2020-05-30 22:33:50.831] [LOG]    [AMK2] Started with text query: brief today
                          [2020-05-30 22:33:51.094] [LOG]    Whoops! There was an uncaught exception...
                          [2020-05-30 22:33:51.094] [ERROR]  [Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'] {
                            errno: -2,
                            code: 'ENOENT',
                            syscall: 'open',
                            path: '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'
                          [2020-05-30 22:33:51.097] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2020-05-30 22:33:51.097] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2020-05-30 22:33:51.100] [ERROR]  Calendar Error. Could not fetch calendar:  https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics Error: certificate has expired
                              at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                              at TLSSocket.emit (events.js:200:13)
                              at TLSSocket._finishInit (_tls_wrap.js:792:8)
                              at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
                            code: 'CERT_HAS_EXPIRED'
                          [2020-05-30 22:33:51.112] [LOG]    {"votd":{"text":"“In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?”","content":"In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?","display_ref":"Psalm 56:4","reference":"Psalm 56:4","permalink":"https:\/\/www.biblegateway.com\/passage\/?version=NIV&search=Psalm%2056:4","copyright":"Copyright ©  1973, 1978, 1984, 2011 by Biblica","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Ps.56.4","day":"30","month":"05","year":"2020","version":"New International Version","version_id":"NIV"}}
                          [2020-05-30 22:33:53.061] [LOG]    { requestId: '**************************' } { profileFile: 'default.json', lang: 'en-US' }
                          [2020-05-30 22:33:53.063] [LOG]    [AMK2] Device Action: { requestId: '***************************' }
                          [2020-05-30 22:33:53.068] [LOG]    [AMK2] Assistant Text Response:
                          [2020-05-30 22:33:53.072] [ERROR]  [AMK2] - temporal HTML creation fails. E: Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/temp.html'
                          [2020-05-30 22:33:53.081] [ERROR]  [AMK2] E: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                              at doWrite (_stream_writable.js:413:19)
                              at writeOrBuffer (_stream_writable.js:401:5)
                              at WriteStream.Writable.write (_stream_writable.js:301:11)
                              at Conversation.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:222:21)
                              at Conversation.emit (events.js:200:13)
                              at ClientDuplexStream.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
                              at ClientDuplexStream.emit (events.js:200:13)
                              at addChunk (_stream_readable.js:294:12)
                              at readableAddChunk (_stream_readable.js:275:11)
                              at ClientDuplexStream.Readable.push (_stream_readable.js:210:10)
                              at Object.onReceiveMessage (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1292:19)
                              at InterceptingListener.recvMessageWithContext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:607:19)
                              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:706:14
                          [2020-05-30 22:33:53.083] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.085] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                              at writeAfterEnd (_stream_writable.js:250:14)
                              at WriteStream.Writable.write (_stream_writable.js:298:5)
                          [2020-05-30 22:33:53.086] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.087] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.088] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.090] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.091] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.092] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.093] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.095] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.096] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.097] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.098] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.100] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.100] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.102] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.103] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.104] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.105] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.106] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.108] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.109] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.110] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.112] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.113] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.115] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.116] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.118] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                          [2020-05-30 22:33:53.119] [LOG]    [AMK2] Some error happens. Try again.
                          [2020-05-30 22:33:53.122] [LOG]    foundHook []
                          [2020-05-30 22:33:53.325] [LOG]    Speaker error: 1
                          [2020-05-30 22:33:53.326] [LOG]    Whoops! There was an uncaught exception...
                          [2020-05-30 22:33:53.327] [ERROR]  1
                          [2020-05-30 22:33:53.327] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2020-05-30 22:33:53.327] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [2020-05-30 22:34:09.077] [LOG]    Shutting down server...
                          [2020-05-30 22:34:09.078] [LOG]    Stopping module helper: updatenotification
                          [2020-05-30 22:34:09.079] [LOG]    Stopping module helper: MMM-TelegramBot
                          [2020-05-30 22:34:09.080] [LOG]    MMM-GoogleBirthdaysProvider: Stopping helper
                          [2020-05-30 22:34:09.080] [LOG]    Stopping module helper: calendar
                          [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-Spotify
                          [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-AssistantMk2
                          [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-DailyBibleVerse
                          [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-Tools
                          [2020-05-30 22:34:09.083] [LOG]    Stopping module helper: MMM-GoogleFit
                          [2020-05-30 22:34:09.084] [LOG]    Stopping module helper: newsfeed
                            reddyman
                            I am having the same issue, if you fix it, please let me know.
                            S S 2 Replies Last reply Reply Quote 0
                              sdetweil @reddyman
                              @reddyman @sdmydbr9 here is the new mk2, wiki, maybe it will help
                              https://github.com/bugsounet/MMM-AssistantMk2/wiki
                              Bugsounet has stepped away for a while… so follow the instructions carefully
                                sdmydbr @reddyman
                                @reddyman hi, I found a work around… maybe it’s temporary but I got it working by Downgrading my assistant mk2 to the previous working version… cheers
                                  reddyman
                                  @sdmydbr I wanted to try downgrading MK2 but I wasn’t sure how to. Sorry, I’m a bit inexperienced in all of this. What is the command? And what version did you use? Thank you!
                                    sdmydbr9 @reddyman
                                    @reddyman well here are the steps for downgrading
                                    1. Go to “Commits”
                                    2. Click the “<>” icon to the right of the desired commit
                                    3. Select Clone or Download
                                    4. Download ZIP
                                    any old version will be fine(not too old) i used may26,2020 version…
                                      reddyman
                                      @sdmydbr Dang, that is so simple. Here I was trying to figure out how to do it commands.
                                      Okay, but now, am I crazy or is MMM-AssistantMK2 now completely taken off github? Because I can’t find it anywhere. Damn it, right when I found a solution…
                                      I don’t suppose you or @sdetweil know where I could find a backup? Thank you again!
                                        sdmydbr9 @reddyman
                                        @reddyman im surprised too, the github page has gone dark… about the assistant mk2 package, i have the zip file that i downloaded earlier, and i would be happy to share it with you! and no… i have no clue of any back ups… cheers
                                        • E Offline
                                          electros Project Sponsor @sdmydbr9
                                          @sdmydbr9 I have same problem with mmm assistant mk2. Can you please send me that zip archive from old version? I can send you a message with my email address.
                                          Thank you.
                                            see this post
                                            • 1 / 6
