    mmm assistant mk2
    112 Posts 12 Posters 55.0k Views 11 Watching
      A Former User
      assistantSay: true
      Your assistant says vocal warning (need myMagicWord feature of MMM-AssistantMk2)
      I don’t really understand what do you want to do
        sdmydbr9 @Guest
        @Bugsounet i just did a fresh install of magicmirror on raspberry pi4 and it was working fine and then i installed assistant mk2, when i launch the magic mirror i get the only black screen,when i open the developers console i dont see anything except “internal server error and bla bla”… heres my log
        npm start
        > magicmirror@2.11.0 start /home/pi/MagicMirror
        [2020-05-30 18:51:14.372] [LOG]    Starting MagicMirror: v2.11.0
        [2020-05-30 18:51:14.378] [LOG]    Loading config ...
        [2020-05-30 18:51:14.382] [LOG]    Loading module helpers ...
        [2020-05-30 18:51:14.383] [LOG]    No helper found for module: alert.
        [2020-05-30 18:51:14.414] [LOG]    Initializing new module helper ...
        [2020-05-30 18:51:14.415] [LOG]    Module helper loaded: updatenotification
        [2020-05-30 18:51:14.415] [LOG]    No helper found for module: clock.
        [2020-05-30 18:51:14.693] [LOG]    Initializing new module helper ...
        [2020-05-30 18:51:14.694] [LOG]    Module helper loaded: calendar
        [2020-05-30 18:51:14.694] [LOG]    No helper found for module: compliments.
        [2020-05-30 18:51:14.695] [LOG]    No helper found for module: currentweather.
        [2020-05-30 18:51:14.695] [LOG]    No helper found for module: weatherforecast.
        [2020-05-30 18:51:14.695] [LOG]    No helper found for module: MMM-AssistantMk2.
        [2020-05-30 18:51:14.714] [LOG]    Initializing new module helper ...
        [2020-05-30 18:51:14.714] [LOG]    Module helper loaded: newsfeed
        [2020-05-30 18:51:14.715] [LOG]    All module helpers loaded.
        [2020-05-30 18:51:14.799] [LOG]    Starting server on port 8080 ...
        [2020-05-30 18:51:14.809] [LOG]    Server started ...
        [2020-05-30 18:51:14.809] [LOG]    Connecting socket for: updatenotification
        [2020-05-30 18:51:14.810] [LOG]    Connecting socket for: calendar
        [2020-05-30 18:51:14.811] [LOG]    Starting node helper for: calendar
        [2020-05-30 18:51:14.811] [LOG]    Connecting socket for: newsfeed
        [2020-05-30 18:51:14.812] [LOG]    Starting module: newsfeed
        [2020-05-30 18:51:14.812] [LOG]    Sockets connected & modules started ...
        [2020-05-30 18:51:14.897] [LOG]    Launching application.
        [2020-05-30 18:51:15.084] [ERROR]  Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/index.html'
           at Object.openSync (fs.js:447:3)
           at Object.func (electron/js2c/asar.js:138:31)
           at Object.func [as openSync] (electron/js2c/asar.js:138:31)
           at Object.readFileSync (fs.js:349:35)
           at Object.fs.readFileSync (electron/js2c/asar.js:580:40)
           at /home/pi/MagicMirror/js/server.js:71:17
           at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)
           at next (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:137:13)
           at Route.dispatch (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:112:3)
        [2020-05-30 18:51:30.160] [LOG]    Shutting down server...
        [2020-05-30 18:51:30.163] [LOG]    Stopping module helper: updatenotification
        [2020-05-30 18:51:30.163] [LOG]    Stopping module helper: calendar
        [2020-05-30 18:51:30.164] [LOG]    Stopping module helper: newsfeed
        S D 2 Replies Last reply Reply Quote 0
          sdetweil @sdmydbr9
          @sdmydbr9 said in mmm assistant mk2:
          looks like something erased the index.html
          git checkout index.html
            sdmydbr9 @sdetweil
            @sdetweil hi thanks for replying, i followed your step but the magicmirror starts, it beeps and then the magicmirror exits. my logs are as follows
            [2020-05-30 20:47:38.468] [LOG]    Starting MagicMirror: v2.11.0
            [2020-05-30 20:47:38.475] [LOG]    Loading config ...
            [2020-05-30 20:47:38.480] [LOG]    Loading module helpers ...
            [2020-05-30 20:47:38.481] [LOG]    No helper found for module: alert.
            [2020-05-30 20:47:38.521] [LOG]    Initializing new module helper ...
            [2020-05-30 20:47:38.522] [LOG]    Module helper loaded: updatenotification
            [2020-05-30 20:47:38.523] [LOG]    No helper found for module: clock.
            [2020-05-30 20:47:38.865] [LOG]    Initializing new module helper ...
            [2020-05-30 20:47:38.866] [LOG]    Module helper loaded: calendar
            [2020-05-30 20:47:38.867] [LOG]    No helper found for module: compliments.
            [2020-05-30 20:47:38.867] [LOG]    No helper found for module: currentweather.
            [2020-05-30 20:47:39.581] [LOG]    Initializing new module helper ...
            [2020-05-30 20:47:39.581] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-05-30 20:47:39.582] [LOG]    No helper found for module: weatherforecast.
            [2020-05-30 20:47:39.605] [LOG]    Initializing new module helper ...
            [2020-05-30 20:47:39.605] [LOG]    Module helper loaded: newsfeed
            [2020-05-30 20:47:39.605] [LOG]    All module helpers loaded.
            [2020-05-30 20:47:39.704] [LOG]    Starting server on port 8080 ...
            [2020-05-30 20:47:39.717] [LOG]    Server started ...
            [2020-05-30 20:47:39.718] [LOG]    Connecting socket for: updatenotification
            [2020-05-30 20:47:39.719] [LOG]    Connecting socket for: calendar
            [2020-05-30 20:47:39.720] [LOG]    Starting node helper for: calendar
            [2020-05-30 20:47:39.720] [LOG]    Connecting socket for: MMM-AssistantMk2
            [2020-05-30 20:47:39.721] [LOG]    Connecting socket for: newsfeed
            [2020-05-30 20:47:39.721] [LOG]    Starting module: newsfeed
            [2020-05-30 20:47:39.722] [LOG]    Sockets connected & modules started ...
            [2020-05-30 20:47:39.820] [LOG]    Launching application.
            [2020-05-30 20:47:41.603] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            [2020-05-30 20:47:41.671] [LOG]    [AMK2] Recipe is loaded: hide_and_show_all_modules.js
            [2020-05-30 20:47:41.677] [LOG]    [AMK2] Recipe is loaded: reboot.js
            [2020-05-30 20:47:41.679] [LOG]    [AMK2] Recipe is loaded: screen_onoff.js
            [2020-05-30 20:47:41.682] [LOG]    [AMK2] Recipe is loaded: shutdown.js
            [2020-05-30 20:47:41.684] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [2020-05-30 20:47:41.802] [LOG]    [AMK2] Temporal storage directory is clearing.
            [2020-05-30 20:47:42.570] [LOG]    [AMK2] assistant ready
            /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
            npm ERR! code ELIFECYCLE
            npm ERR! syscall spawn
            npm ERR! file sh
            npm ERR! errno ENOENT
            npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! Failed at the magicmirror@2.11.0 start script.
            npm ERR!     /home/pi/.npm/_logs/2020-05-30T15_17_42_655Z-debug.log
              sdetweil @sdmydbr9
              __atomic_store_8
              I thought @Bugsounet had fixed that … anyhow
              see the answer here for the steps to workaround this problem
              https://stackoverflow.com/questions/58561090/mmm-hotword-crashing
                sdmydbr9 @sdetweil
                @sdetweil hi again, i did everything mentioned in that post but the behaviour doesnt change, it works for one time and next time i restart the magic mirror it gets back to missing index.html. its an endless loop. please help what am i doing wrong
                  sdetweil @sdmydbr9
                  @sdmydbr9 no idea sorry
                    sdmydbr9 @sdetweil
                    @sdetweil here is another log. i might have missed something in the process i just cant figure out
                    npm start
                    [2020-05-30 22:33:42.189] [LOG]    Starting MagicMirror: v2.11.0
                    [2020-05-30 22:33:42.195] [LOG]    Loading config ...
                    [2020-05-30 22:33:42.200] [LOG]    Loading module helpers ...
                    [2020-05-30 22:33:42.201] [LOG]    No helper found for module: alert.
                    [2020-05-30 22:33:42.233] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:42.233] [LOG]    Module helper loaded: updatenotification
                    [2020-05-30 22:33:42.234] [LOG]    No helper found for module: clock.
                    [2020-05-30 22:33:42.234] [LOG]    No helper found for module: MMM-Volume.
                    [2020-05-30 22:33:42.811] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:42.811] [LOG]    Module helper loaded: MMM-TelegramBot
                    [2020-05-30 22:33:43.715] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:43.716] [LOG]    Check MagicMirror version for node helper 'MMM-GoogleBirthdaysProvider' - Minimum version:  2.6.0 - Current version: 2.11.0
                    [2020-05-30 22:33:43.716] [LOG]    Version is ok!
                    [2020-05-30 22:33:43.716] [LOG]    Module helper loaded: MMM-GoogleBirthdaysProvider
                    [2020-05-30 22:33:43.949] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:43.950] [LOG]    Module helper loaded: calendar
                    [2020-05-30 22:33:43.950] [LOG]    No helper found for module: compliments.
                    [2020-05-30 22:33:43.957] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:43.958] [LOG]    Module helper loaded: MMM-Spotify
                    [2020-05-30 22:33:44.610] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.610] [LOG]    Module helper loaded: MMM-AssistantMk2
                    [2020-05-30 22:33:44.835] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.836] [LOG]    Module helper loaded: MMM-DailyBibleVerse
                    [2020-05-30 22:33:44.836] [LOG]    No helper found for module: MMM-Carousel.
                    [2020-05-30 22:33:44.850] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.850] [LOG]    Module helper loaded: MMM-Tools
                    [2020-05-30 22:33:44.851] [LOG]    No helper found for module: MMM-OpenmapWeather.
                    [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-PushBulletNotifications.
                    [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-WeeklySchedule.
                    [2020-05-30 22:33:44.852] [LOG]    No helper found for module: weatherforecast.
                    [2020-05-30 22:33:44.853] [LOG]    No helper found for module: calendar_monthly.
                    [2020-05-30 22:33:44.853] [LOG]    No helper found for module: MagicMirror-QuoteCatalog.
                    [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-AirQuality.
                    [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-ATM.
                    [2020-05-30 22:33:44.902] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.903] [LOG]    Module helper loaded: MMM-Remote-Control
                    [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                    [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-Strava.
                    [2020-05-30 22:33:44.913] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.914] [LOG]    Module helper loaded: MMM-GoogleFit
                    [2020-05-30 22:33:44.941] [LOG]    Initializing new module helper ...
                    [2020-05-30 22:33:44.941] [LOG]    Module helper loaded: newsfeed
                    [2020-05-30 22:33:44.941] [LOG]    All module helpers loaded.
                    [2020-05-30 22:33:45.023] [LOG]    Starting server on port 8080 ...
                    [2020-05-30 22:33:45.028] [LOG]    Server started ...
                    [2020-05-30 22:33:45.029] [LOG]    Connecting socket for: updatenotification
                    [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-TelegramBot
                    [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-GoogleBirthdaysProvider
                    [2020-05-30 22:33:45.033] [LOG]    MMM-GoogleBirthdaysProvider: Server is running
                    [2020-05-30 22:33:45.033] [LOG]    Connecting socket for: calendar
                    [2020-05-30 22:33:45.034] [LOG]    Starting node helper for: calendar
                    [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-Spotify
                    [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-AssistantMk2
                    [2020-05-30 22:33:45.036] [LOG]    Connecting socket for: MMM-DailyBibleVerse
                    [2020-05-30 22:33:45.037] [LOG]    Started node_helper.js for MMM-DailyBibleVerse.
                    [2020-05-30 22:33:45.037] [LOG]    Connecting socket for: MMM-Tools
                    [2020-05-30 22:33:45.039] [LOG]    Connecting socket for: MMM-Remote-Control
                    [2020-05-30 22:33:45.040] [LOG]    Starting node helper for: MMM-Remote-Control
                    [2020-05-30 22:33:45.043] [LOG]    Connecting socket for: MMM-GoogleFit
                    [2020-05-30 22:33:45.044] [LOG]    MMM-GoogleFit helper started...
                    [2020-05-30 22:33:45.045] [LOG]    Connecting socket for: newsfeed
                    [2020-05-30 22:33:45.045] [LOG]    Starting module: newsfeed
                    [2020-05-30 22:33:45.046] [LOG]    Sockets connected & modules started ...
                    [2020-05-30 22:33:45.115] [LOG]    Launching application.
                    [2020-05-30 22:33:48.324] [LOG]    Create new calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics - Interval: 300000
                    [2020-05-30 22:33:48.335] [LOG]    Create new calendar fetcher for url: http://localhost:8080/MMM-iCloud-Client/birthdays - Interval: 300000
                    [2020-05-30 22:33:48.338] [LOG]    Create new calendar fetcher for url: http://localhost:8080/mmm-googlebirthdaysprovider - Interval: 300000
                    [2020-05-30 22:33:48.339] [LOG]    Create new calendar fetcher for url: http://p55-caldav.icloud.com/published/2/MTYyNDUxMzU4NTMxNjI0NYC75Drqr02v7z3JKqrHR4_Vd4jSfdBaOYaOyJzk__IX - Interval: 300000
                    [2020-05-30 22:33:48.363] [LOG]    [AMK2] Recipe is loaded: with-MMM-TelegramBot.js
                    [2020-05-30 22:33:48.390] [LOG]    [AMK2] Recipe is loaded: reboot.js
                    [2020-05-30 22:33:48.392] [LOG]    [AMK2] Recipe is loaded: with-MMM-Spotify
                    [2020-05-30 22:33:48.396] [LOG]    MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
                    [2020-05-30 22:33:48.645] [LOG]    Create new news fetcher for url: https://timesofindia.indiatimes.com/rssfeeds/-2128936835.cms - Interval: 300000
                    [2020-05-30 22:33:48.964] [LOG]    [SPOTIFY] MMM-Spotify Version: 1.4.1
                    [2020-05-30 22:33:49.711] [LOG]    [AMK2] Temporal storage directory is clearing.
                    [2020-05-30 22:33:49.814] [ERROR]  Calendar Error. Could not fetch calendar:  http://localhost:8080/MMM-iCloud-Client/birthdays 404: Not Found
                    [2020-05-30 22:33:50.755] [LOG]    [AMK2] assistant ready
                    [2020-05-30 22:33:50.830] [LOG]    [AMK2] Conversation starts.
                    [2020-05-30 22:33:50.831] [LOG]    [AMK2] Started with text query: brief today
                    [2020-05-30 22:33:51.094] [LOG]    Whoops! There was an uncaught exception...
                    [2020-05-30 22:33:51.094] [ERROR]  [Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'] {
                      errno: -2,
                      code: 'ENOENT',
                      syscall: 'open',
                      path: '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'
                    [2020-05-30 22:33:51.097] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-05-30 22:33:51.097] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-05-30 22:33:51.100] [ERROR]  Calendar Error. Could not fetch calendar:  https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics Error: certificate has expired
                        at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                        at TLSSocket.emit (events.js:200:13)
                        at TLSSocket._finishInit (_tls_wrap.js:792:8)
                        at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
                      code: 'CERT_HAS_EXPIRED'
                    [2020-05-30 22:33:51.112] [LOG]    {"votd":{"text":"“In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?”","content":"In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?","display_ref":"Psalm 56:4","reference":"Psalm 56:4","permalink":"https:\/\/www.biblegateway.com\/passage\/?version=NIV&search=Psalm%2056:4","copyright":"Copyright ©  1973, 1978, 1984, 2011 by Biblica","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Ps.56.4","day":"30","month":"05","year":"2020","version":"New International Version","version_id":"NIV"}}
                    [2020-05-30 22:33:53.061] [LOG]    { requestId: '**************************' } { profileFile: 'default.json', lang: 'en-US' }
                    [2020-05-30 22:33:53.063] [LOG]    [AMK2] Device Action: { requestId: '***************************' }
                    [2020-05-30 22:33:53.068] [LOG]    [AMK2] Assistant Text Response:
                    [2020-05-30 22:33:53.072] [ERROR]  [AMK2] - temporal HTML creation fails. E: Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/temp.html'
                    [2020-05-30 22:33:53.081] [ERROR]  [AMK2] E: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                        at doWrite (_stream_writable.js:413:19)
                        at writeOrBuffer (_stream_writable.js:401:5)
                        at WriteStream.Writable.write (_stream_writable.js:301:11)
                        at Conversation.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:222:21)
                        at Conversation.emit (events.js:200:13)
                        at ClientDuplexStream.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
                        at ClientDuplexStream.emit (events.js:200:13)
                        at addChunk (_stream_readable.js:294:12)
                        at readableAddChunk (_stream_readable.js:275:11)
                        at ClientDuplexStream.Readable.push (_stream_readable.js:210:10)
                        at Object.onReceiveMessage (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1292:19)
                        at InterceptingListener.recvMessageWithContext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:607:19)
                        at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:706:14
                    [2020-05-30 22:33:53.083] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.085] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                        at writeAfterEnd (_stream_writable.js:250:14)
                        at WriteStream.Writable.write (_stream_writable.js:298:5)
                    [2020-05-30 22:33:53.086] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.087] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.088] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.090] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.091] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.092] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.093] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.095] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.096] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.097] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.098] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.100] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.100] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.102] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.103] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.104] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.105] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.106] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.108] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.109] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.110] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.112] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.113] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.115] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.116] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.118] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                    [2020-05-30 22:33:53.119] [LOG]    [AMK2] Some error happens. Try again.
                    [2020-05-30 22:33:53.122] [LOG]    foundHook []
                    [2020-05-30 22:33:53.325] [LOG]    Speaker error: 1
                    [2020-05-30 22:33:53.326] [LOG]    Whoops! There was an uncaught exception...
                    [2020-05-30 22:33:53.327] [ERROR]  1
                    [2020-05-30 22:33:53.327] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-05-30 22:33:53.327] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-05-30 22:34:09.077] [LOG]    Shutting down server...
                    [2020-05-30 22:34:09.078] [LOG]    Stopping module helper: updatenotification
                    [2020-05-30 22:34:09.079] [LOG]    Stopping module helper: MMM-TelegramBot
                    [2020-05-30 22:34:09.080] [LOG]    MMM-GoogleBirthdaysProvider: Stopping helper
                    [2020-05-30 22:34:09.080] [LOG]    Stopping module helper: calendar
                    [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-Spotify
                    [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-AssistantMk2
                    [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-DailyBibleVerse
                    [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-Tools
                    [2020-05-30 22:34:09.083] [LOG]    Stopping module helper: MMM-GoogleFit
                    [2020-05-30 22:34:09.084] [LOG]    Stopping module helper: newsfeed
                      reddyman
                      I am having the same issue, if you fix it, please let me know.
                      S S 2 Replies Last reply Reply Quote 0
                        sdetweil @reddyman
                        @reddyman @sdmydbr9 here is the new mk2, wiki, maybe it will help
                        https://github.com/bugsounet/MMM-AssistantMk2/wiki
                        Bugsounet has stepped away for a while… so follow the instructions carefully
                        • 11
                        • 12
                        • 1 / 12
