    mmm assistant mk2
    112 Posts 12 Posters 70.0k Views 11 Watching
      sdetweil @sdmydbr9
      @sdmydbr9 said in mmm assistant mk2:
      __atomic_store_8
      I thought @Bugsounet had fixed that … anyhow
      see the answer here for the steps to workaround this problem
      https://stackoverflow.com/questions/58561090/mmm-hotword-crashing
        sdmydbr9 @sdetweil
        @sdetweil hi again, i did everything mentioned in that post but the behaviour doesnt change, it works for one time and next time i restart the magic mirror it gets back to missing index.html. its an endless loop. please help what am i doing wrong
          sdetweil @sdmydbr9
          @sdmydbr9 no idea sorry
            sdmydbr9 @sdetweil
            @sdetweil here is another log. i might have missed something in the process i just cant figure out
            npm start
            > magicmirror@2.11.0 start /home/pi/MagicMirror
            [2020-05-30 22:33:42.189] [LOG]    Starting MagicMirror: v2.11.0
            [2020-05-30 22:33:42.195] [LOG]    Loading config ...
            [2020-05-30 22:33:42.200] [LOG]    Loading module helpers ...
            [2020-05-30 22:33:42.201] [LOG]    No helper found for module: alert.
            [2020-05-30 22:33:42.233] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:42.233] [LOG]    Module helper loaded: updatenotification
            [2020-05-30 22:33:42.234] [LOG]    No helper found for module: clock.
            [2020-05-30 22:33:42.234] [LOG]    No helper found for module: MMM-Volume.
            [2020-05-30 22:33:42.811] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:42.811] [LOG]    Module helper loaded: MMM-TelegramBot
            [2020-05-30 22:33:43.715] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:43.716] [LOG]    Check MagicMirror version for node helper 'MMM-GoogleBirthdaysProvider' - Minimum version:  2.6.0 - Current version: 2.11.0
            [2020-05-30 22:33:43.716] [LOG]    Version is ok!
            [2020-05-30 22:33:43.716] [LOG]    Module helper loaded: MMM-GoogleBirthdaysProvider
            [2020-05-30 22:33:43.949] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:43.950] [LOG]    Module helper loaded: calendar
            [2020-05-30 22:33:43.950] [LOG]    No helper found for module: compliments.
            [2020-05-30 22:33:43.957] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:43.958] [LOG]    Module helper loaded: MMM-Spotify
            [2020-05-30 22:33:44.610] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.610] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-05-30 22:33:44.835] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.836] [LOG]    Module helper loaded: MMM-DailyBibleVerse
            [2020-05-30 22:33:44.836] [LOG]    No helper found for module: MMM-Carousel.
            [2020-05-30 22:33:44.850] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.850] [LOG]    Module helper loaded: MMM-Tools
            [2020-05-30 22:33:44.851] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-PushBulletNotifications.
            [2020-05-30 22:33:44.852] [LOG]    No helper found for module: MMM-WeeklySchedule.
            [2020-05-30 22:33:44.852] [LOG]    No helper found for module: weatherforecast.
            [2020-05-30 22:33:44.853] [LOG]    No helper found for module: calendar_monthly.
            [2020-05-30 22:33:44.853] [LOG]    No helper found for module: MagicMirror-QuoteCatalog.
            [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-AirQuality.
            [2020-05-30 22:33:44.854] [LOG]    No helper found for module: MMM-ATM.
            [2020-05-30 22:33:44.902] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.903] [LOG]    Module helper loaded: MMM-Remote-Control
            [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-PlexNowPlaying.
            [2020-05-30 22:33:44.903] [LOG]    No helper found for module: MMM-Strava.
            [2020-05-30 22:33:44.913] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.914] [LOG]    Module helper loaded: MMM-GoogleFit
            [2020-05-30 22:33:44.941] [LOG]    Initializing new module helper ...
            [2020-05-30 22:33:44.941] [LOG]    Module helper loaded: newsfeed
            [2020-05-30 22:33:44.941] [LOG]    All module helpers loaded.
            [2020-05-30 22:33:45.023] [LOG]    Starting server on port 8080 ...
            [2020-05-30 22:33:45.028] [LOG]    Server started ...
            [2020-05-30 22:33:45.029] [LOG]    Connecting socket for: updatenotification
            [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-TelegramBot
            [2020-05-30 22:33:45.030] [LOG]    Connecting socket for: MMM-GoogleBirthdaysProvider
            [2020-05-30 22:33:45.033] [LOG]    MMM-GoogleBirthdaysProvider: Server is running
            [2020-05-30 22:33:45.033] [LOG]    Connecting socket for: calendar
            [2020-05-30 22:33:45.034] [LOG]    Starting node helper for: calendar
            [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-Spotify
            [2020-05-30 22:33:45.035] [LOG]    Connecting socket for: MMM-AssistantMk2
            [2020-05-30 22:33:45.036] [LOG]    Connecting socket for: MMM-DailyBibleVerse
            [2020-05-30 22:33:45.037] [LOG]    Started node_helper.js for MMM-DailyBibleVerse.
            [2020-05-30 22:33:45.037] [LOG]    Connecting socket for: MMM-Tools
            [2020-05-30 22:33:45.039] [LOG]    Connecting socket for: MMM-Remote-Control
            [2020-05-30 22:33:45.040] [LOG]    Starting node helper for: MMM-Remote-Control
            [2020-05-30 22:33:45.043] [LOG]    Connecting socket for: MMM-GoogleFit
            [2020-05-30 22:33:45.044] [LOG]    MMM-GoogleFit helper started...
            [2020-05-30 22:33:45.045] [LOG]    Connecting socket for: newsfeed
            [2020-05-30 22:33:45.045] [LOG]    Starting module: newsfeed
            [2020-05-30 22:33:45.046] [LOG]    Sockets connected & modules started ...
            [2020-05-30 22:33:45.115] [LOG]    Launching application.
            [2020-05-30 22:33:48.324] [LOG]    Create new calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics - Interval: 300000
            [2020-05-30 22:33:48.335] [LOG]    Create new calendar fetcher for url: http://localhost:8080/MMM-iCloud-Client/birthdays - Interval: 300000
            [2020-05-30 22:33:48.338] [LOG]    Create new calendar fetcher for url: http://localhost:8080/mmm-googlebirthdaysprovider - Interval: 300000
            [2020-05-30 22:33:48.339] [LOG]    Create new calendar fetcher for url: http://p55-caldav.icloud.com/published/2/MTYyNDUxMzU4NTMxNjI0NYC75Drqr02v7z3JKqrHR4_Vd4jSfdBaOYaOyJzk__IX - Interval: 300000
            [2020-05-30 22:33:48.363] [LOG]    [AMK2] Recipe is loaded: with-MMM-TelegramBot.js
            [2020-05-30 22:33:48.390] [LOG]    [AMK2] Recipe is loaded: reboot.js
            [2020-05-30 22:33:48.392] [LOG]    [AMK2] Recipe is loaded: with-MMM-Spotify
            [2020-05-30 22:33:48.396] [LOG]    MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
            [2020-05-30 22:33:48.645] [LOG]    Create new news fetcher for url: https://timesofindia.indiatimes.com/rssfeeds/-2128936835.cms - Interval: 300000
            [2020-05-30 22:33:48.964] [LOG]    [SPOTIFY] MMM-Spotify Version: 1.4.1
            [2020-05-30 22:33:49.711] [LOG]    [AMK2] Temporal storage directory is clearing.
            [2020-05-30 22:33:49.814] [ERROR]  Calendar Error. Could not fetch calendar:  http://localhost:8080/MMM-iCloud-Client/birthdays 404: Not Found
            [2020-05-30 22:33:50.755] [LOG]    [AMK2] assistant ready
            [2020-05-30 22:33:50.830] [LOG]    [AMK2] Conversation starts.
            [2020-05-30 22:33:50.831] [LOG]    [AMK2] Started with text query: brief today
            [2020-05-30 22:33:51.094] [LOG]    Whoops! There was an uncaught exception...
            [2020-05-30 22:33:51.094] [ERROR]  [Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'] {
              errno: -2,
              code: 'ENOENT',
              syscall: 'open',
              path: '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/1590858230831.mp3'
            [2020-05-30 22:33:51.097] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-05-30 22:33:51.097] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-05-30 22:33:51.100] [ERROR]  Calendar Error. Could not fetch calendar:  https://www.calendarlabs.com/ical-calendar/ics/33/India_Holidays.ics Error: certificate has expired
                at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                at TLSSocket.emit (events.js:200:13)
                at TLSSocket._finishInit (_tls_wrap.js:792:8)
                at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
              code: 'CERT_HAS_EXPIRED'
            [2020-05-30 22:33:51.112] [LOG]    {"votd":{"text":"“In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?”","content":"In God, whose word I praise— in God I trust and am not afraid. What can mere mortals do to me?","display_ref":"Psalm 56:4","reference":"Psalm 56:4","permalink":"https:\/\/www.biblegateway.com\/passage\/?version=NIV&search=Psalm%2056:4","copyright":"Copyright ©  1973, 1978, 1984, 2011 by Biblica","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Ps.56.4","day":"30","month":"05","year":"2020","version":"New International Version","version_id":"NIV"}}
            [2020-05-30 22:33:53.061] [LOG]    { requestId: '**************************' } { profileFile: 'default.json', lang: 'en-US' }
            [2020-05-30 22:33:53.063] [LOG]    [AMK2] Device Action: { requestId: '***************************' }
            [2020-05-30 22:33:53.068] [LOG]    [AMK2] Assistant Text Response:
            [2020-05-30 22:33:53.072] [ERROR]  [AMK2] - temporal HTML creation fails. E: Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/MMM-AssistantMk2/tmp/temp.html'
            [2020-05-30 22:33:53.081] [ERROR]  [AMK2] E: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                at doWrite (_stream_writable.js:413:19)
                at writeOrBuffer (_stream_writable.js:401:5)
                at WriteStream.Writable.write (_stream_writable.js:301:11)
                at Conversation.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:222:21)
                at Conversation.emit (events.js:200:13)
                at ClientDuplexStream.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
                at ClientDuplexStream.emit (events.js:200:13)
                at addChunk (_stream_readable.js:294:12)
                at readableAddChunk (_stream_readable.js:275:11)
                at ClientDuplexStream.Readable.push (_stream_readable.js:210:10)
                at Object.onReceiveMessage (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1292:19)
                at InterceptingListener.recvMessageWithContext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:607:19)
                at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:706:14
            [2020-05-30 22:33:53.083] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.085] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
                at writeAfterEnd (_stream_writable.js:250:14)
                at WriteStream.Writable.write (_stream_writable.js:298:5)
            [2020-05-30 22:33:53.086] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.087] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.088] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.090] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.091] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.092] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.093] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.095] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.096] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.097] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.098] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.100] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.100] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.102] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.103] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.104] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.105] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.106] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.108] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.109] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.110] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.112] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.113] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.115] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.116] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.118] [ERROR]  [AMK2] E: Error [ERR_STREAM_WRITE_AFTER_END]: write after end
            [2020-05-30 22:33:53.119] [LOG]    [AMK2] Some error happens. Try again.
            [2020-05-30 22:33:53.122] [LOG]    foundHook []
            [2020-05-30 22:33:53.325] [LOG]    Speaker error: 1
            [2020-05-30 22:33:53.326] [LOG]    Whoops! There was an uncaught exception...
            [2020-05-30 22:33:53.327] [ERROR]  1
            [2020-05-30 22:33:53.327] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-05-30 22:33:53.327] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-05-30 22:34:09.077] [LOG]    Shutting down server...
            [2020-05-30 22:34:09.078] [LOG]    Stopping module helper: updatenotification
            [2020-05-30 22:34:09.079] [LOG]    Stopping module helper: MMM-TelegramBot
            [2020-05-30 22:34:09.080] [LOG]    MMM-GoogleBirthdaysProvider: Stopping helper
            [2020-05-30 22:34:09.080] [LOG]    Stopping module helper: calendar
            [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-Spotify
            [2020-05-30 22:34:09.081] [LOG]    Stopping module helper: MMM-AssistantMk2
            [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-DailyBibleVerse
            [2020-05-30 22:34:09.082] [LOG]    Stopping module helper: MMM-Tools
            [2020-05-30 22:34:09.083] [LOG]    Stopping module helper: MMM-GoogleFit
            [2020-05-30 22:34:09.084] [LOG]    Stopping module helper: newsfeed
              reddyman
              I am having the same issue, if you fix it, please let me know.
              S S 2 Replies Last reply Reply Quote 0
                sdetweil @reddyman
                @reddyman @sdmydbr9 here is the new mk2, wiki, maybe it will help
                https://github.com/bugsounet/MMM-AssistantMk2/wiki
                Bugsounet has stepped away for a while… so follow the instructions carefully
                  sdmydbr @reddyman
                  @reddyman hi, I found a work around… maybe it’s temporary but I got it working by Downgrading my assistant mk2 to the previous working version… cheers
                    reddyman
                    @sdmydbr I wanted to try downgrading MK2 but I wasn’t sure how to. Sorry, I’m a bit inexperienced in all of this. What is the command? And what version did you use? Thank you!
                      sdmydbr9 @reddyman
                      @reddyman well here are the steps for downgrading
                      1. Go to “Commits”
                      2. Click the “<>” icon to the right of the desired commit
                      3. Select Clone or Download
                      4. Download ZIP
                      any old version will be fine(not too old) i used may26,2020 version…
                        reddyman
                        @sdmydbr Dang, that is so simple. Here I was trying to figure out how to do it commands.
                        Okay, but now, am I crazy or is MMM-AssistantMK2 now completely taken off github? Because I can’t find it anywhere. Damn it, right when I found a solution…
                        I don’t suppose you or @sdetweil know where I could find a backup? Thank you again!
                          sdmydbr9 @reddyman
                          @reddyman im surprised too, the github page has gone dark… about the assistant mk2 package, i have the zip file that i downloaded earlier, and i would be happy to share it with you! and no… i have no clue of any back ups… cheers
                          • E Offline
                            electros Project Sponsor @sdmydbr9
                            @sdmydbr9 I have same problem with mmm assistant mk2. Can you please send me that zip archive from old version? I can send you a message with my email address.
                            Thank you.
                              [[global:former-user]]
                              see this post
                                reddyman
                                @Bugsounet Ahh that makes sense. I’m sorry to hear that project is dead but I understand. I’m sorry you had to deal with so many crappy and ugly people; they don’t deserve anything from someone who put in so much hardwork and sweat as you have.
                                Gah, I just wish I didn’t update my mirror yesterday. The last time I updated it was in February and everything was working perfectly. And of course when I updated, I didn’t bother making a backup. Valuable lesson learned though!
                                I’ll take down my mirror for now I guess. But best of luck to you Bugsounet to anything you do in the future!
                                  @reddyman : don’t remove it ;)
                                  I am ready to deploy the new assistant
                                  AND … I am ready to deploy the new Assistant2Display
                                  Edit:
                                  • MMM-Assistant2Display is deployed
                                    reddyman
                                    I had thought you meant you were stepping down completely. I misunderstood, this is wonderful news!
                                    I will be checking for days for your new assistant then… and let me know if you take donations!
                                      For clarify why closing it:
                                      • In this forum, there 2 gays who arcel me and there are now stopped
                                      So, I don’t want to continue with AMk2 name (sorry @sean)
                                      too many bad memories are in mind with this module name
                                        dvbit
                                        Hi @Bugsounet thanks !
                                        Your work is really appreciated.
                                        I wish I knew js to help.
                                        However if you need polite and Linux expert beamta testers or simply financial contribution please let me know.
                                          @dvbit: thx :)
                                          Time -> 23:30
                                          Deploy new Assistant in 30 min !
                                            dvbit
                                            Bien heureux de t’aider si tu veux. Je suis italien mais je parle francais. Meme si c’est seulement pour traduire ;-)
                                            • 1 / 6
