    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
      chassain 0 @rubenix
      @rubenix or pi 4 8GB. :) i have a lot of modules switching with the module mm pages and i have no problem with rain map (power on during 24h/24)
      C rubenixR 2 Replies Last reply
        chassain 0 @chassain 0
        @chassain-0 i have a rasp pi4 4GB
        • rubenixR
          rubenix @chassain 0
          @chassain-0 yeah something more powerful indeed; the most the better.
          anyway have no problem at all with any of my pages but when I switch to RAIN-MAP page (by alexa, gesture or automatically on rotation) i see the cpu usage when It shows on the mirror…
          hardware upgrade coming soon…
          C 1 Reply Last reply
            chassain 0 @rubenix
            • JalibuJ
              Jalibu Module Developer
              I think about pre-rendering the map animation once as gif image in the backend using phantom instead of live rendering on the frontend. I’ll test that when time allows…
              rubenixR 1 Reply Last reply
              • rubenixR
                rubenix @Jalibu
                @Jalibu sounds nice!
                • FoziF
                  Fozi Project Sponsor @rubenix
                  @rubenix thank you so much for your thorough and comprehensive analysis and feedback!
                  I will now disable the above mentioned 5 3rd party modules nd enablle them one by and check if they’d interfere with MMM-RAIN-MAP. I’ll keep you all posted!
                  • rubenixR
                    rubenix @Fozi
                    @Fozi 6 actually. i’ve posted pages & pages indicator @same line :face_with_stuck-out_tongue_winking_eye:
                    FoziF 1 Reply Last reply
                    • FoziF
                      @rubenix sorry, you’re right…my mistake. I just restarted MM and got an update notification for MMM-RAIN-MAP. I’ll pull that and test right away with the new version.
                      • rubenixR
                        rubenix @Fozi
                        @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
                        • JalibuJ
                          I have a alpha version for a backend-generated (pre-rendered) map.
                          Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
                          rubenixR C 2 Replies Last reply
                          • rubenixR
                            rubenix @Jalibu
                            @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
                              chassain 0 @Jalibu
                              @Jalibu i can again
                              • FoziF
                                @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
                                • JalibuJ
                                  The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
                                  The little problem is that prerendering is kind of ultra heavy :-D
                                  My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
                                  For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
                                  • FoziF
                                    I FOUND THE “CULPRIT”!!
                                    Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
                                    And Bingo!
                                    Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
                                    I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
                                    And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
                                    Thanks to all of you and @Jalibu for helping me!
                                      requiemmg
                                      Hi @jalibu,
                                      I really like this module, but I fear that the memory issue still persists.
                                      Just cloned the repo, the module runs fine for some minutes or up to one hour, then the Raspi freezes. I am running on a 1GB 3B+ with 4 pages.
                                      Anything you can do about it?
                                      rubenixR JalibuJ 2 Replies Last reply
                                      • rubenixR
                                        rubenix @requiemmg
                                        @requiemmg since I updated the pi to a Pi 4 4GB have no issues at all…came from a pi3 1GB too
                                        • JalibuJ
                                          Jalibu Module Developer @requiemmg
                                          @requiemmg
                                          yepp, as @rubenix mentioned, 1GB memory is unfortunately too little :-/
                                          On my Raspi 4, 4GB it just works perfectly fine.
                                          I already tried to optimize the rendering to get it working with limited resources, but without success ¯\(ツ)/¯
                                          • rubenixR
                                            rubenix @Jalibu
                                            @Jalibu & @requiemmg was tempted to go for the 8GB one, but I can confirm 4Gb is more than enought; go for it and use the pi3 for another project :love-you_gesture_light_skin_tone:
                                            • 10
                                            • 2 / 10
