    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 309.3k Views 42 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @Jalibu
      @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
      can I change that is showing the next 2 hours
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ Offline
        Jalibu Module Developer @Stoffbeuteluwe
        @Stoffbeuteluwe nope, the data provider only serves weather history
        • rubenixR Offline
          rubenix
          @Fozi We’ve a MM setup with 10 pages on it (its more a Family panel than a mirror; so useful for us to keep activities, list and routines and important info for a daily basis)
          Anyway the modules that matches yours:
          default modules:
          newsfeed,
          alert,
          updatenotification --> config disabled: true
          Third Party modules:
          MMM-AlexaControl,
          MMM-Pages & MMM-page-indicator,
          MMM-RemoteControl,
          MMM-GroveGestures,
          MMM-Tools,
          Im pretty sure the rpi freezes due to RAIN-MAP animation itself and not because of any module interaction but am not 100% sure.
          I’ve updated the module but nothing changes and mirror freezes if I show the RAIN-MAP (got it hidden on start and call it by alexaControl whenever I wanna show it).
          If I disabled the module, never freezes (have it on for hours with no problems --> we usually shutdown the rpi when going to bed…If I enabled the module and make it visible on the mirror it freezes at some point (maybe minutes, maybe hours…but it freezes indeed). If I start the mirror (remember default RAIN-MAP not visible) and never show the RAIN-MAP never freezes. If I disable the module (disabled: true) in config cpu usage & temperature on the pi are fine but If I enable it goes up to 40-70% at some stages and temperature goes over 70ºC sometimes…(not good)
          I increase value of animationSpeed on module config must say improves rpi performance (I’ve set it @800 and its fine for a longer period and maybe if we’re lucky the pi does not freeze). Could be the zoom in/out feature on module itself…don’t know as its hard to catch a useful log to look at. No error at all on pm2 logs.
          Here my newbie contribution; hope we can found something as module looks nice on the Mirror!
          I will keep an eye on this topic and, indeed, post it here if find something that helps…
          Cheers!
          FoziF 1 Reply Last reply Reply Quote 1
          • rubenixR Offline
            rubenix
            Also must to say that Ive a raspbian virtual machine on my vmware workstation where I do all my tests with module on it and never freezes; actually Ive got the beauties “MMM-ISS-Live” & “MMM-Earth-Live” that my raspi could not handle and works flawlessly on the VM…
            BTW its a pi3B (not the B+) --> so maybe time to upgrade to Asus Tinker Board or pi 4 4GB…
              chassain 0 @rubenix
              @rubenix or pi 4 8GB. :) i have a lot of modules switching with the module mm pages and i have no problem with rain map (power on during 24h/24)
              C rubenixR 2 Replies Last reply Reply Quote 0
                chassain 0 @chassain 0
                @chassain-0 i have a rasp pi4 4GB
                • rubenixR Offline
                  rubenix @chassain 0
                  @chassain-0 yeah something more powerful indeed; the most the better.
                  anyway have no problem at all with any of my pages but when I switch to RAIN-MAP page (by alexa, gesture or automatically on rotation) i see the cpu usage when It shows on the mirror…
                  hardware upgrade coming soon…
                    chassain 0 @rubenix
                    • JalibuJ Offline
                      I think about pre-rendering the map animation once as gif image in the backend using phantom instead of live rendering on the frontend. I’ll test that when time allows…
                      rubenixR 1 Reply Last reply Reply Quote 0
                      • rubenixR Offline
                        rubenix @Jalibu
                        @Jalibu sounds nice!
                        • FoziF Offline
                          Fozi Project Sponsor @rubenix
                          @rubenix thank you so much for your thorough and comprehensive analysis and feedback!
                          I will now disable the above mentioned 5 3rd party modules nd enablle them one by and check if they’d interfere with MMM-RAIN-MAP. I’ll keep you all posted!
                          • rubenixR Offline
                            rubenix @Fozi
                            @Fozi 6 actually. i’ve posted pages & pages indicator @same line :face_with_stuck-out_tongue_winking_eye:
                            • FoziF Offline
                              @rubenix sorry, you’re right…my mistake. I just restarted MM and got an update notification for MMM-RAIN-MAP. I’ll pull that and test right away with the new version.
                              • rubenixR Offline
                                rubenix @Fozi
                                @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
                                • JalibuJ Offline
                                  I have a alpha version for a backend-generated (pre-rendered) map.
                                  Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
                                  rubenixR C 2 Replies Last reply Reply Quote 0
                                  • rubenixR Offline
                                    rubenix @Jalibu
                                    @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
                                      chassain 0 @Jalibu
                                      @Jalibu i can again
                                      • FoziF Offline
                                        @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
                                        • JalibuJ Offline
                                          The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
                                          The little problem is that prerendering is kind of ultra heavy :-D
                                          My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
                                          For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
                                          • FoziF Offline
                                            I FOUND THE “CULPRIT”!!
                                            Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
                                            And Bingo!
                                            Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
                                            I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
                                            And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
                                            Thanks to all of you and @Jalibu for helping me!
                                            • 10
                                            • 2 / 10
