    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • FoziF
      Fozi Project Sponsor @lavolp3
      @lavolp3 just a question as I have the same issue and @Jalibu and I tried his latest release, but no success on my side.
      Which modules do you have activated?
      I assume that the module might interfere with another module, but I am not sure which one. I’d like to compare your activated modules with mine and maybe I can find out which one is identical and might cause the conflict. Here’s a list of my modules, which are separated over two pages:
      Page1:
      newsfeed,
      alert,
      updatenotification,
      MMM-PIR-Sensor,
      MMM-AlexaControl,
      MMM-MyCalendar,
      MMM-page-indicator,
      MMM-Pages,
      MMM-withings,
      MMM-Sonos,
      MMM-DarkSkyForecast,
      MMM-DWD-WarnWeather,
      MMM-MyScoreBoard,
      MMM-Podcast2,
      2x MMM-PublicTransportHafas,
      MMM-google-route,
      MMM-RemoteControl,
      MMM-GroveGestures,
      Page2:
      netatmo,
      MMM-Tools,
      mmm-hue-lights,
      MMM-Homematic, .
      C 1 Reply Last reply
        chassain 0 @Fozi
        @Fozi the best way is to add disabled: true at each module one by one and restart mm beetwen
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @Jalibu
          @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
          can I change that is showing the next 2 hours
          JalibuJ 1 Reply Last reply
          • JalibuJ
            Jalibu Module Developer @Stoffbeuteluwe
            @Stoffbeuteluwe nope, the data provider only serves weather history
            D 1 Reply Last reply
            • rubenixR
              rubenix
              @Fozi We’ve a MM setup with 10 pages on it (its more a Family panel than a mirror; so useful for us to keep activities, list and routines and important info for a daily basis)
              Anyway the modules that matches yours:
              default modules:
              newsfeed,
              alert,
              updatenotification --> config disabled: true
              Third Party modules:
              MMM-AlexaControl,
              MMM-Pages & MMM-page-indicator,
              MMM-RemoteControl,
              MMM-GroveGestures,
              MMM-Tools,
              Im pretty sure the rpi freezes due to RAIN-MAP animation itself and not because of any module interaction but am not 100% sure.
              I’ve updated the module but nothing changes and mirror freezes if I show the RAIN-MAP (got it hidden on start and call it by alexaControl whenever I wanna show it).
              If I disabled the module, never freezes (have it on for hours with no problems --> we usually shutdown the rpi when going to bed…If I enabled the module and make it visible on the mirror it freezes at some point (maybe minutes, maybe hours…but it freezes indeed). If I start the mirror (remember default RAIN-MAP not visible) and never show the RAIN-MAP never freezes. If I disable the module (disabled: true) in config cpu usage & temperature on the pi are fine but If I enable it goes up to 40-70% at some stages and temperature goes over 70ºC sometimes…(not good)
              I increase value of animationSpeed on module config must say improves rpi performance (I’ve set it @800 and its fine for a longer period and maybe if we’re lucky the pi does not freeze). Could be the zoom in/out feature on module itself…don’t know as its hard to catch a useful log to look at. No error at all on pm2 logs.
              Here my newbie contribution; hope we can found something as module looks nice on the Mirror!
              I will keep an eye on this topic and, indeed, post it here if find something that helps…
              Cheers!
              FoziF 1 Reply Last reply
              • rubenixR
                rubenix
                Also must to say that Ive a raspbian virtual machine on my vmware workstation where I do all my tests with module on it and never freezes; actually Ive got the beauties “MMM-ISS-Live” & “MMM-Earth-Live” that my raspi could not handle and works flawlessly on the VM…
                BTW its a pi3B (not the B+) --> so maybe time to upgrade to Asus Tinker Board or pi 4 4GB…
                  chassain 0 @rubenix
                  @rubenix or pi 4 8GB. :) i have a lot of modules switching with the module mm pages and i have no problem with rain map (power on during 24h/24)
                  C rubenixR 2 Replies Last reply
                    chassain 0 @chassain 0
                    @chassain-0 i have a rasp pi4 4GB
                    • rubenixR
                      rubenix @chassain 0
                      @chassain-0 yeah something more powerful indeed; the most the better.
                      anyway have no problem at all with any of my pages but when I switch to RAIN-MAP page (by alexa, gesture or automatically on rotation) i see the cpu usage when It shows on the mirror…
                      hardware upgrade coming soon…
                        chassain 0 @rubenix
                        • JalibuJ
                          I think about pre-rendering the map animation once as gif image in the backend using phantom instead of live rendering on the frontend. I’ll test that when time allows…
                          rubenixR 1 Reply Last reply
                          • rubenixR
                            rubenix @Jalibu
                            @Jalibu sounds nice!
                            • FoziF
                              Fozi Project Sponsor @rubenix
                              @rubenix thank you so much for your thorough and comprehensive analysis and feedback!
                              I will now disable the above mentioned 5 3rd party modules nd enablle them one by and check if they’d interfere with MMM-RAIN-MAP. I’ll keep you all posted!
                              • rubenixR
                                rubenix @Fozi
                                @Fozi 6 actually. i’ve posted pages & pages indicator @same line :face_with_stuck-out_tongue_winking_eye:
                                • FoziF
                                  @rubenix sorry, you’re right…my mistake. I just restarted MM and got an update notification for MMM-RAIN-MAP. I’ll pull that and test right away with the new version.
                                  • rubenixR
                                    rubenix @Fozi
                                    @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
                                    • JalibuJ
                                      I have a alpha version for a backend-generated (pre-rendered) map.
                                      Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
                                      rubenixR C 2 Replies Last reply
                                      • rubenixR
                                        rubenix @Jalibu
                                        @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
                                          chassain 0 @Jalibu
                                          @Jalibu i can again
                                          • FoziF
                                            @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
                                            • 10
                                            • 2 / 10
