    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 309.3k Views 42 Watching
    • rubenixR Offline
      rubenix
      Also must to say that Ive a raspbian virtual machine on my vmware workstation where I do all my tests with module on it and never freezes; actually Ive got the beauties “MMM-ISS-Live” & “MMM-Earth-Live” that my raspi could not handle and works flawlessly on the VM…
      BTW its a pi3B (not the B+) --> so maybe time to upgrade to Asus Tinker Board or pi 4 4GB…
        chassain 0 @rubenix
        @rubenix or pi 4 8GB. :) i have a lot of modules switching with the module mm pages and i have no problem with rain map (power on during 24h/24)
        C rubenixR 2 Replies Last reply Reply Quote 0
          chassain 0 @chassain 0
          @chassain-0 i have a rasp pi4 4GB
          • rubenixR Offline
            rubenix @chassain 0
            @chassain-0 yeah something more powerful indeed; the most the better.
            anyway have no problem at all with any of my pages but when I switch to RAIN-MAP page (by alexa, gesture or automatically on rotation) i see the cpu usage when It shows on the mirror…
            hardware upgrade coming soon…
              chassain 0 @rubenix
              • JalibuJ Offline
                Jalibu Module Developer
                I think about pre-rendering the map animation once as gif image in the backend using phantom instead of live rendering on the frontend. I’ll test that when time allows…
                rubenixR 1 Reply Last reply Reply Quote 0
                • rubenixR Offline
                  rubenix @Jalibu
                  @Jalibu sounds nice!
                  • FoziF Offline
                    Fozi Project Sponsor @rubenix
                    @rubenix thank you so much for your thorough and comprehensive analysis and feedback!
                    I will now disable the above mentioned 5 3rd party modules nd enablle them one by and check if they’d interfere with MMM-RAIN-MAP. I’ll keep you all posted!
                    • rubenixR Offline
                      rubenix @Fozi
                      @Fozi 6 actually. i’ve posted pages & pages indicator @same line :face_with_stuck-out_tongue_winking_eye:
                      • FoziF Offline
                        @rubenix sorry, you’re right…my mistake. I just restarted MM and got an update notification for MMM-RAIN-MAP. I’ll pull that and test right away with the new version.
                        • rubenixR Offline
                          rubenix @Fozi
                          @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
                          • JalibuJ Offline
                            I have a alpha version for a backend-generated (pre-rendered) map.
                            Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
                            rubenixR C 2 Replies Last reply Reply Quote 0
                            • rubenixR Offline
                              rubenix @Jalibu
                              @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
                                chassain 0 @Jalibu
                                @Jalibu i can again
                                • FoziF Offline
                                  @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
                                  • JalibuJ Offline
                                    The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
                                    The little problem is that prerendering is kind of ultra heavy :-D
                                    My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
                                    For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
                                    • FoziF Offline
                                      I FOUND THE “CULPRIT”!!
                                      Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
                                      And Bingo!
                                      Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
                                      I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
                                      And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
                                      Thanks to all of you and @Jalibu for helping me!
                                        requiemmg
                                        Hi @jalibu,
                                        I really like this module, but I fear that the memory issue still persists.
                                        Just cloned the repo, the module runs fine for some minutes or up to one hour, then the Raspi freezes. I am running on a 1GB 3B+ with 4 pages.
                                        Anything you can do about it?
                                        rubenixR JalibuJ 2 Replies Last reply Reply Quote 0
                                        • rubenixR Offline
                                          rubenix @requiemmg
                                          @requiemmg since I updated the pi to a Pi 4 4GB have no issues at all…came from a pi3 1GB too
                                          • JalibuJ Offline
                                            Jalibu Module Developer @requiemmg
                                            @requiemmg
                                            yepp, as @rubenix mentioned, 1GB memory is unfortunately too little :-/
                                            On my Raspi 4, 4GB it just works perfectly fine.
                                            I already tried to optimize the rendering to get it working with limited resources, but without success ¯\(ツ)/¯
                                            • 10
                                            • 2 / 10
