    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • FoziF
      Fozi Project Sponsor @rubenix
      @rubenix thank you so much for your thorough and comprehensive analysis and feedback!
      I will now disable the above mentioned 5 3rd party modules nd enablle them one by and check if they’d interfere with MMM-RAIN-MAP. I’ll keep you all posted!
      rubenixR 1 Reply Last reply
      • rubenixR
        rubenix @Fozi
        @Fozi 6 actually. i’ve posted pages & pages indicator @same line :face_with_stuck-out_tongue_winking_eye:
        FoziF 1 Reply Last reply
        • FoziF
          @rubenix sorry, you’re right…my mistake. I just restarted MM and got an update notification for MMM-RAIN-MAP. I’ll pull that and test right away with the new version.
          • rubenixR
            rubenix @Fozi
            @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
            • JalibuJ
              Jalibu Module Developer
              I have a alpha version for a backend-generated (pre-rendered) map.
              Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
              rubenixR C 2 Replies Last reply
              • rubenixR
                rubenix @Jalibu
                @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
                  chassain 0 @Jalibu
                  @Jalibu i can again
                  • FoziF
                    @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
                    • JalibuJ
                      The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
                      The little problem is that prerendering is kind of ultra heavy :-D
                      My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
                      For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
                      • FoziF
                        I FOUND THE “CULPRIT”!!
                        Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
                        And Bingo!
                        Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
                        I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
                        And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
                        Thanks to all of you and @Jalibu for helping me!
                          requiemmg
                          Hi @jalibu,
                          I really like this module, but I fear that the memory issue still persists.
                          Just cloned the repo, the module runs fine for some minutes or up to one hour, then the Raspi freezes. I am running on a 1GB 3B+ with 4 pages.
                          Anything you can do about it?
                          rubenixR JalibuJ 2 Replies Last reply
                          • rubenixR
                            rubenix @requiemmg
                            @requiemmg since I updated the pi to a Pi 4 4GB have no issues at all…came from a pi3 1GB too
                            • JalibuJ
                              Jalibu Module Developer @requiemmg
                              @requiemmg
                              yepp, as @rubenix mentioned, 1GB memory is unfortunately too little :-/
                              On my Raspi 4, 4GB it just works perfectly fine.
                              I already tried to optimize the rendering to get it working with limited resources, but without success ¯\(ツ)/¯
                              • rubenixR
                                rubenix @Jalibu
                                @Jalibu & @requiemmg was tempted to go for the 8GB one, but I can confirm 4Gb is more than enought; go for it and use the pi3 for another project :love-you_gesture_light_skin_tone:
                                  sdetweil @rubenix
                                  @rubenix u can make the swap space bigger too, helps in some environments
                                  • rubenixR
                                    rubenix @sdetweil
                                    @sdetweil i agree with that and sure it helps; but a pi 4 4Gb goes so smoth!!
                                    pi3 1gb its ok for a simple magic mirror; for a complex one with transitions / animations it needs more gauge!
                                    • earnestrichardsE
                                      earnestrichards
                                      Great module. It’s running fantastically on my PI4.
                                        requiemmg
                                        Okay, for now I will not switch to a 4gb version. So I need to remember this one for “later”. Thanks.
                                        • bheplerB
                                          bhepler Module Developer
                                          I just tried this out. Thank you for the excellent module! Exactly what I was looking for.
                                          Now if I could just get a dark theme going. I’m cool with the rain being in color, but it would be nice if I could figure out how to get the roads & state borders to only be outlines.
                                          karsten13K 1 Reply Last reply
                                            bdream
                                            @Jalibu Just tried it out and it works fantastic wit OSM. Great job! :clapping_hands_medium-light_skin_tone: Many thanks
                                            cheers, bdream
                                            • 10
                                            • 3 / 10
