    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 316.1k Views 42 Watching
    • rubenixR
      rubenix @Fozi
      @Fozi ok thanks, did not check the mirror today and dont know if i can pull the update; let me tuned mate!
      • JalibuJ
        Jalibu Module Developer
        I have a alpha version for a backend-generated (pre-rendered) map.
        Are there any volunteers who would like to test it? (Please only people who can withstand high frustration :-D )
        rubenixR C 2 Replies Last reply Reply Quote 0
        • rubenixR
          rubenix @Jalibu
          @Jalibu I can test it out on a virtual machine running raspbian for you if that helps :winking_face:
            chassain 0 @Jalibu
            @Jalibu i can again
            • FoziF
              Fozi Project Sponsor @rubenix
              @rubenix I’ve disabled yesterday all 6 modules, but unfortunatelly the situation didn’t improve. The memory consumption was still increasing over the time and within 1-2 hrs. the MM froze. I guess I have to do the brute force method and disable all modules and enable them one by one.
              • JalibuJ
                The serverside prerendering works in theory. The recording is just 2-4 Megabytes and the playback on the frontend consumes nearly no additional computing resources.
                The little problem is that prerendering is kind of ultra heavy :-D
                My Raspi 3 takes more than a minute for that (with only a few additional modules running) and takes >60MB memory for that.
                For those of you having problems due to limited resources with live rendering, the prerendering won’t be the answer I guess :-/
                • FoziF
                  I FOUND THE “CULPRIT”!!
                  Yesterday I tinkered around with a module I tried some time ago (MMM-TextClock) and deactivate MMM-google-routes, as I knew the didn’t play well together. In that context I enabled MMM-RAIN-MAP again, just to see if that would have any effect if MMM-google-routes was disabled.
                  And Bingo!
                  Since yesterday evening I had no crash or freeze on my MM. Also the memory consumption appears normal and the processor load is between 5%-20% on average (RPi 3b+)
                  I’ll keep MMM-google-routes disabled for now, as I gives me no real added value at the moment.
                  And to be clear, it is is a beautiful module and I love it, but I have no current use case for it. I ran it from the very beginning of my MM build without any issues and it is an eye catcher, too. But in favour of MMM-TextClock and MMM-RAIN-MAP we’ll have a pause ;-)
                  Thanks to all of you and @Jalibu for helping me!
                    requiemmg
                    Hi @jalibu,
                    I really like this module, but I fear that the memory issue still persists.
                    Just cloned the repo, the module runs fine for some minutes or up to one hour, then the Raspi freezes. I am running on a 1GB 3B+ with 4 pages.
                    Anything you can do about it?
                    rubenixR JalibuJ 2 Replies Last reply Reply Quote 0
                    • rubenixR
                      rubenix @requiemmg
                      @requiemmg since I updated the pi to a Pi 4 4GB have no issues at all…came from a pi3 1GB too
                      • JalibuJ
                        Jalibu Module Developer @requiemmg
                        @requiemmg
                        yepp, as @rubenix mentioned, 1GB memory is unfortunately too little :-/
                        On my Raspi 4, 4GB it just works perfectly fine.
                        I already tried to optimize the rendering to get it working with limited resources, but without success ¯\(ツ)/¯
                        rubenixR 1 Reply Last reply Reply Quote 0
                        • rubenixR
                          rubenix @Jalibu
                          @Jalibu & @requiemmg was tempted to go for the 8GB one, but I can confirm 4Gb is more than enought; go for it and use the pi3 for another project :love-you_gesture_light_skin_tone:
                            sdetweil @rubenix
                            @rubenix u can make the swap space bigger too, helps in some environments
                            • rubenixR
                              rubenix @sdetweil
                              @sdetweil i agree with that and sure it helps; but a pi 4 4Gb goes so smoth!!
                              pi3 1gb its ok for a simple magic mirror; for a complex one with transitions / animations it needs more gauge!
                              • earnestrichardsE
                                earnestrichards
                                Great module. It’s running fantastically on my PI4.
                                  requiemmg
                                  Okay, for now I will not switch to a 4gb version. So I need to remember this one for “later”. Thanks.
                                    bhepler Module Developer
                                    I just tried this out. Thank you for the excellent module! Exactly what I was looking for.
                                    Now if I could just get a dark theme going. I’m cool with the rain being in color, but it would be nice if I could figure out how to get the roads & state borders to only be outlines.
                                      bdream
                                      @Jalibu Just tried it out and it works fantastic wit OSM. Great job! :clapping_hands_medium-light_skin_tone: Many thanks
                                      cheers, bdream
                                      • karsten13K
                                        karsten13 @bhepler
                                        @bhepler
                                        or
                                        JalibuJ 1 Reply Last reply Reply Quote 2
                                        • JalibuJ
                                          Jalibu Module Developer @karsten13
                                          @karsten13 thanks for your contribution. I saw your PR and will merge it soon.
                                          • ViDiBiV
                                            ViDiBi
                                            Hi @Jalibu!
                                            This module is really amazing! Thank you so much!
                                            Maybe you can help me with one issue: The map doesn’t center correctly on my Mirror… Have I done something wrong:
                                                        module: "MMM-RAIN-MAP",
                                                        position: "bottom_right",
                                                            animationSpeed: 600,
                                                            displayClockSymbol: false,
                                                            displayTime: true,
                                                            extraDelayLastFrame: 1000,
                                                            height: "420px",
                                                            lat: 50.31,
                                                            lon: 11.91,
                                                            map: "OSM",
                                                            markers: [
        { lat: 50.31, lng: 11.91, color: "red" },
                                                            onlyOnRain: false,
                                                            opacity: 0.65,
                                                            timeFormat: 24,
                                                            updateIntervalInSeconds: 300,
                                                            width: "420px",
                                                            zoom: 9,
                                                            zoomOutEach: 1,
                                                            zoomOutLevel: 3,
                                            Bild 1
                                            Bild 2
                                            Thank you very much :-)
                                            Victor
                                            • 10
                                            • 3 / 10
