    mmm assistant mk2
    112 Posts 12 Posters 70.0k Views 11 Watching
    • E Offline
      electros Project Sponsor @sdmydbr9
      @sdmydbr9 I have same problem with mmm assistant mk2. Can you please send me that zip archive from old version? I can send you a message with my email address.
      Thank you.
        [[global:former-user]]
        see this post
          reddyman
          @Bugsounet Ahh that makes sense. I’m sorry to hear that project is dead but I understand. I’m sorry you had to deal with so many crappy and ugly people; they don’t deserve anything from someone who put in so much hardwork and sweat as you have.
          Gah, I just wish I didn’t update my mirror yesterday. The last time I updated it was in February and everything was working perfectly. And of course when I updated, I didn’t bother making a backup. Valuable lesson learned though!
          I’ll take down my mirror for now I guess. But best of luck to you Bugsounet to anything you do in the future!
            @reddyman : don’t remove it ;)
            I am ready to deploy the new assistant
            AND … I am ready to deploy the new Assistant2Display
            Edit:
            • MMM-Assistant2Display is deployed
              reddyman
              I had thought you meant you were stepping down completely. I misunderstood, this is wonderful news!
              I will be checking for days for your new assistant then… and let me know if you take donations!
                For clarify why closing it:
                • In this forum, there 2 gays who arcel me and there are now stopped
                So, I don’t want to continue with AMk2 name (sorry @sean)
                too many bad memories are in mind with this module name
                  dvbit
                  Hi @Bugsounet thanks !
                  Your work is really appreciated.
                  I wish I knew js to help.
                  However if you need polite and Linux expert beamta testers or simply financial contribution please let me know.
                    @dvbit: thx :)
                    Time -> 23:30
                    Deploy new Assistant in 30 min !
                      dvbit
                      Bien heureux de t’aider si tu veux. Je suis italien mais je parle francais. Meme si c’est seulement pour traduire ;-)
                        AND… it’s now time !
                        Welcome to the new assistant : MMM-GoogleAssistant
                        Welcome to the new Assistant2Display: MMM-Assistant2Display
                        D S D 3 Replies Last reply Reply Quote 0
                          dvbit @Guest
                          @Bugsounet great!
                          Will be testing.
                          And reporting quietly .
                          Tx again. Merci
                          Ps: good I have exactly the same setup.
                            Attention … configuration is not the same.
                            Read Wiki
                            D ChrisC 2 Replies Last reply Reply Quote 1
                              dvbit @Guest
                              @Bugsounet yep. Sure. Reading now. Installing tomorrow.and giving you feedback.
                              If you need help in giving simple support (i.e. dumb Linux, not reading the wiki … Aka not real issue / first level support I can try to help you there :-))
                                no problem :)
                                  reddyman
                                  Started partial installation tonight…and I can say: what an absolutely beautiful and efficient installer! This is the best installer I have seen for a module.
                                  I’m running it on a fresh installation of Raspberry Pi OS and fresh installation of MagicMirror with no other modules installed.
                                  Ran into a small hiccup during the post-installation process, during audio configuration for the speakers. I can’t get any sound output.
                                  It’s late so I will fiddle and experiment more tomorrow but in case anyone else runs into the same problem before I figure out a solution, I’ll leave some data below:
                                  Sending audio output via aux cable from pi to monitor and can confirm audio is working when playing a youtube video.
                                  Interestingly I hear a beep during this part of the installation, but nothing after that:
                                  Do you want to check compatible GCC version [Y/n]
                                  Your choice:
                                  No sound from here onwards:
                                  Checking Speaker and Microphone...
                                  Do you want check your audio configuration [Y/n]
                                  Your choice: Y
                                  Checking audio output...
                                  Make sure your speakers are on press [Yes].
                                  Press [No] if you don't want to check. [Y/n]
                                  Your choice: Y
                                  Current configuration not working !
                                  Did you hear Google beep? [Y/n]
                                  Your choice: n
                                  Selection of the speaker device
                                  card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
                                  card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
                                  Indicate the card # to use [0-9]: 0
                                  Indicate the device # to use [0-9]: 0
                                  you have selected: hw:0,0 (plughw:0)
                                  Your choice: Y
                                  Your choice: n
                                  Indicate the device # to use [0-9]: 1
                                  you have selected: hw:0,1 (plughw:0)
                                  Your choice: Y
                                  Your choice: n
                                  Indicate the card # to use [0-9]: 1
                                  you have selected: hw:1,0 (plughw:1)
                                  Your choice: Y
                                  Your choice: n
                                  you have selected: hw:1,1 (plughw:1)
                                  Your choice: Y
                                  Your choice: n
                                  aplay -l
                                  **** List of PLAYBACK Hardware Devices ****
                                    Subdevices: 4/4
                                    Subdevice #0: subdevice #0
                                    Subdevice #1: subdevice #1
                                    Subdevice #2: subdevice #2
                                    Subdevice #3: subdevice #3
                                    Subdevices: 4/4
                                  EDIT:
                                  I couldn’t sleep so I continued playing. I set audio speaker output to 1,0 which should be the correct configuration for me even though I couldn’t hear anything and I was getting an error. HOWEVER, in the next portion where I had to setup my microphone, I was able to hear my own voice playback.
                                  Ran through the sample config example, and everything works perfectly with the brief testing I have done. Beautiful work Bugsounet!
                                    sdmydbr @Guest
                                    @Bugsounet thank you so much for this awesome module… works like a charm… 🤩
                                      djdocta @Guest
                                      @Bugsounet said in mmm assistant mk2:
                                      Will do some tests and debug on it but …
                                      Impressive.
                                      Good work.
                                      Congrats. and THANKS for sharing.
                                        dvbit
                                        Installing . Flawless process
                                          dvbit
                                          and flawless install!
                                          Thanks @Bugsounet
                                            dvbit
                                            A2D was not working at first launch.
                                            npm rebuild in the directory did the trick.
                                            Working now
                                            • 2 / 6
