    mmm assistant mk2
    112 Posts 12 Posters 76.4k Views 11 Watching
      A Former User
      AND… it’s now time !
      Welcome to the new assistant : MMM-GoogleAssistant
      Welcome to the new Assistant2Display: MMM-Assistant2Display
      D S D 3 Replies Last reply Reply Quote 0
        dvbit @Guest
        @Bugsounet great!
        Will be testing.
        And reporting quietly .
        Tx again. Merci
        Ps: good I have exactly the same setup.
          A Former User
          Attention … configuration is not the same.
          Read Wiki
          D ChrisC 2 Replies Last reply Reply Quote 1
            dvbit @Guest
            @Bugsounet yep. Sure. Reading now. Installing tomorrow.and giving you feedback.
            If you need help in giving simple support (i.e. dumb Linux, not reading the wiki … Aka not real issue / first level support I can try to help you there :-))
              A Former User
              no problem :)
                reddyman
                Started partial installation tonight…and I can say: what an absolutely beautiful and efficient installer! This is the best installer I have seen for a module.
                I’m running it on a fresh installation of Raspberry Pi OS and fresh installation of MagicMirror with no other modules installed.
                Ran into a small hiccup during the post-installation process, during audio configuration for the speakers. I can’t get any sound output.
                It’s late so I will fiddle and experiment more tomorrow but in case anyone else runs into the same problem before I figure out a solution, I’ll leave some data below:
                Sending audio output via aux cable from pi to monitor and can confirm audio is working when playing a youtube video.
                Interestingly I hear a beep during this part of the installation, but nothing after that:
                Do you want to check compatible GCC version [Y/n]
                Your choice:
                No sound from here onwards:
                Checking Speaker and Microphone...
                Do you want check your audio configuration [Y/n]
                Your choice: Y
                Checking audio output...
                Make sure your speakers are on press [Yes].
                Press [No] if you don't want to check. [Y/n]
                Your choice: Y
                Current configuration not working !
                Did you hear Google beep? [Y/n]
                Your choice: n
                Selection of the speaker device
                card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
                card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
                Indicate the card # to use [0-9]: 0
                Indicate the device # to use [0-9]: 0
                you have selected: hw:0,0 (plughw:0)
                Your choice: Y
                Your choice: n
                Indicate the device # to use [0-9]: 1
                you have selected: hw:0,1 (plughw:0)
                Your choice: Y
                Your choice: n
                Indicate the card # to use [0-9]: 1
                you have selected: hw:1,0 (plughw:1)
                Your choice: Y
                Your choice: n
                you have selected: hw:1,1 (plughw:1)
                Your choice: Y
                Your choice: n
                aplay -l
                **** List of PLAYBACK Hardware Devices ****
                  Subdevices: 4/4
                  Subdevice #0: subdevice #0
                  Subdevice #1: subdevice #1
                  Subdevice #2: subdevice #2
                  Subdevice #3: subdevice #3
                  Subdevices: 4/4
                EDIT:
                I couldn’t sleep so I continued playing. I set audio speaker output to 1,0 which should be the correct configuration for me even though I couldn’t hear anything and I was getting an error. HOWEVER, in the next portion where I had to setup my microphone, I was able to hear my own voice playback.
                Ran through the sample config example, and everything works perfectly with the brief testing I have done. Beautiful work Bugsounet!
                  sdmydbr @Guest
                  @Bugsounet thank you so much for this awesome module… works like a charm… 🤩
                    djdocta @Guest
                    @Bugsounet said in mmm assistant mk2:
                    Will do some tests and debug on it but …
                    Impressive.
                    Good work.
                    Congrats. and THANKS for sharing.
                      dvbit
                      Installing . Flawless process
                        dvbit
                        and flawless install!
                        Thanks @Bugsounet
                          dvbit
                          A2D was not working at first launch.
                          npm rebuild in the directory did the trick.
                          Working now
                            dvbit
                            Hi
                            Curious it has been working for the first calls.
                            Now It answers on screen.
                            Not via speakers (but that could be for sure a problem with my audio setup)
                            The other thing is that the on screen google assistant prompt on top keeps spinning and no further interaction is possible.
                            Here is the debug log.
                            I can see the call is successfully created files inthe tmp directory and have scped them to my laptop and they are ok.
                            What changed in between was the tests are that I installed a2d .
                            While I investigate on my audio output to check if it works I post the log in debug mode
                            I see a suspicious “null” in volume in the log.
                            I tried a vlc lastResponse.mp3 and it was correctly output
                            [2020-06-01 12:15:47.539] [LOG]    [ASSISTANT:AS] CONVERSATION:SCREEN object
                            [2020-06-01 12:15:47.542] [LOG]    [ASSISTANT:AS] CONVERSATION:ACTION { requestId: '5ed37b16-0000-2f10-85f3-089e0827ce88' }
                            [2020-06-01 12:15:47.543] [LOG]    [ASSISTANT:AS] CONVERSATION:RESPONSE
                            [2020-06-01 12:15:47.589] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.592] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.593] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.594] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.596] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.597] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
                            [2020-06-01 12:15:47.598] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 768
                            [2020-06-01 12:15:47.602] [LOG]    [ASSISTANT:AS] CONVERSATION_ALL_RESPONSES_RECEIVED
                            [2020-06-01 12:15:47.603] [LOG]    [ASSISTANT:AS] CONVERSATION_END:COMPLETED
                            [2020-06-01 12:15:47.603] [LOG]    [ASSISTANT:AS] CONVERSATION_PP:RESPONSE_AUDIO_PROCESSED
                            [2020-06-01 12:15:47.604] [LOG]    [MP3] MP3 FILE CREATED 10368 bytes
                            [2020-06-01 12:15:47.656] [LOG]    [ASSISTANT:SP] CONVERSATION:SCREENOUTPUT_CREATED
                            [2020-06-01 12:15:47.657] [LOG]    [ASSISTANT] ASSISTANT_RESULT { error: null,
                              action: { requestId: '5ed37b16-0000-2f10-85f3-089e0827ce88' },
                              text: null,
                              screen:
                               { text:
                                  'Bracciano RM / Ora locale\n12:15\nlunedì 1 giugno 2020\nOrario (Edited)',
                                 links: [],
                                 photos: [],
                                 path:
                                  '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastScreenOutput.html',
                                 uri: 'tmp/lastScreenOutput.html' },
                              audio:
                               { path:
                                  '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastResponse.mp3',
                                 uri: 'tmp/lastResponse.mp3' },
                              transcription: { transcription: 'a che ora è', done: true },
                              continue: false,
                              volume: null,
                              lastQuery:
                               { type: 'MIC',
                                 key: null,
                                 lang: 'it-IT',
                                 useScreenOutput: true,
                                 useAudioOutput: true,
                                 status: 'standby',
                                 chime: true } }
                              dvbit
                              Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
                              Still the same issue of assistant hanging after query:
                              I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
                              After refreshing the screen goes again in “steady state”
                              Now I am sure I have a sound output issue.
                              Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
                              I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
                              What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
                              Will continue checking
                              • ChrisC
                                Chris @Guest
                                @Bugsounet
                                First of all, thank you for not stopping your work on this module which is of high quality.
                                I tried to install the new assistant. I followed the wiki. However, I have a problem.
                                Indeed, when the mirror is launched, I find myself with the following message:
                                [2020-06-01 14:04:54.256] [LOG]    [ASSISTANT][ERROR] token.json file not found
                                However, I followed the WIKI well and applied the following command:
                                (env) pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ ACCESSTOKEN=ya29.a0AfH6SMABBPj590X_itMQG616F8QpxddhPVuSXCE4qvZs6znHKbG2n5RggszFMdl0V5HP0lf956H9O7VHlbuGuMxSzkU3pMkdbpFxs485NwfXYl9T7hfLzB0EOPlRTwcifZW-8rIUlZlWXXXXXXXXXXXXXXXXXXX
                                Do you have any idea about this problem?
                                Thanking you in advance,
                                Regards,
                                  A Former User
                                  @dvbit try this:
                                  launch it in root directly in RPI terminal (not ssh)
                                  sudo ./node_modules/.bin/electron js/electron.js --no-sandbox
                                  give me result
                                    A Former User
                                    @chris: token.json file must be located in ~/MagicMirror/modules/MMM-GoogleAssistant/token.json
                                    ChrisC 1 Reply Last reply Reply Quote 0
                                      sdetweil @Guest
                                      @Bugsounet u can also run the fixsandbox script from my repo
                                      if they use my installer I fix it… otherwise they either need the --nosandbox or run my script
                                        A Former User
                                        sam, i suspect a bug in electron
                                        chown root and chmod 4755 ?
                                          sdetweil @Guest
                                          @Bugsounet yes, what my script does…
                                          not a bug, new feature
                                            A Former User
                                            yes but i don’t understand why … with pulseaudio there is no sound but with root it’s works …
                                            There is a permission missing somewhere
                                            • 2 / 6
