    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 553.7k Views 29 Watching
    • Mykle1M
      What a surprise! The USNO api has not resumed normal operations by the expected completion date. I’ll keep checking the site but it’s anyone’s guess now. :(
      • Mykle1M
        So, I went outside just as the sun was setting a little while ago and noticed the sky had cleared (it has been raining for days) and the moon was shining brightly. Ran inside, got my camera, click!
        • Mykle1M
          From the USNO website.
          S StoffbeuteluweS 2 Replies Last reply
            sdetweil @Mykle1
            @Mykle1 can’t help myself.alt text
            Mykle1M 1 Reply Last reply
            • Mykle1M
              :thumbsup:
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @Mykle1
                @Mykle1 Ohh no:disappointed_but_relieved_face:
                • Mykle1M
                  I found this very interesting.
                  “You’ve never seen the moon like in this ‘all terminator’ image (and you never will).”
                  "Shadows creep down the banks of every crater on the near-side of the moon, highlighting the pockmarked face of Earth’s gravitationally-bound buddy with a clarity never before seen.
                  According to photographer Andrew McCarthy, who posted the stunning image to his Instagram in April, there’s a simple explanation for the unprecedented level of detail in his work — this lunar view is actually “impossible.”
                  “This moon might look a little funny to you, and that’s because it is an impossible scene,” McCarthy wrote on Instagram. “From two weeks of images of the waxing moon, I took the section of the picture that has the most contrast … aligned and blended them to show the rich texture across the entire surface.”
                  The high-contrast section of the moon that McCarthy referred to is called the “lunar terminator” — the long line in the sand (or regolith, if you prefer) that divides the moon’s Earth-facing side between darkness and light. This terminator line moves around constantly depending on the phase of the moon, revealing or concealing new sections of the lunar surface each day. Because the terminator line heightens the contrast between the light and dark sides of the moon’s face, shadows look elongated and intensified in craters closest to the terminator.
                  • Y
                    yomm
                    Thanks a lot for your work on this addon.
                    I would like to hide the information about the distance to get just the image. I read carefully the README but I cannot find this configu trick.
                    Could you please tell me how ?
                    Here is my conf :
                                            disabled: false,
                                            module: 'MMM-Lunartic',
                                            position: 'top_center', // Best in left, center, or right regions
                                            classes: 'scheduler',
                                                    module_schedule: {from: '0 21 * * *', to: '0 8 * * *' },
                                                    mode: "rotating", // rotating or static
                                                    image: "current", // animation, current, DayNight or static
                                                    distance: "km", // miles or km
                                                    sounds: "no", // howling wolf, only on a full moon
                                                    useHeader: false, // true if you want a header
                                                    /* header: "The Lunartic is in my head", // Any text you want*/
                                                    maxWidth: "200px",
                                                    animationSpeed: 10,
                                                    rotateInterval: 15000,
                    Thanks for advance.
                      sdetweil @yomm
                      @yomm please edit the post and use the code block, mark the section of text and hit the </> thing above the edit window
                      • Y
                        yomm
                        I got this… its all in the css.
                        S Mykle1M 2 Replies Last reply
                          sdetweil @yomm
                          @yomm thanks for your help, corrected
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @yomm
                            @yomm said in MMM-Lunartic:
                            Yup. Glad you figured it out.
                            • Mykle1M
                              Update
                              The api is still down for both MMM-Lunartic and MMM-SunRiseSet. http://api.usno.navy.mil/
                              Their first announcement for a return to service was April 2020. The second announcement was revised to the Summer of 2020. I will keep checking. In the meantime, MMM-Lunartic still works with the temporary fix.
                              Peace
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Mykle1
                                @Mykle1
                                Update
                                StoffbeuteluweS 1 Reply Last reply
                                • StoffbeuteluweS
                                  @Mykle1 thanks 🙏
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @Stoffbeuteluwe
                                    @Stoffbeuteluwe
                                    This is a quote from their website. Upper left of the page. https://www.usno.navy.mil/USNO/astronomical-applications/data-services
                                    The USNO websites aa.usno.navy.mil, ad.usno.navy.mil, aristarchus.usno.navy.mil, maia.usno.navy.mil, rorf.usno.navy.mil, toshi.usno.navy.mil, and tycho.usno.navy.mil are undergoing modernization efforts. The expected completion of the work and the estimated return of service is Fall 2020, subject to change due to potential impacts of COVID-19.
                                    qu1queQ StoffbeuteluweS T 3 Replies Last reply
                                    • qu1queQ
                                      qu1que Project Sponsor @Mykle1
                                      @Mykle1
                                      I already feel a little sorry for the coronavirus. It always takes the blame for many things that cannot be done. [It’s a joke :face_with_stuck-out_tongue_winking_eye: ]
                                      • cowboysdudeC
                                        cowboysdude Module Developer @qu1que
                                        @qu1que said in MMM-Lunartic:
                                        @Mykle1
                                        EVERYONE blames the virus for all the things that they don’t do LOL I’m tired of it.
                                        • StoffbeuteluweS
                                          @Mykle1 Thanks for the News…hope it will work in 2021. :face_with_stuck-out_tongue_winking_eye:
                                          • T
                                            trividar @Mykle1
                                            @mykle1 Is this module working again or still down? thx
                                            Z cowboysdudeC 2 Replies Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
