    ipWhitelist HowTo
    83 Posts 36 Posters 162.7k Views 34 Watching
    • A
      AndrewVircks
      I have tried all of the suggestions to get MMM-Remote-Control to work and I cannot figure anything out. Any help would be appreciated. I keep getting Cannot GET /remote.html and I’m not sure what to do from here.
        mochman Module Developer
        That doesn’t sound like an ipWhitelist problem. Did you install MMM-Remote-Control per the instructions? If so, what exactly are you getting your error message on and what are the IPs of your magicmirror and device?
        • A
          AndrewVircks @mochman
            payal09
            Please help me out, i do all the things whatever consulted in forum to access the remote control, but it is not working from my phone, or any other devices.
            It just working on the pc from where raspberry pi is operated through vnc.
            Please, help me. My project submission date is too close, please help.
            • G
              gjones444
              Re: [[Remote-Control] Shutdown](Configure and Update your MagicMirror)
              Has anyone found a fix for the issue below? I tried hardcoding my raspberry pi IP address and creating a range of acceptable IP addresses but still not able to access the MagicMirror from my desktop or phone. Any advice?
              • L
                lolobyte @gjones444
                @gjones444
                hi
                you must configure your config.js and maybe your interent router.
                This is my adress for global access to the mm2 via internet browser
                http://raspi-mm2.xxxxxxxxxxxxxx.myfritz.net:8116/
                an this is a part of my configuration in my config .js
                var config = {
                        address: "0.0.0.0",
                        port: 8116,
                        ipWhitelist: [],
                Port forward configuration for my router for global access
                screenshot browser:
                screenshot VNC Viewer:
                • V
                  veejae
                  Anyone can help me please?
                  I tried everything but still cant get an access granted to my IP 192.168.254.107
                    sdetweil @veejae
                    @veejae addess: “localhost”, means listen ONLY inside (from myself)…
                    change to address: “0.0.0.0” (listen from anywhere)
                    • E
                      ertopps Banned
                      • L
                        leem2000
                        Hi
                        I recently installed MM and am viewing on screen rather than on a mirror. I’m unable to view MM in a web browser from another machine in the network. I get
                        This site can’t be reached
                        192.168.0.113 refused to connect.
                        I’ve gone through this topic and tried the various suggestions including turning off IPv6. No joy.
                        No errors or connection refused messages in the pm2 logs. I’ve run config:check and it runs clean.
                        netstat -lnpt
                        Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      -
                        tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      1861/electron.js
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
                        I’m trying to access with http://192.168.0.113. Ssh to the pi is fine.
                        Any ideas?
                        • L
                          leem2000 @leem2000
                          Setting address: “0.0.0.0” has solved this.
                          • O
                            openPhiL
                            really? this topic has 63k views, so it is litterally really annoying and problematic to a lot of people.
                            It is a website for a mirror, how hard do you want to make it to be set up? the website should be served to anybody who can access it. IT pros who need to secure it will be able to, without this trickery. this is bs.
                            • lavolp3L
                              lavolp3 Module Developer @openPhiL
                              @openPhiL
                              Well, suggest a better solution then. Maybe in a more constructive way.
                              Or just go ahead find something else.
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • G
                                greda
                                Hi everybody,
                                I want to connect from the outside on my maggic. I configured the config.js file like this: ipWhitelist: [“127.0.0.1”, “:: ffff: 127.0.0.1”, “:: 1”, “0.0.0.0”], // Set [] to allow all IP addresses but I don’t have remote access.
                                Thank you for your help.
                                  sdetweil @greda
                                  @greda said in ipWhitelist HowTo:
                                  u mean inside your home?
                                  address: "0.0.0.0".
                                  ipWhitelist:[],
                                  127.0.0.1 means ONLY from the same box as MM on it.
                                  • G
                                    greda
                                    @sdetweil said in ipWhitelist HowTo:
                                    Yes inside my home.
                                    • G
                                      greda
                                      Ok thanks it 's good now.
                                      • E
                                        esamecar
                                        sorry, this is a very long thread I stumbled upon because I had the problem that my browser told me that I cannot connect to a server only instance of mm2. The terminal output gave me an “Access denied to IP address” and printed the ip address I configured in the ipWhitelist section of the config file according to the getting started section in the documentation and the comment in the config itself.
                                        What I was doing was following this advice:
                                        the ip rejected was 192.168.178.42, therefore I used first
                                        "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.178.42"
                                        BUT I think I have to use (at least this is what makes it working)
                                        "127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.178.42"
                                        Does this make any sense to you?
                                        Kind regards
                                        Marco
                                          sdetweil @esamecar
                                          @esamecar what is your address: setting?
                                          to allow systems from OUTSIDE the MagicMirror hardware, you must use something OTHER than “localhost”
                                          you can either use “0.0.0.0” , which means use any ip address on this machine to listen to requests
                                          or the actual ip address (which can change )
                                          use
                                          ip addr
                                          to get the address of the wifi or ethernet connected interface
                                          THEN
                                          you can fiddle with the whitelist …
                                          using the whitelist (IMHO) is really only useful in a commercial setting where someone in the office MIGHT scan for open IP addresses and try to connect to a range of ports…
                                          in my house, noone is getting on my network unless I let them …
                                          • E
                                            esamecar @sdetweil
                                            @sdetweil thanks for your answer
                                            I was using “0.0.0.0” as ip addr already as advised in the documentation but could not pass the ipWhitelist section … omitting the “::ffff:” part helped. (Now everything is up and running.)
                                            • 4 / 5
